Empire: Total War - הדיון הראשי
header.jpg?t=1236254526
מפתחת: Creative Assembly
ז'אנר: אסטרטגיה תורות, לחימה בזמן אמת
האתר הרשמי: http://www.totalwar.com/empire/
ניתן להתרשם מהDEMO כאן: http://www.totalwar.com/empire/demo/
סקירה בעיברית:
http://gamer.nana10.co.il/Article/?ArticleID=616715
Synopsis: Command the seas, control the land, forge a new nation, and conquer the globe. Empire: Total War takes the Total War franchise to the eighteenth century Age of Enlightenment -- a time of political upheaval, military advancements, and radical thought, captured in stunning detail in Empire: Total War.
Empire: Total War introduces a host of revolutionary new features, including true 3D naval combat. For the first time in the Total War series, you will be able to intuitively command single ships or vast fleets upon seascapes rich with extraordinary water and weather effects that play a huge role in your eventual glorious success or ignominious defeat. After pummelling your enemy with cannon fire, close in to grapple their ship and prepare to board, taking control of your men as they fight hand-to-hand on the decks of these wooden behemoths.
In addition, Empire: Total War will see further enhancements to the Total War series signature 3D battles and turn-based campaign map. Real-time battles will pose new challenges with the addition of cannon and musket, challenging players to master new formations and tactics as a result of the increasing role of gunpowder within warfare. And the Campaign Map -- for many, the heart of Total War -- introduces a variety of new and upgraded elements, including new systems for Trade, Diplomacy and Espionage with agents; a refined and streamlined UI; improved Advisors; and a vastly extended scope, taking in the riches of India, the turbulence of Europe and, for the first time, the untapped potential of the United States of America.
טריליר יציאה של המשחק: http://www.gametrailers.com/player/46261.html]
סקירות קצרות של המשחק עלידי המפתחים:
קרבות ימים - http://www.gametrailers.com/player/38337.html
קרבות יבשה - http://www.gametrailers.com/player/40753.html
הקמפיגן - http://www.gametrailers.com/player/41950.html
הדרך לעצמאות - http://www.gametrailers.com/player/43831.html
מצב משחק - רב משתתפים - http://www.gametrailers.com/player/44441.html
Screen shots:
דרישות מערכת:
o Supported OS: Windows® XP Service Pack 2 or Windows Vista
o Processor: 2.4 GHz Intel® Pentium® or greater or AMD® Athlon® equivalent CPU
o Memory: 1 GB RAM (XP,) 2 GB RAM (Vista)
o Graphics: 100% DirectX 9.0c compatible hardware accelerated video card with shader version 2.0 support, 256 MB video memory
o Display: Minimum screen resolution of 1024 x 768 pixels
o Sound: Directx9.0c compatible sound card
o Hard Drive: 2.2 GB free hard disk space
o Peripherals: Windows compatible mouse and keyboard
עריכה:
קישור לפורום של קהילת מודרים ל ETW מוצלח.
http://www.twcenter.net/forums/forumdisplay.php?f=1075
  • תגובות 201
  • צפיות 23.5k
תוכל להתרשם מהדמו כאן:
http://store.steampowered.com/app/10620/
תערוך בבקשה את כותרת הדיון, אתה לא בצ'ט קבוצתי
עורך...
עריכה: ערכתי, עכשיו מותר ליל שאול מה אתם לעזזאל חושבים על המשחק?!!?!?!?!?!?
זה לא משנה אם הוא עלה לרשת או לא. משחקים טובים ייקנו גם אם הם ידלפו שבוע לפני ההשקה הרשמית.
אני אישית קניתי אותו דרך סטים, אחרי ששיחקתי בדמו.
למדתי לא לקנות משחקים לפני שאני מנסה אותם.. (אהמ, FEAR2).
ניסיתי לשחק בדמו אבל זמני הטעינה המגוחכים לחלוטין חסמו כל ניסיון שלי לבדוק את המשחק הזה....
אני קיבלתי את הרושם שהמשחק לא אמור להיות יותר כבד באופן משמעותי מקודמו, אתה יכול לפרט?
מה יש לפרט?
פותחים את המשחק-נשאר תקוע במסך הראשון וצריך לחכות איזה 10 דקות שיועיל בטובו להגיע לתפריט הראשי
הולכים להגדרות ומורידים אותם למינימום- מחכים 20 דקות עד שהמשחק חוזר לתפריט הראשי
מתחילים משימה-מחכים 30 דקות+ (וויתרתי)
כנראה 1GB זיכרון זה מעט מדי בשבילו.
כן למשהו זמני הטעינה בדמו מגוחחים להחריד. אני זוכר שבROME TOTAL WAR הזמן טעינה היה סביל (ועוד הייתי על מערכת יחסית חלשה).
אני מתאר לעצמי שהם רק כאלה בדמו. שיחקתי בוא טיפה , הפסדתי בשני הקרבות... די נהנתי , את הקרב הראשון והרגיל אני מכיר והוא היה נחמד (אין כמו לפרוס יחידה אחת על שורה אחת ולראות אנשים שרצים עליך מתים :) )
גם מהקרב הימי יחסית נהנתי למרות ששוב הפסדתי.
לדניס, גם ה 4 שלי לא עשו טוב לזמני הטעינה. כמה דקות לכול קרב? מוגזם לטעמי.
חוץ מזה למשהו הייתי צריך לשחק מלא עם ההגדרות גראפיקה כדי שכול ה UI לא יהבהב לי.
אני יכול רק לנחש שמדובר במשחק שאוכל את הזיכרון הגרפי וצריך לפחות ג'יגה של כזה כדי לעשות קולות של "בסדר"..
יש לי 4
אני לא מבין איך אתם מתלוננים לפני ששיחקתם במשחק המלא :\
זמני הטעינה של הדמו היו סביבות ה 30 שניות אצלי, מה שמשתווה לזמני הטעינה של GTA או קרייסיס, למשל.
כנ"ל אצלי.. הזמני טעינה לא כאלה נוראיים. בסביבות ה 20-30 שניות.
משחק מדהים ביופיו...
אני משחק עכשיו CAMPAIGN של כל העולם ( אירופה, אסיה נראה לי ואמריקה)
ישבתי על המשחק כבר איזה 10 שעות
אחד המשחקים הכי יפים שיש, באמת.
יש לי 2 גיגה זיכרון, זמניי הטעינה טיפה גבוהים מהרגיל אבל אפשר להתרגל... אני משחק על ULTRA HIGH עם הHD4850 שלי.
יש טיפה לאגים בקרבות ובזמן שאני מסיים את התור שלי וכל שאר המעצמות משחקות את תורן...
חוצמזה, משחק פצצתי.
אה.. כמובן... הורדתי אותו =p
זה לא אישי או משהו, פשוט יש לי מין סדר עדיפויות, קודם לחסוך לקניית חלקיי מחשב, אח"כ לחשוב על קניית משחקים. ואם הייתי קונה את המשחק הייתי צריך לחכות עוד חודש עד להזמנה של ה 4גיגה זיכרון וAMD 7750BE :silly:
נ.ב
אני על VISTA אז אולי זה משתמש בDX10? כי הגראפיקה מעולה :yelclap:
