הצורב לא מצליח לצרוב DVD ?R DL
שלום לכולם, להלן לוג הבעיה:
1K22-0867-0795-66M4-5090-2688-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.3.2.1
Internal Version: 8, 3, 2, 1
Recorder: <Optiarc DVD RW AD-7170A> Version: 1.05 - HA 1 TA 0 - 8.3.2.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <Optiarc DVD RW AD-7170A >Version: 1.05 - HA 1 TA 0 - 8.3.2.1
=== Scsi-Device-Map ===
CdRomPeripheral : Optiarc DVD RW AD-7170A atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1600AAJS-00PSA0 atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
Optiarc DVD RW AD-7170A E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2096620kB)
Free physical memory: 1194MB (1223496kB)
Memory in use : 41 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
28.4.2009
Burn DVD Image
10:16:56 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
10:16:56 #2 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
10:16:56 #3 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 4084799 (907:43.74, 7978MB)
10:16:56 #4 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
10:16:56 #5 Text 0 File DlgWaitCD.cpp, Line 2932
Recorder: Optiarc DVD RW AD-7170A, Media type: DVD+R DL
Disc Manufacturer ID: <CMC MAG>, Media Type ID: <D03>, Product revision number: 64
Disc Application Code: 0, Extended Information Indicators: 3
10:16:56 #6 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
10:16:56 #7 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 4084800 (4084800) = #4084800/907:44.0
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4084800 blocks [E: Optiarc DVD RW AD-7170A]
10:16:56 #8 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [E: Optiarc DVD RW AD-7170A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8365670400, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 4084800 | 4084800 | 0x00
4084800 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:16:56 #9 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
10:16:56 #10 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
10:16:56 #11 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
10:16:56 #12 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
10:16:56 #13 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
10:16:56 #14 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11,080 KB/s)
10:16:56 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
10:16:57 #16 Text 0 File DVDPlusDualLayer.cpp, Line 580
Disc finalized, LBA total Image size: 4084800 (7978MB), Last LBA L0: 2042399 (3989MB)
10:18:21 #17 SPTI -1066 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAD 00 00 00 00 00 00 21 08 04 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 C0 00 07
Buffer x0790d640: Len x804
10:18:21 #18 Text 0 File DVDPlusDualLayer.cpp, Line 745
L0 Data Zone Capacity set to 2042400 (1F2A20h, 3989MB) -> OK, confirmed setting
10:18:21 #19 CDR -1205 File DVDPlusDualLayer.cpp, Line 772
Burning Layer 1
10:18:21 #20 Text 0 File DVDPlusDualLayer.cpp, Line 782
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
10:18:21 #21 Text 0 File Cdrdrv.cpp, Line 10164
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-ROM (0), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: FCFFFF h
End Physical Sector Number in Layer 0: 22D7FF h (LBN: 1FD7FF h, 4075 MB)
Data in Burst Cutting Area (BCA) does not exist
Twin Format Flag: 0
Media Specific [16..783]:
00 00 03 43 4D 43 20 4D - 41 47 00 44 30 33 40 40 ...CMC.MAG.D03@@
25 25 37 10 00 2C 6C 00 - 2C 6C 20 1F 0C 0C 14 14 %%7..,l.,l......
02 01 01 20 00 20 1F 0C - 0C 14 14 02 01 01 20 00 ................
04 00 33 7B 5C 00 25 69 - 3A 26 1C 0A 0B 20 02 01 ..3{\.%i:&......
01 00 00 58 62 42 26 1C - 0A 0B 20 02 01 01 00 5F ...XbB&........_
84 00 00 43 66 3E 26 1C - 0A 0B 20 02 01 01 00 00 ...Cf>&.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
E1 0F 32 10 00 03 00 00 - 00 FC FF FF 00 22 D7 FF ..2.........."..
25 25 37 15 00 2D 6D 00 - 2D 6D 19 19 0C 0B 0E 0E %%7..-m.-m......
00 00 00 10 00 19 19 0C - 0B 0E 0E 00 00 00 10 00 ................
04 00 33 7B 5C 00 2C 6D - 4B 19 10 05 04 10 00 00 ..3{\.,mK.......
00 00 00 55 65 3B 24 16 - 09 08 20 00 00 00 00 26 ...Ue;$........&
84 00 00 42 67 2F 24 16 - 09 08 20 00 00 00 00 00 ...Bg/$.........
10:18:21 #22 Text 0 File DVDR.cpp, Line 6901
Drive: Optiarc DVD RW AD-7170A
Book Type request [NEC]: DVD-ROM, write to RAM
select Book Type setting from RAM
Changing the Book Type was finished successfully, return code 0
10:18:21 #23 CDR -1207 File DVDR.cpp, Line 6605
Book Type automatically set to: DVD-ROM
10:18:21 #24 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
10:18:21 #25 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
10:18:33 #26 SPTI -1135 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
CDB Data: 0x2A 00 00 00 3B 40 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x0a0976c0: Len x10000
0x00 00 01 BA 44 02 6C 96 DD 03 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 00 00 00 00 00 00 00 00 00
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10:18:33 #27 CDR -1135 File Writer.cpp, Line 306
Write error
10:18:33 #28 SPTI -1135 File SCSIPassThrough.cpp, Line 196
CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00
Sense Code: 0x0C
Sense Qual: 0x00
10:18:33 #29 SPTI -1176 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176)
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
Sense Code: 0x72
Sense Qual: 0x03
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 72 03
10:18:33 #30 Phase 127 File dlgbrnst.cpp, Line 1767
Generating DVD high compatibility borders
10:18:33 #31 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 15168
10:18:33 #32 Text 0 File DVDR.cpp, Line 6901
10:18:33 #33 CDR -1176 File WriterStatus.cpp, Line 292
Session fixation error
10:18:33 #34 TRANSFER -24 File WriterStatus.cpp, Line 292
Could not perform end of Disc-at-once
10:18:33 #35 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11,080 KB/s)
10:18:33 #36 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:18:37 #37 Text 0 File Cdrdrv.cpp, Line 11420
DriveLocker: UnLockVolume completed
10:18:37 #38 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
אני מקווה שראית שהצורב תומך רק בדיסק דו שיכבתי מינוס ולא תומך בפלוס.
תעדכן את הקושחה של הצורב ותתקין גירסה עדכנית של נרו.
  • 1 חודש מאוחר יותר...
עידכנתי את הקושחה, אבל זה לא עזר. אולי באמת זה התמיכה במינוס ולא פלוס.
