בדיקה מקיפה של xbitlabs למשחות תרמיות
יש כל כך הרבה משתנים בעניין המשחות התרמיות שהופכים את ההשוואה ביניהן לכמעט בלתי אפשרית.
There are so many variables a direct comparison is virtually impossible for accurate results. Differences in cure times, thermal sensors, optimal amounts of the compound, current ambient temperature, pressure of the heatsink on the CPU, etc. Then these review sites have the nerve of measuring to the tenth of a degree.
Edit:
How evenly the compound spread over the surface, did the surfaces get washed sufficiently between trials, do some compounds yield different conductivity at different temperatures, was there a sufficient cool down time between each test for the various components, were the number of trials for each compound sufficient, do different batches of each compound make a difference, have I made my point?
