הדיון הראשי על הדרייבר - AMD Catalyst (שוחרר 12.08)
זה רק מוסיף תמיכה בכרטיסים החדשים.
  • תגובות 2.4k
  • צפיות 360k
אפילו פה אין מלה על ה290..... אמא שלהם....
  • 3 שבועות מאוחר יותר...
דרייבר בטא חדש 13.11 BETA 6, כולל את כל המרכיבים של 13.11 עם תמיכה בכרטיסים החדשים ובווינדוס 8.1:
http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx
http://www.techpowerup.com/193241/amd-releases-the-catalyst-13-11-beta6-driver.html
http://www.guru3d.com/files_details/amd_catalyst_13_11_beta6_(13_250_18_october_24)_download.html
  • Feature Highlights of The AMD Catalyst 13.11 Beta​​6 Driver for Windows
    • Includes all Feature Highlights of AMD Catalyst 13.11 Beta
    • Includes support for the new prod​ucts:
      • AMD Radeon​™ R9 290X
      • AMD Radeon R9 290
      [*]​Performance improvements
      • ​Batman: Arkham Origins - improves performance up to 35% with MSAA 8x enabled
      • Total War™: Rome 2 - improves performance up to 10%
      • Battlefield 3 - improves performance up to 10%
      • GRID 2 - improves performance up to 8.5%
      • DiRT Showdown - improves performance up to 10%
      • Formula 1™ 2013 - improves performance up to 8%
      • DiRT 3 - improves performance up to 7%
      • Sleeping Dogs - improves performance up to 5%
      [*]​Automatic AMD Eyefinity Configuration​
      [*]Automatic "plug and play" configuration of supported Ultra HD/4K tiled displays
    Feature Highlights of The AMD Catalyst 13.11 Beta Driver for Windows
    • ​Includes support for the new products:​
      • AMD Radeon™ R9 280X
      • AMD Radeon R9 270X
      • AMD Radeon R7 260X
      • AMD Radeon R7 250
      • AMD Radeon R7 240
      [*]Performance improvements for the AMD Radeon HD 7000 Series in the following games:
      • ​Total War™: Rome 2 - improves performance up to 10%
      • Splinter Cell® Blacklist™ - improves performance up to 7% on single GPU and AMD CrossFire™ configurations
      • The Elder Scrolls V: Skyrim® - improves performance up to 9%
Compatible Operating Systems
The AMD Catalyst 13.11 Beta Driver for Windows is designed to support the following Microsoft Windows platforms:
  • Windows 8.1 (32 & 64-bit version)
  • Windows 8 (32 & 64-bit version)
  • Windows 7 (32 & 64-bit version with SP1 or higher)
  • 2 שבועות מאוחר יותר...
נערך על-ידי rroonnii
אין דיבור על Raptr ??
זאת התשובה של AMD ל geforce experience ?
אם אתה אומר לי ש-AMD מנסים לכתוב תוכנה כזאת כנגד ה-0 NVIDIA אקפריאנס עשית לי את היום !
יוו גדול נכנסתי לקישור שצירפת, זה רשמי ? אפשר להוריד את זה וזה עובד טוב ?
raptr חברה עצמאית, לפני כמה זמן הם הודיעו על שיתוף פעולה עם AMD. יש לתוכנה הזו הרבה אפשרויות מאוד נחמדות כמו:
1. ריכוז של כל החברים שלכם מ STEAM/PSN/XBL/חברים שהוספתם דרך התוכנה ועוד + CHAT וכו'.
2. למי שיש כרטיס מסך של AMD יש אפשרות להתאים את הביצועים של המשחק בצורה ממש נוחה דרך התוכנה (היא תבחר את ההגדרות המתאימות ביותר בהתאם לחומרה שלהם).
3. התוכנה מרכזת את ה achievements שלכם מכל החשבונות שמקושרים.
לא יודע אם זה ברמה של מה ש NVIDIA מפתחים (ושוב רוב האפשרויות של RAPTR יעבדו גם עם כרטיסי מסך של NVIDIA) אבל התוכנה עצמה מאוד נחמדה והתוספות של AMD מצויינות.
ניסיתי להוריד את התוכנה עד שהיא ירדה לקח שעה, עכשיו להתקין אותה זה גם סיפור, יש איזו הודעת שגיאה איך שההתקנה מתחילה שאומרת שאולי יש לי פורטים חסומים,. על מה מדובר והאם אתה מכיר את הבעיה הזאת ופתרון שלה ?
כרגע היא מותקנת עם הדרייבר. האם מומלץ להשתמש איתה או שעדיף לבטל אותה?
סוף סוף לגבי COD GHOSTS. המשחק אצלי נתקע למרות שיש 60FPS...מקווה שהדרייבר BETA החדש יתקן את העניין (מערך CF).
דרייבר חדש מבית AMD 13.11-9.4 BETA:
כולל את השיפורים הבאים:
Feature Highlights of The AMD Catalyst 13.11 Beta9.4 Driver for Windows
Includes all Feature Highlights of The AMD Catalyst 13.11 Beta9.2 Driver
May resolve intermittent black screens or display loss observed on some AMD Radeon™ R9 290X and AMD Radeon R9 290 graphics cards
Improves AMD CrossFire™ scaling in the multi-player portion of Call of Duty®: Ghosts
AMD Enduro Technology Profile updates:
​XCOM:​ Enemy Unknown
Need for Speed Rivals
  • 10 חודשים מאוחר יותר...
התקנתי את הדרייבר העדכני שמתאים לכרטיס שלי (6950) - 14.9. ביצעתי התקנה נקייה, כולל הסרה של כל השאריות ב-safe mode לפני ההתקנה.
הבעיה: אני פותח את CCC והולך לחלון שמראה את נתוני ה-software (ביצעתי זאת כדי לוודא שהגרסה החדשה הותקנה כראוי). כאשר אני סוגר את החלון (קליק על ה-X) במטרה ש-CCC יוקטן בחזרה לשורת המשימות, אני מקבל הודעת שגיאה מווינדוס שהיישום נעצר/נסגר. ובאמת CCC נסגר וכבר לא מופיע בטריי.
מישהו מכיר או יכול לעזור?
