Grand Theft Auto IV - הדיון הראשי
למישהו יש מושג למה המשחק כותב לי שנמערכת לא מסוגלת להריץ אותו? הוא בכלל לא נותן לי להתקין ולדעתי אני עומד במינימום
E7200
HD3850 256MB
2GB RAM
מקום פנוי לא חסר
וVISTA אם זה משנה
  • תגובות 606
  • צפיות 72.8k
PATCH בדרך!:
We are working on making a patch available in the next few days. Since Grand Theft Auto IV is a Games For Windows Live game the patch must be certified by Microsoft before release. The patch is already at Microsoft and we expect a speedy approval. The patch contains a variety of fixes including:
* A fix to the crash after legal screen that some German customers were reporting.
* Numerous improvements to the video editor: Smarter naming of videos, improved rendering quality, better fx during replays
* Fix to bowling while using certain sensitive mice
* Fix for ATI 1900 shadows
* Overall savings to memory
* Graphic improvements to particle systems and mirrors
* Multiplayer character settings are preserved
* Support for DirectInput controllers. Note: The current hack way of supporting these controllers may not work with the improved functionality. So we recommend you remove the hack before upgrading to the patch.
Issues with power management software have also been fixed (slow speed, double speed issues). Even after the patch comes out setting power management software to maximum performance is recommended. Weve seen cases where power management software does not detect the game is running and puts the CPU in green mode.
Besides the patch weve also improved the way the Social Club handles data this should have greatly reduced or eliminated the Mma10 error. If you are still receiving this error after logging in and out of Social Club we would like to know as much info as you can about it.
יש לך E6300 בלי OC ?
כן, הוא בלי OC (למרות שבא לי לעשות לו.. הוא עושה לי צוואר בקבוק קטן..אולי בקרוב..)
Makoto, סגרתי הרבה מאוד תהליכים שהיו פתוחים והינה השיפור!
אולי אחרי הפאטץ' אני יוכל לשחק נורמלי כמו שציפיתי :)
נ.ב... מישהו יודע איך אני יורה מהרכב כמו שהיה בSA? (ליורת מהחלון הצדדי לא מקדימה..)
עריכה:
למה אני רואה עכשיו שבאתר של Nvidia אין את הדרייבר 180.84 ???
דניאל.
מה איכפת לך? הוא בNZONE...
אני גם עם 6300 ואין לי OC כי אני לא יכול לעשות.
בלוח אם שלי אין אופציה גם בנסתרים שם. יש רק לזיכרונות.
טוב מכיוון שאצלי פשוט התקנתי את הדרייבר ולא בדקתי FPS לפני...
אז אני אתן לך בנצ'ים מהמחשב של אחי :
180.48
Statistics
Average FPS: 27.00
Duration: 37.30 sec
CPU Usage: 90%
System memory usage: 76%
Video memory usage: 95%
Graphics Settings
Video Mode: 1280 x 1024 (60 Hz)
Texture Quality: Medium
Render Quality: High
View Distance: 14
Detail Distance: 13
Hardware
Microsoft Windows XP Professional
Service Pack 3
Video Adapter: NVIDIA GeForce 8800 GT
Video Driver version: 180.48
Audio Adapter: Creative Sound Blaster PCI
AMD Athlon 64 X2 Processor 4200+
File ID: benchmark.cli
180.84
Statistics
Average FPS: 32.25
Duration: 37.00 sec
CPU Usage: 93%
System memory usage: 85%
Video memory usage: 97%
Graphics Settings
View Distance: 13
Detail Distance: 14
Hardware
Service Pack 3
Video Driver version: 180.84
File ID: Benchmark.cli
עדכנתי את הסיוס בלוח שלי מF1 לF7 בהצלחה למזלי.
עכשיו יש לי אפשרות בביוס לעשות OC :D
אני אקנה לי משחה טרמית איכותית ונראה כבר מה אפשר לעשות...
אף אחד פה עדיין לא שיחק במשחק עם E6300 בלי OC?
לפחות אתם יכולים לשחק אצלי המשחק לא שחיק בגלל הבאג המטומטם של סדרת 7900 פעם ב נטענת לה טקסטורה ככה שאני רואה אותי ולפעמים איזהשהו בניין נחמד :s07:
טוב חברה גם עוד אחד שמאוכזב מהמשחק
למרות המחשב הבינוני שיש לי
רציתי לדעת אם זה בסדר שזה פועל לי על 30-20 fps
מה אתם אומרים?<
e8400
p45
2 זיכרון
4850
כרגע זה בסדר שזה פועל לך ככה, לרוב זה פועל ככה עם מפרטים דומים מאוד לזה. כשיצא פאץ' בקרוב מאוד אני מקווה, זה יתוקן.
לדעתי משחק מצויין בכללי יש עלילה מצויינת מחר אני קונה רק איך אני מעביר את כל מה שעברתי עד עכשיו למקורי?
המ, תיכנס לתיקיית שמירות:
אני זוכר שזה נמצא בAPPLICATION DATA בUSERS(שנקרא בXP MY DOCUMENTS)
אין לי מושג איפה בדיוק כי אין לי את המשחק עדיין(כן, גם לא את הפרוץ)
החלטתי להיות גם איזה שפן נסיונות קטן ולבדוק את הדרייבר החדש של NVIDIA.
אז ככה.. הנתונים מתוך הבנצ'מארק של במשחק באפשרויות גרפיקה. כמו כן המערכת נבדקה עם המפרט בצד.
180.48
Average FPS: 47.00
Duration: 37.19 sec
CPU Usage: 63%
System memory usage: 82%
Video memory usage: 98%
Graphics Settings
Video Mode: 1280 x 1024 (75 Hz)
Render Quality: Highest
View Distance: 58
Detail Distance: 100
Hardware
Service Pack 3
Audio Adapter: Realtek HD Audio output
Intel® Core2 Quad CPU Q6600 @ 2.40GHz
180.84
Average FPS: 45.88
Duration: 37.25 sec
CPU Usage: 64%
System memory usage: 83%
Graphics Settings
View Distance: 59
Hardware
Service Pack 3
המשחק רץ לי חלק 35 FPS ובלי תקיעות רק לאחר שעתיים יש תקיעות אני פשוט יוצא לחצי שעה וממשיך
המשחק יפה עלילה מעניינת
אם אני יעשה אובר קלוק זה ישפר ? (יש לי E7200 וקירור OCZ ונקווישר תכננתי OC כשקניתי)
שאלה אחרונה מתי לדעתכם יצא הפאץ?
זה מהמחשב שלי.. יש לי רק אחרי :
Statistics
Average FPS: 40.73
Duration: 37.02 sec
CPU Usage: 77%
System memory usage: 43%
Video memory usage: 99%
Graphics Settings
Video Mode: 1680 x 1050 (60 Hz)
View Distance: 46
Hardware
Service Pack 3
Video Adapter: NVIDIA GeForce 9800 GTX/9800 GTX+
Intel Pentium III Xeon processor
זה על הגדרות הכי גבוהות שאני יכול לשים..
דיי מרוצה...
