מבקש עזרה בניתוח קובץ DUMP..
בעקבות מסך שחור שמפסיק פעולת מחשב, מסך כחול שקרה בעבר, ומינדאמפ שנוצר, אני מבקש עזרה בניתוח הקובץ(השתדלתי לעבוד לפי ההוראות בסטיקי,מקווה שזה בסדר):
Microsoft ® Windows Debugger Version 6.10.0003.233 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini010909-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: D:\6d5228fb2dd71211e1b5f459d0bd\symbols.exe
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720
Debug session time: Fri Jan 9 14:14:42.640 2009 (GMT+2)
System Uptime: 1 days 6:13:15.354
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image ati2dvag.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ati2dvag.dll
*** ERROR: Module load completed but symbols could not be loaded for ati2dvag.dll
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, bf039614, a9d52328, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ati2dvag.dll ( ati2dvag+27614 )
Followup: MachineOwner
מה בעצם נאמר בניתוח פה, מה יכולה להיות בעיה?
תודה מראש.
תודה רבה..
ניסיתי מה שהציעו, נקווה יעזור.. :)
תעדכן אם זה עזר
טוב, לא עזר..
היה ריסט פתאומי, שבמהלכו הופיע מסך כחול שנעלם, ואז התבצע ריסט..
וכל זה במהלך טעינת דף בגוגל..
שאלה נוספת (אולי זה גם משפיע),
למישהו יש מושג באיזה התקן יכול להיות מדובר בתמונה המצורפת:
http://img525.imageshack.us/my.php?image=69092047jh2.jpg
יכול להיות שזה יוצר את הבעיה..?
תודה מראש.
תעשה נקודת שחזור מערכת
תיכנס ל"הוספה או הסרה של תוכניות"
תמצא את microsoft visual c++ redistributable
ותסיר את כולם
תאתחל את המחשב
תוריד את
מפה: http://www.microsoft.com/downloads/details.aspx?FamilyId=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en
ותתקין
