problem|dg45id doesnt work with e6600
i won the motherboard yesterday at the vgames lan *yay* and i tried using it with E6600 proccesor and i know that this should work but it didnt
then i tried only with one DIM of ram 800Mhz kingstong 1G
and it didnt work either
you can answer in hebrew its just that my windows is fucked up
thanks
