America's Army 3 - הדיון הראשי
מישהו יכול לעזור לי לפתור את הבעיה כדי שאני אוכל לעדכן?
PLATFORM VERSION INFO
Windows : 5.1.2600.131072 (Win32NT)
Common Language Runtime : 2.0.50727.3053
System.Deployment.dll : 2.0.50727.3053 (netfxsp.050727-3000)
mscorwks.dll : 2.0.50727.3053 (netfxsp.050727-3000)
dfdll.dll : 2.0.50727.3053 (netfxsp.050727-3000)
dfshim.dll : 2.0.50727.3053 (netfxsp.050727-3000)
SOURCES
Deployment url : file:///C:/Documents%20and%20Settings/fogel.ARAGORN.000/Desktop/AA3Deploy.appref-ms%7C
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of C:\Documents and Settings\fogel.ARAGORN.000\Desktop\AA3Deploy.appref-ms| resulted in exception. Following failure messages were detected:
+ The referenced assembly is not installed on your system. (Exception from HRESULT: 0x800736B3)
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [04/07/2009 20:59:27] : Activation of C:\Documents and Settings\fogel.ARAGORN.000\Desktop\AA3Deploy.appref-ms| has started.
ERROR DETAILS
Following errors were detected during this operation.
* [04/07/2009 20:59:28] System.Runtime.InteropServices.COMException
- The referenced assembly is not installed on your system. (Exception from HRESULT: 0x800736B3)
- Source: System.Deployment
- Stack trace:
at System.Deployment.Internal.Isolation.IStore.GetAssemblyInformation(UInt32 Flags, IDefinitionIdentity DefinitionIdentity, Guid& riid)
at System.Deployment.Internal.Isolation.Store.GetAssemblyManifest(UInt32 Flags, IDefinitionIdentity DefinitionIdentity)
at System.Deployment.Application.ComponentStore.GetAssemblyManifest(DefinitionIdentity asmId)
at System.Deployment.Application.ComponentStore.GetSubscriptionStateInternal(DefinitionIdentity subId)
at System.Deployment.Application.SubscriptionStore.GetSubscriptionStateInternal(SubscriptionState subState)
at System.Deployment.Application.SubscriptionState.Validate()
at System.Deployment.Application.SubscriptionState.get_IsInstalled()
at System.Deployment.Application.ApplicationActivator.ProcessOrFollowShortcut(String shortcutFile, String& errorPageUrl, TempFile& deployFile)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
  • תגובות 430
  • צפיות 44.9k
דפלוי זה לא הקליינט הצולע עוד מAA2 שכל הזמן נדפק?
תשתמש בסטים
אכן כן זה זה, ואין לי כוח להשתמש בסטים.
יופי של פאץ' :-X
[attachment deleted by admin]
אוי תפסיק לקטר...
(אלא אם כן זה קורה כל פעם ואז אני חוזר בי :-X)
הורדתי את המשחק מחדש, ועכשיו עם העדכון האחרון באמת זה עובד ואפשר להתחבר לשרתים (הללויה!).
הבעיה שהמשחק כבד בטירוף, למרות שהגרפיקה עצמה מכוערת בטירוף ומזכירה לי משחקים מלפני 10 שנים, זה עדיין מאוד מקרטע עד שאי אפשר לשחק ככה (לא טרחתי למדוד FRAPS, זה פשוט כבד). זה קורה גם אצלכם?
אוי תפסיק לקטר...
בוא נראה,
העלתי את המשחק, נכנסתי לאימון המשחק נתקע.
העלתי אותו שוב נכנסתי לאימון עברתי אותו על 93% אבל התברר לי שאני כישלון גדול, רציתי לצאת מהאימון-נתקע.
העלתי אותו בשלישית ונכנסתי ישר למולטי, השרת הראשון שנכנסתי אליו-נתקע.
מספיק להיום עם המשחק הזה....
וואי, לא חוויה נעימה...
מעניין כמה פאטצ'ים הם יוסיפו עד שזה יהיה שחיק...
וכן, זה משום מה מרגיש מאוד כבד על המערכת (אפילו אצלי) ושלא לדבר על זה שAA לא עובד אלא אם זה דרך הדרייבר וזה מחרבש
את הHUD...
בוא נראה,
חוזר בי.
בוא נראה,
העלתי אותו שוב נכנסתי לאימון עברתי אותו על 93% אבל התברר לי שאני כישלון גדול, רציתי לצאת מהאימון-נתקע...
וכל זה אחרי הפאטצ' החדש?
למשחק יש עדיין חמולה שלמה של בעיות...
אבל אם הצוות הנוכחי יפתור את כולן GSC יהיו חייבים לקנות אותו
  • 2 שבועות מאוחר יותר...
יש עידכון חדש :
America's Army 3
More messaging when unable to connect to server for particular circumstances like full servers, etc
More enhancements to PunkBuster implementation
Adds in switching viewpoints during pb validation and adds in messaging to let player know something is happening
Streamlined the server connect
Adjusted the ftmp cleanup logic so it works properly on the server
New Auth SDK that fixes MBS query issues, several crashes, and memory leaks
Better feedback to players kicked from training due to not being qualified
Fixes to player count in Internet Browser
Fix for hud decrementing frag grenade round display when 320 ammo types are switched
Frag grenade loadout fixes
Cleanup of client stat file on startup so bad stats won't hang players joining training
Removes "player didn't play in round" debugging message from logs
Fixes accessed nones caused by mission lost statistics when player isn't alive at end of round
Adjustments to clan tag support to allow use of a prefix (+ is add it as a suffix, - add as prefix, and anything else uses the "of xxx" format from 3.0.4)
Prevent going prone while tossing a grenade
Report full server to user message and bad/wrong password to user in message box after being kicked from server
Adds in ability to left click on a server in MBS and have its information updated if it hasn't been updated recently (in last 10 minutes)
Adds new message box if the connection times-out so user knows what happens if they step away and the client fails to connect to the server
Added pbsetup and a simple batch wrapper to call necessary commands to setup a system for using PB (Binaries\pbsetup_help.bat)
Added PunkBuster setup steps to installation
אני האמת משחק קצת ואני מקווה שהם תיקנו פה את רב הבעיות (ולא חסר)
וויתרתי עליו. תודיעו כשיש טעם לנסות שוב.
וואלה אפשר לשחק, יש עוד פה ושם אבל המשחק עצמו עובד וסבבה...
אתם יודעים מה הכי מסריח? שבמשחקים של פאנק באסטר, החרא הזה ירוץ כל הזמן גם שלא משחקים
ואם מבטלים פתאום המשחק יום אחד יעשה בעיות
מה, קשה להם לעשות משהו יעיל כמו VAC?
