עזרה בבחירת מחשב נייד....studio xps 16 או asus g51
בעקרון אני רוצה שיהיה בו גם את היכולת להריץ משחקים כבדים....
ןיש לי התלבטות כרגע בין שתי הדגמים הנ"ל:
dell
studio xps 16:
PROCESSOR Intel® Core 2 Duo P8600 (3MB cache/2.4GHz/1066Mhz FSB)
OPERATING SYSTEM Genuine Windows Vista® Home Premium Edition SP1, 64-bit
HD DISPLAY Edge-to-Edge HD+ Widescreen 15.6 inch WLED LCD (1600x900) W/2.0 MP
MEMORY 4GB Dual Channel DDR3 SDRAM at 1067MHz (2 Dimms)
HARD DRIVE 500GB 7200 RPM SATA Hard Driv
INTERNAL OPTICAL DRIVE 8X DVD+/- RW(DVD/CD read/write) Slot Load Drive
VIDEO CARD ATI Mobility RADEON HD 4670 1GB
WIRELESS CARDS Intel® 5300 WLAN Wireless-N (3x3) Mini Card
BATTERY Additional 9-Cell Battery
SOUND OPTIONS High Definition Audio 2.0
או זה
Asus - Laptop with Intel® Centrino® 2 Processor Technology - White/Black
Model: G51VX-RX05
Product Features
* Intel® Centrino® 2 processor technology with interrelated Intel® Core2 Duo processor P7350
Intel® PM45 chipset, 802.11b/g/n network connection and extended battery life capability.
* Intel® Intelligent Power capability and Deep Power Down Technology
Reduce power consumption and help extend battery life to keep you on the go farther between charges.
* 4GB PC2-6400 DDR2 memory
For multitasking power; 1066MHz frontside bus, 3MB L2 cache and 2.0GHz processor speed.
* Multiformat DVD±RW/CD-RW drive with double-layer support
Records up to 8.5GB of data or 4 hours of video using compatible media.
* 15.6" WXGA widescreen LED display
With a 1366 x 768 resolution brings your movies and games to life.
* 320GB SATA hard drive (7200 rpm)
Provides plenty of storage space and fast read/write times.
* NVIDIA GeForce GTX 260M graphics
With 1GB of dedicated DDR3 graphics memory for powerful graphic performance. Azalia audio chip with built-in stereo speakers; HDMI output.
* See the benefits of an NVIDIA graphics processor in your laptop.
* Built-in 1.3-megapixel webcam
Makes it easy to send video mail to family and friends.
* Facial recognition security
Uses the built-in webcam and software to help keep your laptop safe.
* 8-in-1 media reader
Supports Secure Digital, miniSD, MultiMediaCard, Memory Stick, xD-Picture Card, Memory Stick PRO, Memory Stick Duo and Memory Stick PRO Duo for easy transfer of your digital photos.
* 1 IEEE 1394 port and 4 high-speed USB 2.0 ports
For fast digital video, audio and data transfer.
* Built-in 10/100 Mbps Ethernet LAN with RJ-45 connector
Ensures easy Internet connectivity.
* Illuminated keyboard
Provides improved key visibility for an enhanced gaming experience.
* Weighs 7.3 lbs. and measures just 1.6" thin
For portable power.
* Good battery life
Of up to 2 hours and 7 minutes.
* Microsoft Windows Vista Home Premium Edition 64-bit operating system
With Service Pack 1 (SP1) preinstalled for a stable operating platform.
* Software package included
With Power 4 Gear, Life-Frame 3, CyberLink Power2Go, Adobe Acrobat Reader 8 and more.....
איזה מהם יותר חזק? ואם אפשר גם למה???
תודה!!
תלוי מה השימושים שלך.
לDELL מעבד טוב יותר וזכרון מהיר, לאסוס כרטיס גרפי חזק יותר.
נא להכניס את דגמי המחשבים ו/או התקציב לכותרת.
ואללה השימושים כמו שאמרתי שידע להריץ משחקים כבדים.....בטווח זמן ארוך.....
יעניי שאני לא אצטרך לקנות עוד 3 שנים לפטופ חדש...כי זה כבר לא סוחב....
שיספיק לי ל5-6 שנים....
אז מה אתם אומרים יותר עדיף??
תודה!! :xyxthumbs:
לפי קצב ההתפתחות בתחום זה בעשור האחרון, מחשב נייד (וגם מחשב שולחני) שייקנה היום ויריץ משחקים כבדים גם בעוד 5-6 שנים פשוט לא קיים. אז אתה יכול לשכוח מזה.
ובכל זאת....
מבחינה מקצועית
לאיזה מהמחשבים כאן יש את היכולות הגבוהות יותר???
האסוס מה שאני אוהב בו שיש לו מקלדת מלאה (עם מספרים בצד) וזה נראה לי יתרון חשוב למשחקים??!!
האם יש אופצייה להרחיב באסוס את הזכרון בשלב יותר מאוחר??
ועד כמה ההבדלים גדולים בין הכרטיס מסך של דל :
VIDEO CARD ATI Mobility RADEON™ HD 4670 – 1GB
ןה 260
ובכל זאת....
מבחינה מקצועית
כן אפשר להרחיב את הזכרון ואפילו להחליף מעבד
