memory stability program
Does anybody know a program that check the stability of the memory dimms?
because I got some new dimms and I started getting blue screens and I don't know which one is faulty.
Memtest86
install it on a boot disk,
everytime you boot, boot with 1 stick only and run the test.
thanks man...
ok, when I try each at a time, they all pass but when I put them all at once they fail, so I assume it's a mobo problem. anybody heard about that problem with the MSI KT3 Ultra?
another weird thing is that my new Golden Dragon PC3500 256x2 Dual Pack 2 6/3/3 1T can't work at 333Mhz @ 2 5/2/2 1T. weird...
btw, my other dimm is Samsung 256Mb PC2700 2.5 tested at 350Mhz 2 5/2/3 1T w/ fast command at default voltage
בדיוק כמו שב KT400 אי אפשר לשים יותר מסטיק או שניים של DDR400 גם ב KT333 יש הגבלות כאלו.
אם תפעיל את הסטיקים ביחד ב 266 מה"ז זה צריך להיות בסדר.
אם אתה מתעקש להפעיל אותם ב 333 תנסה לבטל את 1T command ואולי להוסיף להם קצת מתח.
I thought I've read somewhere in the motherboard menual about it, but I lost it and couldn't find it on MSI's website. the problem is that I tried all of them on 266Mhz and it still didn't work. I'll try it again when I'll come back home in 2 weeks.
**writen not from my home**
