ניסיתי כמעט הכל ועדיין לא הצלחתי למצוא את המקור לריסטרטים של המחשב באמצע משחקים
טוב נתחיל ממידע לגבי המערכת, מחשב חדש לפני שלוש חודש
Computer:
Operating System Microsoft Windows XP Professional
OS Service Pack Service Pack 3
DirectX 4.10.0.5512 (DirectX 10)
Award BIOS Type Award Modular BIOS v6.00PG
Award BIOS Message GIGABYTE GA-EP45-DS5 F5
DMI BIOS Version F5
GIGABYTE 4850 GV-R484ZL-512H
450W EZCOOL
2GB KIT DDR2 800MZ CORSAIR
Q6600 @ 2.4GHZ
320GB SATA 2 WD
SYSTEM SUMMARY
Windows XP Professional Service Pack 3 build 2600 (32-bit),
1 x Intel® Core2 Quad CPU Q6600 @ 2.40GHz,
2.0GB RAM,
ATI Radeon HD 4850,
298GB HDD,
DVD-RW, CD/DVD,
GENERAL
System Name: SIMON1
Motherboard Manufacturer: Gigabyte Technology Co., Ltd.
Motherboard Name: EP45-DS5
Motherboard Version: x.x
BIOS Manufacturer: Award Software International, Inc.
BIOS Version: F5
BIOS Release Date: 06/03/2008
CPU
CPU manufacturer: GenuineIntel
CPU Type: Intel® Core2 Quad CPU Q6600 @ 2.40GHz
Codename: Kentsfield
CPUID: Family 6, Model F, Stepping B, Revision G0
Socket: LGA775
Lithography: 65nm
Physical CPU's: 1
Cores per CPU: 4
Hyperthreading: Not capable
CPU features: MMX SSE SSE2 SSE3 SSSE3 DEP PAE Intel64 VMX
Clock frequencies:
Measured CPU speed: 2070.6 MHz
Multiplier: x8.0
Scalable Bus Speed: 266.0 MHz
Front Side Bus: 1066.0 MHz
Cache per CPU package:
L1 Instruction Cache: 4 x 32 KB
L1 Data Cache: 4 x 32 KB
L2 Cache: 2 x 4096 KB
MEMORY
Total Physical Memory: 2046MB
Available Physical Memory: 1488MB
Memory devices:
A0:
- 1024MB, 800MHz,
- Serial number:
A1:
- Not populated
A2:
- 1024MB, 800MHz,
- Serial number:
A3:
- Not populated
Virtual memory: C:\pagefile.sys (allocated base size 2046MB)
GRAPHICS
ATI Radeon HD 4850
Chip Type: ATI Radeon Graphics Processor (0x9442)
DAC Type: Internal DAC(400MHz)
Memory: 512MB
BIOS: 113-AB70101-101-GB
Driver provider: ATI Technologies Inc.
Driver version: 8.582.0.0
Driver date: 2-3-2009
Monitor 1: 1440x900x32 60Hz (Primary monitor)
DISK VOLUMES
C: Local drive, NTFS, (298.08GB total, 243.87GB free)
DISK DRIVES
Disk drive: Model WDC WD3200AAKS-00B3A0 (Size: 298.09GB)
OPTICAL DRIVES
PIONEER DVD-RW DVR-215D
הבעיה:
באמצע GTA 4 ו DEVIL MAY CRY 4 בלי שום התראה המחשב עושה ריסטרט. לרוב זה קורה אחרי 5-10 דקות משחק לפעמים אפילו לפני
ניסיונות לאיתור תקלה:
בהתחלה חשבתי זה הדרייברים, היה לי את הדרייברים המקוריים עם הדיסק של הכרטיס מסך ו DX9
התקנתי דרייברים מהאתר של ATI לא עזר
התקנתי דרייברים מהאתר של GIGABYTE לא עזר
לפני כמה ימים יצאו באתר של ATI דרייברים עוד יותר עדכניים וגם לא עזר
התקנתי DX10 לא עזר.
אז חשבתי שאולי זה בעית חומרה \ התחממות.
METEST86+ אחרי חצי שעה ושני טסטים מוצלחים אמרתי חלאס זה לא הזיכרון.
BURN IN 2008 אחרי 12 טסטים (למעבד) שזה בערך רבע שעה אין תקלות אמרתי חלאס.
HOT CPU TESTER PRO 4 LITE EDITION (מעבד + לוח אם) גם אחרי רבע שעה שום בעיות (חום לוח אם הגיע ל 50 מעלות מקסימום)
rthdribl שזה
DX9 Real-Time High-Dynamic Range Image-Based Lighting
אחרי רבע שעה שאני משחק עם כל ההגדרות והאפשרויות חום הכרטיס מסך לא עולה על 50 מעלות וכשאני משחק זה מגיע למקסימום 44
אז נראה שהזיכרון תקין והלוח אם תקין והמעבד תקין והם לא מתחממים יתר על המידה.
אני די אובד עצות כי עם משחקים אחרים אין שום בעיה ואם אני אקח אותו לבדיקה בחנות הם יגידו לי שהכל בסדר כי על הנייר הכל נראה תקין
שלחתי אימייל ל GIGABYTE והם אמרו גם שנראה להם שהכל תקין.
בקיצור אם יש למישהו רעיון מה הבעיה או עוד תוכנות שאני יכול להריץ כדי לנסות למצוא את מקור הבעיה אני אשמח לשמוע.
חדשות רעות... הבעיה בנתיים רק החמירה ריסטרט אחרי פחות מדקת משחק
והעכשיו זה גם קורה ב SHELLSHOCK 2
ולפני זה הוא עבד לי חלק ללא בעיות
באמת שאני נואש כי לא יודע מה הבעיה בוינדוס אין שום סימן שהיה BSOD
סריקת וירוסים ורוגלות עשיתה?
כנראה שלא בדקת טוב. הכרטיס אמור להתחמם ב-3D ככה הוא בנוי.
אתה צריך להפסיק את האופציה לריסטארט (בסיסטם) ולראות אם יש הודעה ומה רשום שם.
