מסך כחול עם שגיאת tcpip.sys, צירפתי את הלוג מקובץ ה .dump
נראה לי שה NOD מעמיס לי על הTCP ,
בדקתי בתוכנה TcpView והיו הרבה שורות שלו באדום.
כמה תמונות מ TCPZ
http://img107.imageshack.us/img107/8997/nodjava.png
גם הג'אווה מעמיס ? מה זה כל הגי'גות שהם לוקחים ?
והנה הלוג
Unable to load image tcpip.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for tcpip.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 100000D1, {c, 2, 0, ada65f29}
Probably caused by : tcpip.sys ( tcpip!ReadNextTCB+d2 )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000c, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: ada65f29, address which referenced memory
Debugging Details:
READ_ADDRESS: 0000000c
CURRENT_IRQL: 2
FAULTING_IP:
ada65f29 8b400c mov eax,dword ptr [eax+0Ch]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: TCPZ.exe
LAST_CONTROL_TRANSFER: from ada56ade to ada65f29
STACK_TEXT:
a9ae5870 ada56ade 023acee8 a9ae5a10 88b61008 tcpip!ReadNextTCB+0xd2
a9ae5aa4 6301afd0 00000000 6301cb3f 00000000 tcpip!TdiQueryInformationEx+0x7e5
WARNING: Frame IP not in any known module. Following frames may be wrong.
a9ae5ac0 ada36197 00b61008 a9ae5a68 00000a70 0x6301afd0
a9ae5b5c ada335b5 88b61008 88b6109c 88b6109c tcpip!TCPQueryInformationEx+0x1bf
a9ae5b78 ada3356d 88b61008 88b6109c 89208b78 tcpip!TCPDispatchDeviceControl+0x129
a9ae5bb0 804e13c9 88fed030 88b61008 88b61008 tcpip!TCPDispatch+0x127
a9ae5bb0 00000000 88fed030 88b61008 88b61008 nt!KiTrap0D+0x483
88bd6960 00000000 00000000 00000000 00000000 0x0
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: tcpip!ReadNextTCB+d2
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: tcpip
IMAGE_NAME: tcpip.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 48025cec
FAILURE_BUCKET_ID: 0xD1_tcpip!ReadNextTCB+d2
לא יודע מזה כל הIO כתיבה/קריאה האלה
המספרים נראים לי מופרכים,בכל אופן
עד כמה שאני רואה התוכנה הזאת
היא בדיוק מה שגורם לבעיה TCPZ כלומר
שים לב שבדאמפ הפרוסס שרץ בעת השגיאה הוא TCPZ.exe
בSTACK TEXT מוזכר TCPIP (שהוא הדרייבר לתעבורת
אינטרנט של הוינדוס) והוא לא יכול לגרום בעיות הוא פשוט
מוזכר כי תוכנה אחרת גרמה לו בעיות בעקיפין,בגלל שהTCPZ
דלתה מידע מTCPIP ועשתה זאת באופן שמעמיס יותר מדי..
זה גרם לקריסה
מחקתי את זה, עדיין יש איטיות שכמה טאבים של אתרים פתוחים
ברגע שאני יוצא מהם המחשב עובד רגיל.
