פורסם 2011 במרץ 1115 שנים Project Mjölnir is a multidimensional effort aimed at increasing performance and providing improved stability of the AMD Catalyst software.The AMD Catalyst 11.4 early preview, code named Mjölnir I, already available to the public (link) with Mjölnir II and III to be available in the months to come. This driver encompasses major improvements for the entire AMD Radeon HD 6800 and 6900 Series. Users should see a boost, particularly with anti-aliasing and large resolutions in numerous titles: Up to 70% performance improvement in Civilization V Up to 49% performance improvement in Call of Duty: Black Ops Up to 23% performance improvement in F1 2010 Up to 21% performance improvement in Wolfenstein MP Up to 15% performance improvement in Tom Clancy’s H.A.W.X Up to 17% performance improvement in S.T.A.L.K.E.R.: Call of Pripyat Up to 28% performance improvement in Metro2033 Up to 33% performance improvement in Left 4 Dead 2 Up to 26% performance improvement in FarCry 2 Up to 15% performance improvement in Crysis Warhead Up to 50% performance improvement in Unigine Heaven Up to 22% performance improvement in Batman: Arkham Asylum Up to 19% performance improvement in Aliens vs. PredatorBut the goodness does not stop with this release. Mjölnir I is only the first in a series of drivers we intend to release this year, all of which should provide big performance boosts. לקוח מכאן, http://www.rage3d.com/index.php?cat=75#newsid33974865
פורסם 2011 במרץ 1115 שנים לקוח מאותה ההודעה:EDIT - To clarify, the performance increases indicated are not against Catalyst 11.2 but an earlier version of the Catalyst drivers, available before the launch of the AMD Radeon Hd 6800. Which would change the performance increases from 'woot' to 'tell me something I don't know'./EDIT
פורסם 2011 במרץ 1315 שנים CATALYST 11.2 VS 11.4עם 6950http://www.overclock.net/ati-drivers-overclocking-software/962554-catalyst-11-2-vs-11-4-a.htmlעם 5870http://www.overclock.net/12707804-post31.html
פורסם 2011 במרץ 1315 שנים לפי הדיבורים צפוי עוד שיפורים בהמשך... נראה... אני בכל מקרה עם הבטא המדובר, אין לי שום בעיות איתו והביצועים טובים יותר בכל מה שבדקתי...
פורסם 2011 במרץ 1315 שנים אני עם זוג 6950@70, אתה לא "מרגיש" הבדלים... אבל כשאתה בודק קצב FPS הוא גבוהה יותר בצורה ברורה...הרצתי כמה בדיקות עם FRAPS, יצאו בחלק מהדברים טובים בצורה משמעותית...אצלי ההבדל ( מבחינת אחוזים ) קצת גדול יותר ב CF מאשר בכרטיס יחיד, כניראה שגם בזה טיפלו קצת...לינק לדרייבר המדובר,http://support.amd.com/us/kbarticles/Pages/Catalyst114earlypreview.aspx
פורסם 2011 במרץ 1315 שנים פעם אחת הכרטיס שלי התחמם יותר מדי (של NVIDIA) כאשר השתמשתי בבטא.. מאז אני מעדיף לא לקחת סיכונים. :-\תודה רבה בכל אופן, מחכה כבר ליציאה הרישמית.
פורסם 2011 במרץ 1315 שנים הבעיה שאתה מתאר הייתה קיימת בדרייבר אחד בודד של NV בנוסף בדקתי את הדרייבר הזה ואין בעיות... אתה מוזמן לנסות ומקסימום להחזיר
פורסם 2011 במרץ 1315 שנים אני לא רואה שמזכירים שום שיפורים בדרייבר לסדרות ישנות יותר כמו HD4000. האם הוא משפר משהו או שלא?(לי יש 4730).
פורסם 2011 במרץ 1415 שנים התקנתי את הדמו (HD 6950)שיפור ביצועים ב 3DMARK11מ P4877ל P4956 +- (הכרטיס לא פתוח ל 6970 )כ - 7 עד 10 FPS יותר במשחקים שונים ....
פורסם 2011 במרץ 1615 שנים אני פשוט לא מאמין... זה אמיתי? כל הדריברים החדשים האלו פשוט חירבו לי הכל. עכשיו גם ה- VISUAL STUDIO גורם לדריבר של הכרטיס מסך לקרוס כשמופעל AA. פוטושופ עולה ולא מסוגל להציג תמונות וקורס לאחר כמה שניות. אני חוזר ל-10.10e.
פורסם 2011 במרץ 1815 שנים AMD Catalyst 11.4 RC2 (March 9/11) Win7 x86/x64If you have the 11.4 Preview drivers installed you must remove them before installing these.Win7/Vista x86/x64, http://www.megaupload.com/?d=0KBLP1B0Win7/Vista Mobility x86/x64, http://www.mediafire.com/?6gtuq9d3tgb99aoWinXP x86/x64, http://www.mediafire.com/?y597ajmc7fdfmik
