דיון מקדים - GeForce GTX400 VS Radeon HD5000 , החברות שולפות את הנשקים.
Nvidia Is Happy With Performance of GeForce GF100 “Fermi” Graphics Card.
Nvidia Wants to Make Fermi Perfect for Everyone
Nvidia Corp. first demonstrated its code-named GF100 (NV60, G300, GT300, etc) graphics processing units (GPU) based on Fermi architecture over three months ago. Since the product is still not released, it is not a surprise that there are loads of speculations about performance of the next-generation GeForce. According to a representative at Nvidia, the company is happy about performance of the novelty.
“We expect [Fermi] to be the fastest GPU in every single segment. The performance numbers that we have [obtained] internally just [confirms] that. So, we are happy about this and are just finalizing everything on the driver side,” said Luciano Alibrandi, the head of Nvidia public relations department in EMEAI region, in an interview with DonanimHaber web-site.
It was untraditional for Nvidia to demonstrate capabilities of its forthcoming graphics card months ahead of actual release. It is generally believed that Nvidia showed off its Fermi product in late September in an attempt to slowdown sales of its arch-rival ATI’s DirectX 11 graphics processors. The company yet has to show performance numbers of its next-gen graphics products. However, according to Mr. Alibrandi, the company is not only working hard on the new chip itself, but is also developing “perfect” drivers in an attempt to provide ultimate experience for the end-user.
“We just want to make sure it is as perfect as we want it to be in both graphics and computing [performance and quality],” said Mr. Alibrandi.
To date, Nvidia has demonstrated its next-generation GeForce GF100 graphics card rendering a DirectX 11 benchmark and working in multi-GPU SLI mode.
The chief of Nvidia’s public relations department in EMEAI did not reveal when exactly Nvidia plans to launch its GF100 GPU for consumers. The only official comment on the matter was made by the company’s chief executive Jen-Hsun Huang, who said that production of the GF100 would be ramped only in Q1 FY2011. Nvidia’s first quarter of fiscal year 2011 begins on the 26th of January and ends on the 26th of April, 2010.
The flagship Fermi graphics processor will feature 512 stream processing engines (which are organized as 16 streaming multi-processors with 32 cores in each) that support a type of multi-threading technology to maximize utilization of cores. Each stream processor has a fully pipelined integer arithmetic logic unit (ALU) and floating point unit (FPU). The top-of-the-range chip contains 3 billion of transistors, features 384-bit memory GDDR5 memory controller with ECC and features rather unprecedented 768KB unified level-two cache as well as rather complex cache hierarchy in general. Naturally, the Fermi family is compatible with DirectX 11, OpenGL 3.x and OpenCL 1.x application programming interfaces (APIs). The new chips will be made using 40nm process technology at TSMC.
http://www.xbitlabs.com/news/video/display/20091226130553_Nvidia_Is_Happy_With_Performance_of_GeForce_GF100_Fermi_Graphics_Card.html
  • תגובות 2k
  • צפיות 208.6k
משפט המפתח מבחינתי לפחות:
נקווה שהוא יקיים את מה שהם מבטיחים רק לשם התחרות הטובה ביניהם לבין ATI...
נקווה שהתחרות הטובה תביא למחירים טובים :)
נקווה אבל אני לא אופטימי , לפחות לא בחודשים הראשונים...
אני לא אופטימי בכל הדור הזה...
אחרי דור 4000 מול 200 שהיה תחרותי טיל ומתומחר מצויין הדור הזה שוב יהיה בתמחור הזוי... לכן נראה לי שאדלג עליו ואצוד 4870 יד שניה לשים בCF...
האמת היא שבכלל אין סיבה לשדרג כרגע , אז יש DX11 , ביג דיל...
האמת שלצוד איזה 275 נוסף יכול להיות רעיון טוב כשאני אתחיל להרגיש ירידה בביצועים במשחקים , כרגע אין סיבה...
אני כבר מרגיש את ה 4870 צולע לי מדי פעם...
באמת?!?!? באיזה משחקים? (ותעשה טובה אל תרשום קרייסיס :lol: )
ה260 שלי מזה צולע ב red faction guerrilla כשמבנים קורסים בייחוד כשיותר ממבנה אחד קורס אז זה כבר סיוט (מסך 22אינ'ץ) מה עושים :<
כבר דיברו על זה בדיון הראשי של המשחק ,זה משחק שמשתמש יותר במעבד וצריך מעבד חזק כדי למנוע את החלק הגדול של התקיעות והקרטועים...
אה טוב אז לא ניראה לי שאני יכול לבנות יותר מדי על הe7400 שלי :< אני מניח שצריך כבר איזה c2q ומעלה =s
בMW2 אני צריך להוריד פילטרים לX2 ולהוריד הגדרות ואני כולה על 1680 על 1050... לא תקין...
הגזמת רצח. אני עם המפרט שלי על אותו רזולוצייה משחק חלק על הגדרות גבוהות ופילטרים X2
באמא
Nvidia delays Fermi to March 2010; AMD to launch new GPU in January-February
Nvidia is expected to delay its next-generation DirectX 11-supporting GPU (Fermi) to March, 2010, while AMD will launch more GPUs in January-February, according to sources from graphics card makers.
Nvidia originally scheduled to launch Fermi in November 2009, but was delayed until CES in January 2010 due to defects, according to market rumors. However, the company recently notified graphics card makers that the official launch will now be in March 2010, the sources noted.
Nvidia plans to launch a 40nm GDDR5 memory-based Fermi-GF100 GPU in March, and will launch a GF104 version in the second quarter to target the high-end market with its GeForce GTX295/285/275/260, the sources pointed out.
For performance level markets, Nvidia will allow its GeForce GTS250, GT240/220 and 9800GT/9500GT defend against AMD's Radeon HD 5770/5750, 4870/4850 and 4670/4650.
For the mainstream market, Nvidia will mainly push its GeForce 210.
Meanwhile, AMD will launch 40nm Radeon HD 5670/5570 (Redwood) and HD 5450 (Cedar) GPUs at the end of January or in February 2010, the sources noted.
In related news, although Taiwan Semiconductor Manufacturing Company's (TSMC's) 40nm process yields have already improved, capacity is still not sufficient to supply the two GPU giants fully which may have an impact the launch schedules, the sources added.
Nvidia declined the opportunity to respond to this report saying it cannot comment on unannounced products. AMD did not respond by the time of publication.
http://www.digitimes.com/news/a20091228PD207.html
http://www.maximumpc.com/article/news/nvidia_fermi_delayed_again_amd_readies_midrange_refresh
