בעיה עם צורב פיוניר 215D.
שלום לכולם,
כבר פעם שנייה שאני מנסה לצרוב משהו וכתוב בסוף תהליך הצריבה(נרו 8) שהצריבה נכשלה, הינה הלוג שנרו מוציא:
1K22-1867-0795-66M4-5312-2932-****
Windows Vista 6.0
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 8.3.6.0
Internal Version: 8, 3, 6, 0
(Nero Express)
Recorder: <PIONEER DVD-RW DVR-215D>Version: 1.13 - HA 1 TA 0 - 8.3.6.0
Adapter driver: <Serial ATA> HA 1
Drive buffer : 2000kB
Bus Type : default
CD-ROM: <PIONEER DVD-RW DVR-215D>Version: 1.13 - HA 1 TA 0 - 8.3.6.0
=== Scsi-Device-Map ===
ArrayPeripheral : MARVELL Virtual Device 1.00 mv61xx Port 4 ID 20 DMA: Off
CdRomPeripheral : WRQDU M701E749 3.5Z aanwvtbw Port 6 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-215D D: CdRom0
WRQDU M701E749 E: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4094MB (4192380kB)
Free physical memory: 2405MB (2463380kB)
Memory in use : 41 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
23.6.2009
ISO compilation
10:10:49 AM #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
10:10:49 AM #2 Text 0 File Isodoc.cpp, Line 6713
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:10:50 AM #3 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
10:10:50 AM #4 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
10:10:50 AM #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
10:10:50 AM #6 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2239935 (497:45.60, 4374MB)
10:10:50 AM #7 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
10:10:50 AM #8 Text 0 File DlgWaitCD.cpp, Line 2948
Recorder: PIONEER DVD-RW DVR-215D, Media type: DVD-R
Disc Manufacturer ID: <DAXON0> <16S>
Disc Application Code: 64, Disc Physical Code: 193
10:10:50 AM #9 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
10:10:50 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2239936 (2239936) = #2239936/497:45.61
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2239936 blocks [D: PIONEER DVD-RW DVR-215D]
10:10:50 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [D: PIONEER DVD-RW DVR-215D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4587388928, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2239936 | 0 | 0x00
2239936 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:10:54 AM #12 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
10:10:54 AM #13 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
10:10:54 AM #14 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
10:10:54 AM #15 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
10:10:54 AM #16 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
10:10:54 AM #17 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 4x (5,540 KB/s)
10:10:55 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:10:55 AM #19 Text 0 File DVDR.cpp, Line 3297
Recording mode: Sequential Recording Mode
10:10:55 AM #20 Text 0 File DVDR.cpp, Line 3451
Start write address at LBA 0
DVD high compatibility mode: Yes
10:10:55 AM #21 SPTI -1066 File SCSIPassThrough.cpp, Line 214
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x06123f80: Len x648
10:10:55 AM #22 Text 0 File Cdrdrv.cpp, Line 10187
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 0 h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 84 0E 10 87 88 80 00 .@....R.........
03 44 41 58 4F 4E 30 00 - 04 31 36 53 00 00 00 00 .DAXON0..16S....
05 88 80 00 00 00 01 00 - 06 09 0B 12 A8 88 90 00 ................
07 88 80 00 00 00 00 00 - 08 06 13 0A 0E 08 04 00 ................
09 96 06 0C 0B 70 88 00 - 0A 80 00 00 00 00 10 00 .....p..........
0B 08 18 17 B8 88 85 00 - 0C B6 79 0B B0 33 03 00 ..........y..3..
0D 30 00 D0 00 00 00 00 - 0E 0A 20 3B 37 29 1E 00 .0.........;7)..
0F 50 1D 2B 15 AA B5 00 - 10 88 80 00 00 00 00 00 .P.+............
11 00 00 00 00 00 00 00 - 12 0A 2D 39 35 2B 1D 00 ..........-95+..
13 50 1F 2D 19 98 B5 00 - 14 88 80 00 00 00 00 00 .P.-............
15 00 00 00 00 00 00 00 - 16 09 3A 45 40 2E 27 00 ..........:E@.'.
17 80 21 2E 1F 78 B5 00 - 18 88 8C 00 0C 00 0C 00 ..!..x..........
19 00 00 00 00 00 00 00 - 1A 09 4F 47 46 38 26 00 ..........OGF8&.
1B 70 21 2D 1B 67 C5 00 - 1C 88 84 00 04 00 04 00 .p!-.g..........
10:10:55 AM #23 Text 0 File DVDR.cpp, Line 3589
Reserved Track size: 2239936 (222DC0h, 4374MB) -> return code 0
10:10:55 AM #24 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
10:11:39 AM #25 SPTI -1064 File SCSIPassThrough.cpp, Line 214
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
CDB Data: 0x2A 00 00 00 03 40 00 00 20 00 00 00
Sense Code: 0x21
Sense Qual: 0x02
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 21 02
Buffer x192506c0: Len x10000
0x01 B6 94 36 5C 18 9F A2 D7 E9 61 BF A2 9A 48 74
0x99 E9 49 3A 5E 8F F4 96 9A E8 F4 B6 9D 29 22 26
0x96 19 3A 8E 2F 48 50 5A 7E 9A 44 74 83 9A 7D 2E
10:11:39 AM #26 CDR -1064 File Writer.cpp, Line 306
Invalid block address
10:11:39 AM #27 Text 0 File DVDR.cpp, Line 3857
EndDAO: Last written address was 831 (33Fh)
10:11:39 AM #28 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 4x (5,540 KB/s)
10:11:39 AM #29 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:11:43 AM #30 Text 0 File Cdrdrv.cpp, Line 11450
DriveLocker: UnLockVolume completed
10:11:43 AM #31 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
למישהו יש מושג מה הבעיה?
האם יש סיבה מיוחדת שאתה מנסה לצרוב במהירות 4 על דיסק
שהוא במהירות 16? אין שום סיבה שבעולם לעשות דבר כזה
עקרונית מקובל בדיסקים של DVD לצרוב מהירות אחת או שתיים
מתחת למקורית בשביל אקסטרה איכות של הצריבה (12 או 8 במקרה זה)
4 זה כבר הזוי ורחוק מאופטימלי
אני ממליץ לך דבר ראשון לעדכן את הקושחה לגרסה 1.22
http://files.rpc1.org/index.php?act=view&id=5586
(ודא שאתה עושה זאת כאשר אין דיסק בכונן)
לאחר מכן צרוב שוב (ובמהירות נורמלית^^ )
אם עדיין יכשל אז כנראה הצורב שלך לא אוהב תדיסקים האלה
יש כל מיני דברים שניתן לנסות בכדי לפתור את הבעיה. הרבה משתמשים נתקלו בבעיה הזו וכל אחד פתר את הבעיה בדרך אחרת, אך דבר אחד בטוח- זו בעיה תוכנתית לגמרי וככל הנראה בעניין בקר ה-SATA או בתאימות עם מערכת ההפעלה.
אז ההצעות הן, לפי סדר מהאופציה הכי קלה וקצרה לאופציה הכי משמעותית:
- עדכון דרייברים לבקר ה-SATA מהאתר של יצרנית הלוח.
- עדכונים לווינדוס.
- התקנת Repair למערכת ההפעלה.
עדכון קושחה לא יעזור לפני ניסיון של אנשים אחרים שחוו את הבעיה הזו.
תודה רבה על התגובות.
לגבי MEHIR, אני צורב על מהירות 4 כי היא הכי איכותית, אבל הארת את עיניי ומסתבר שאפשר לצרוב אף מהר יותר מבלי לפגוע באיכות, למרות שצרבתי במהירות זאת כבר עשרות רבות של דיסקים(לא רק על הצורב הזה).
אני שמח לשמוע שהבעיה היא תוכנתית בלבד, אבל לא התקנתי שום דבר מוזר לאחרונה לכן איני מבין מדוע בעיה זאת צצה פתאום.
יש לי לוח ASUS P5Q DELUXE, אני אמור פשוט להוריד דרייוורים חדשים ללוח כדי לעדכן את הSATA?
ואתה מבסס את זה על כמה מקרים בודדים?
אני לא מאמין שאתה דוחה נחרצות את הרעיון,גורם לי
לתהות אם אתה יודע איך הקושחה משפיעה על זיהוי
וצריבת דיסקים,לכל דיסק המיוצר על ידי יצרן דיסקים מסויים
יש קוד זיהוי (ואני מדבר על יצרני דיסקים אמיתיים כמו CMC/RITEK ולא
מותגים שהם מייצרים להם) ,הקוד זיהוי הזה יחודי לכל סדרה (לפי
יצרן/סוג הדיסק ומהירותו) בכל קושחה יש רשימה של קודי זיהוי/מהיריות ואסטרטגיות צריבה שונות לכל אחד
ולכן כאשר בנאדם מנסה לצרוב על דיסק שהקוד זיהוי שלו לא נתמך בקושחה
הצריבה תכשל ,אז אל תגיד לי שאין סיכוי שבעולם שזה קשור
- אמרתי "הרבה משתמשים". "הרבה" באופן יחסי לכלל השגיאות הנפוצות והשכיחות גם יחד. אפילו לא קרוב ל"מקרים בודדים".
- קורס ה-5 שניות על Media ID שלך היה קצת חובבני, אולי כדאי שתקרא על הנושא.
- לא אמרתי שאין סיכוי. לא דיברתי על הסיכויים של עדכון קושחה. סטטיסטית אולי מתוך כלל האנשים שנתקלו בבעיה אחד מהם פתר אותה ע"י עדכון קושחה ואולי זה רק ע"פ הדיווח שלו (הוא ניסה גם דברים אחרים ואחד מהם פתר את הבעיה.)
shevah, תעדכן קושחה בבקשה ותעדכן אותנו בנושא, לפני שאתה מנסה את הדברים האחרים.
מה בדיוק היה חובבני בו? דיברתי ישר ולעניין
ואני מאמין שאני בקיא בנושא מספיק טוב
וכמו שאומרים,כל מקרה לגופו
בקיצור, שמנו את האופציות על השולחן, שיהיה לו בהצלחה.
