בעיה בקריאת קבצי DUMP.
עבדתי לפי המדריך שבסטיקי ובמקום מה שצריך להופיע לי, זה מה שמופיע לי:
Microsoft ® Windows Debugger Version 6.11.0001.404 AMD64
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\110809-20638-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\websymbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
ואין את הסיבה לבעיה כמו במדריך, מה אני עושה?
תוריד את ה symbol library למערכת ההפעלה שלך.
זה מה שזה נתן לי:
Loading Dump File [C:\Windows\Minidump\110809-21715-01.dmp]
Symbol search path is: D:\Symbols
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02a5f000 PsLoadedModuleList = 0xfffff800`02c9ce50
Debug session time: Sun Nov 8 08:17:17.061 2009 (GMT+2)
System Uptime: 0 days 15:40:18.653
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {80000028, 2, 0, fffff88001624b1c}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** WARNING: Unable to verify timestamp for ndis.sys
*** work. ***
*** work. ***
Probably caused by : ndis.sys ( ndis!NdisMQueueDpcEx+4b )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000080000028, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88001624b1c, address which referenced memory
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: ndis
FAULTING_MODULE: fffff80002a5f000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc184
READ_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
0000000080000028
CURRENT_IRQL: 0
FAULTING_IP:
fffff880`01624b1c 8b4828 mov ecx,dword ptr [rax+28h]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
LAST_CONTROL_TRANSFER: from fffff80002ad0469 to fffff80002ad0f00
STACK_TEXT:
fffff880`0af0bab8 fffff800`02ad0469 : 00000000`0000000a 00000000`80000028 00000000`00000002 00000000`00000000 : nt+0x71f00
fffff880`0af0bac0 00000000`0000000a : 00000000`80000028 00000000`00000002 00000000`00000000 fffff880`01624b1c : nt+0x71469
fffff880`0af0bac8 00000000`80000028 : 00000000`00000002 00000000`00000000 fffff880`01624b1c fffffa80`0528d800 : 0xa
fffff880`0af0bad0 00000000`00000002 : 00000000`00000000 fffff880`01624b1c fffffa80`0528d800 00000000`00000000 : 0x80000028
fffff880`0af0bad8 00000000`00000000 : fffff880`01624b1c fffffa80`0528d800 00000000`00000000 00000000`00000000 : 0x2
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
SYMBOL_NAME: ndis!NdisMQueueDpcEx+4b
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ndis.sys
BUCKET_ID: WRONG_SYMBOLS
[br]פורסם בתאריך: 15.11.2009 בשעה 17:47:35
והשני:
Machine Name:
Kernel base = 0xfffff800`02a1d000 PsLoadedModuleList = 0xfffff800`02c5ae50
Debug session time: Sun Nov 8 09:07:17.300 2009 (GMT+2)
System Uptime: 0 days 0:48:27.496
Unable to load image \SystemRoot\System32\drivers\dxgkrnl.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for dxgkrnl.sys
BugCheck 116, {fffffa8003c1a160, fffff880048ef220, 0, 2}
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : nvlddmkm.sys ( nvlddmkm!DriverEntry+dc560 )
באמת שלא חחיב להדביק את כל זה. ניסית בכלל לקרוא מה כתוב לך שם קודם?
אוקיי מצטער לא שמתי לב, הנה:
CRASH 1:
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: dxgkrnl.sys
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x00000116 (0xfffffa8003c1a160, 0xfffff880048ef220, 0x0000000000000000,
0x0000000000000002)
*** dxgkrnl.sys - Address 0xfffff8800532aef8 base at 0xfffff880052ce000 DateStamp
0x4ac5509e
CRASH2:
to your computer.
The problem seems to be caused by the following file: ndis.sys
these steps:
select Safe Mode.
*** STOP: 0x000000d1 (0x0000000080000028, 0x0000000000000002, 0x0000000000000000,
0xfffff88001624b1c)
*** ndis.sys - Address 0xfffff88001624b1c base at 0xfffff88001623000 DateStamp
0x4a5bc184
וכמעט כל יום קורה שכשאני משחק במשחק, זה פשוט יוצא מהמשחק ורושם את זה:
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1037
Files that help describe the problem
WD-20091108-0907.dmp
sysdata.xml
WERInternalMetadata.xml
View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Extra information about the problem
BCCode: 117
BCP1: FFFFFA8003C1A160
BCP2: FFFFF880048EF220
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
BlueScreenView v1.15
Copyright © 2009 Nir Sofer
Web site: http://www.nirsoft.net
הדרייברים לכרטיס מסך מעודכנים!
E8400
4GIGA GSKILL
260GTX
dxgkrnl.sys
בעייה של DirectX שיצא לך לה תיקון לפני שלושה ימים. מתי עשית Windows Update לאחרונה?
ndis.sys
בעייה של כרטיס רשת. תראה אם יש עדכון לדרייבר שלו וכמובן להציץ בWU כמו שהולץ מקודם.
נוצר לך קובץ dump גם פה.
תודה על העזרה!!! הקראשים גם כללו:
ntoskrnl.exe
dxgmms1.sys
nvlddmkm.sys
ובקשר לקראש של הכרטיס מסך, הקובץ DUMP הזה לא קיים.
