האם בלוח אם הזה יש 4 USB בצד החיצוני של הכונן ??
ואם כן אז איזה מארז יש לו 4 USB מקדימה
‏EP43-UD3L s775 C2Q 1333Mhz, Intel P43, DDRII 1333, PCI-E‎
Warranty 3 years
Model GA-EP43-UD3L
CPU Support for an Intel® Core 2 Extreme processor/ Intel® Core 2 Quad processor/Intel® Core 2 Duo processor/ Intel® Pentium® Dual-Core processor/Intel® Celeron® processor in the LGA 775 package
(Go to GIGABYTE's website for the latest CPU support list.)
L2 cache varies with CPU
Front Side Bus 1600(O.C.)/1333/1066/800 MHz FSB
Chipset North Bridge: Intel® P43 Express Chipset
South Bridge: Intel® ICH10
Memory 4 x 1.8V DDR2 DIMM sockets supporting up to 16 GB of system memory
Dual channel memory architecture
Support for DDR2 1200+/1066/800/667 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
Audio Realtek ALC888 codec
High Definition Audio
2/4/5.1/7.1-channel
Support for S/PDIF In/Out
Support for CD In
LAN 1 x Realtek 8111C chip (10/100/1000 Mbit)
Expansion Slots 1 x PCI Express x16 slot, running at x16
(The PCI Express x16 slot conforms to PCI Express 2.0 standard.)
4 x PCI Express x1 slots
2 x PCI slots
Storage Interface South Bridge :6 x SATA 3Gb/s connectors supporting up to 6 SATA 3Gb/s devices
JMicron 368 chip:
1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
iTE IT8718 chip:
1 x floppy disk drive connector supporting up to 1 floppy disk drive
USB Integrated in the South Bridge
Up to 12 USB 2.0/1.1 ports (8 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors 1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x IDE connector
1 x CPU fan header
2 x system fan headers
1 x power fan header
1 x front panel header
1 x front panel audio header
1 x CD In connector
1 x S/PDIF In header
1 x S/PDIF Out header
2 x USB 2.0/1.1 headers
1 x parallel port header
1 x serial port header
1 x power LED header
1 x chassis intrusion header
Back Panel Connectors 1 x PS/2 keyboard port
1 x PS/2 mouse port
1 x coaxial S/PDIF Out connector
1 x optical S/PDIF Out connector
8 x USB 2.0/1.1 ports
1 x RJ-45 ports
6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller iTE IT8718 chip
H/W Monitoring System voltage detection
CPU/System temperature detection
CPU/System/Power fan speed detection
CPU overheating warning
CPU/System/Power fan fail warning
CPU/System fan speed control
BIOS 2 x 8 Mbit flash
Use of licensed AWARD BIOS
Support for DualBIOS
PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features Support for @BIOS
Support for Q-Flash
Support for Virtual Dual BIOS
Support for Download Center
Support for Xpress Install
Support for Xpress Recovery2
Support for EasyTune
Support for Dynamic Energy Saver Advanced
Support for Time Repair
Support for Q-Share
Bundle Software Norton Internet Security(OEM version)
Operating System Support for Microsoft® Windows Vista/XP
Form Factor ATX Form Factor; 30.5cm x 21.0cm
תודה וסליחה על הבורות
כן יש לו
לכל לוח יש יותר מפרונט אחד.
השאלה היא אם יש לך במארז פרונט עם חיבור ל4 יציאות .
כאן לא מתעסקים במארזים, על כך תשאל בפורום המתאים לנושא.
הלוח הזה נותן מקסימום שנים עשר פורטים של USB, שמונה בגב הלוח בפאנל האחורי (I/O) וארבע באמצעות הרחבות מהלוח עצמו.
במידה ויש לך מארז עם ארבע פורטים מקדימה אז תוכל לנצל זאת. לידע כללי- כל חיבור מספק שני פורטים.
איזה מהירות
תודה רבה
(האם זה הודעות תודה נחשבות ספאם ??)
הסטנדרט הוא 2 יציאות קידמיות
אם אתה רוצה יותר תקנה מפצל
יש גם פאנלים קדמיים למטרה זו.
