בעיות עם DVR-217DBK של פיוניר.
נכשלו לי שתי צריבות עם פיוניר DVR-217DBK ו ImgBurn
ניסיתי לצרוב IMAGE של DVD , והוא לא הצליח.
מדיה של VERBATIM
הלוג הוא כזה:
I 17:18:16 ImgBurn Version 2.4.4.0 started!
I 17:18:16 Microsoft Windows Vista Ultimate Edition (6.0, Build 6001 : Service Pack 1)
I 17:18:16 Total Physical Memory: 2,094,860 KB - Available: 1,052,720 KB
I 17:18:16 Initialising SPTI...
I 17:18:16 Searching for SCSI / ATAPI devices...
I 17:18:16 Found 1 DVD±RW and 1 BD-ROM/HD DVD-ROM!
I 17:19:39 Operation Started!
I 17:19:39 Source File: C:\Users\Administrator\CDR1\New Folder\DVD\s01.iso
I 17:19:39 Source File Sectors: 1,370,796 (MODE1/2048)
I 17:19:39 Source File Size: 2,807,390,208 bytes
I 17:19:39 Source File Volume Identifier: s01
I 17:19:39 Source File Volume Set Identifier: 4A53B30C0000003E
I 17:19:39 Source File Application Identifier: MKISOFS ISO 9660/HFS FILESYSTEM BUILDER & CDRECORD CD-R/DVD CREATOR (C) 1993 E.YOUNGDALE (C) 1997 J.PEARSON/J.SCHILLING
I 17:19:39 Source File Implementation Identifier: mkisofs
I 17:19:39 Source File File System(s): ISO9660, UDF (1.02)
I 17:19:39 Destination Device: [0:1:0] PIONEER DVD-RW DVR-217D 1.07 (E:) (ATA)
I 17:19:39 Destination Media Type: DVD-R (Disc ID: MCC 03RG20) (Speeds: 4x, 6x, 8x, 12x, 16x, 20x)
I 17:19:39 Destination Media Sectors: 2,297,888
I 17:19:39 Write Mode: DVD
I 17:19:39 Write Type: DAO
I 17:19:39 Write Speed: MAX
I 17:19:39 Link Size: Auto
I 17:19:39 Lock Volume: Yes
I 17:19:39 Test Mode: No
I 17:19:39 OPC: No
I 17:19:39 BURN-Proof: Enabled
I 17:19:40 Advanced Settings - Optimal Writing Speed: No
I 17:19:40 Filling Buffer... (40 MB)
I 17:19:41 Writing LeadIn...
W 17:20:04 Failed to Write Sectors 768 - 799 - Reason: Unknown (Internal Target Failure) (ASC: 0x44, ASCQ: 0x4B)
W 17:20:04 Retrying (1 of 20)...
W 17:20:04 Retry Failed - Reason: Cannot Write Medium - Incompatible Format
W 17:20:04 Retrying (2 of 20)...
W 17:20:04 Retrying (3 of 20)...
W 17:20:04 Retrying (4 of 20)...
W 17:20:04 Retrying (5 of 20)...
W 17:20:04 Retrying (6 of 20)...
W 17:20:04 Retrying (7 of 20)...
W 17:20:04 Retrying (8 of 20)...
W 17:20:04 Retrying (9 of 20)...
W 17:20:04 Retrying (10 of 20)...
W 17:20:04 Retrying (11 of 20)...
W 17:20:04 Retrying (12 of 20)...
W 17:20:04 Retrying (13 of 20)...
W 17:20:04 Retrying (14 of 20)...
W 17:20:04 Retrying (15 of 20)...
W 17:20:04 Retrying (16 of 20)...
W 17:20:04 Retrying (17 of 20)...
W 17:20:04 Retrying (18 of 20)...
W 17:20:04 Retrying (19 of 20)...
W 17:20:04 Retrying (20 of 20)...
W 17:20:13 Retrying (21)...
W 17:20:14 Retry Failed - Reason: Cannot Write Medium - Incompatible Format
W 17:20:15 Retrying (22)...
W 17:20:15 Retry Failed - Reason: Cannot Write Medium - Incompatible Format
E 17:20:16 Failed to Write Sectors 768 - 799 - Reason: Unknown (Internal Target Failure) (ASC: 0x44, ASCQ: 0x4B)
I 17:20:16 Synchronising Cache...
E 17:20:23 Failed to Write Image!
E 17:20:23 Operation Failed! - Duration: 00:00:43
I 17:20:23 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
I 17:20:31 Close Request Acknowledged
I 17:20:31 Closing Down...
I 17:20:33 Shutting down SPTI...
I 17:20:33 ImgBurn closed!
לא יודע את מי להאשים, ImgBurn עבדה לי טוב עם הצורב סמסונג שלי.
אני לא כל כך מבין בדיוק מה הבעיה מהלוג שצירפתי.
אבל את אותו IMAGE צרבתי ב BurnAware ועבד אחלה.
מה אתם אומרים?
אם תוכנה אחרת הצליחה לבצע את הצריבה אז הרי שאין שום בעיה עם הצורב, הבעיה היא עם התוכנה.
תעדכן את התוכנה.
עדכון קושחה:
http://files.rpc1.org/index.php?act=view&id=5656
הקושחה עדכנית.
וגם התוכנה מעודכנת ... השתמשתי בתוכנה 100 פעם עם הצורב הקודם שלי, לא נכשלה לי מעולם צריבה.
טוב
גם ב BurnAware נדפקה לי צריבה...
חבל על הדיסקים שלי
לדעתכם הצורב דפוק?
אני חושב שהצורב דפוק גם בגלל שעכשיו הורידו אותו מKSP.
לדעתכם הצורב דפוק?
הרבה יותר סביר שהוא פשוט שונא תדיסקים האלה
קנה verbatim 16x dvd+r made in taiwan
זה הדבר הכי מגוחך שאי פעם שמעתי,אין שום קשר
יכול להיות שיש אחוז מאוד גבוה של 217DBK תקולים בKSP אז הורידו את הדגם מהאתר והפסיקו למכור אותו.
עכשיו זה נשמע פחות מגוחך?
למעשה עכשיו זה נשמע עוד יותר מגוחך כי אתה
מעלה השערות ללא ביסוס , זה לא דבר בלתי
שגרתי שחנות תוריד מוצר מהרשימה,יכולות להיות
כל מני סיבות
בוא נתחיל מזה שזו ההשערה היחידה שיש עכשיו ונכון זו השערה ולא עובדה.
והיא ההשערה היחידה שיש עכשיו.
אז עד שלא יהיה לך השערה אחרת אין לך כל זכות לקרוא להשערה שלי מגוחכת. (זה מה שנקרא דיון עינייני ולא ויכוח FXP)
גם הצורב נעלם מזאפ והמהחנויות המוכרות לי באינטרנט. (עובדה)
יש כאן דיווח על בעיה בצורב. (עובדה)
עדיין קיימים צורבים ישנים יותר של פיוניר למכירה בזאפ. (עובדה)
אני חושב שהצורב דפוק גם בגלל שעכשיו הורידו אותו מKSP עקב סידרה או יבוא פגום. (השערה עם ביסוס)
(השערה ללא ביסוס)
אם יש לך השערה אחרת כדאי לך לשלול טענה נגדית בצורה יותר מכובדת (לא נעים לקרוא "זה הדבר הכי מגוחך שאי פעם שמעתי")
ואם אשמע עוד פעם שזה נשמע עוד מגוחך אפסיק להגיב כאן. :s07:
למה לעלות בכלל השערות ? מה ההיגיון בזה?
לדעתי להעלות השערות סתם ככה זה
פשוט לא הגיוני ,יש לעבוד אם
המידע המסופק על ידי פותח התראד ולא מעבר
אלה עובדות אמיתיות , העובדות לכאורה שלך לא מוכיחות שום דבר
יש לי כל הזכות שבעולם לבטא את דעתי
ואני לא יביא השערות אחרות,כי שוב,אין שום סיבה
לעשות זאת ,אם אתה רוצה להפסיק להגיב זה החלטה
שלך, אל תאיים עליי בצורה ילדותית
מספיק לריב...
שמתי את הצורב ב KSP היום, הם אמרו שהם יבדקו אותו.
אם KSP יחליטו שהוא מקולקל (שאני בספק בזה - יגידו שהבעיה אצלי)
אז ... נראה לאיזה דגם הם יחליפו.
אני יעדכן כאן.
לגבי הדיסקים של VERBATIM.
אם לצורב יש בעיה עם הדיסקים הקיימים שלי, אז אין לי שימוש בו .
כי יש לי עוד 100 דיסקים כאלה והם עולים כמו שתי צורבים.
ומאיפה קונים דיסקים MADE IN TAIWAN של VERBATIM?
טוב , עדכונים.
שמתי את הצורב ב KSP , והם שלחו ליבואן.
והיום קיבלתי את האותו דגם אבל חדש.
מנסיון של שתי צריבות , הצורב נראה תקין, מהיר ושקט.
כנראה שהמכשיר שלי היה דפוק מהייצור, ועכשיו כנראה שבסדר.
אם יהיה בעיה , אני יעדכן פה.
[ומאיפה קונים דיסקים MADE IN TAIWAN של VERBATIM?
הדיסקים שלי הם מנעה...
איך בכלל מבדילים?
עריכה:
יש לי חבילה מ KSP
כתוב מיוצר ב TAIWAN.
