TOMSHARDWARE nelahem intorduction
QPI brings a fascinating possibility to the table: in order to create a dual-CPU motherboard, a company simply has to solder a second processor socket onto its PCB. Since the processors can communicate with each other directly, this option is independent of the chipset, making it very simple, not to mention inexpensive. A good portion of todays software shows marked performance gains thanks to the four additional virtual processors provided through Hyper-Threading. When adding another CPU with real cores, the performance improvement should be even more pronounced.
impressive feature, i fear that this has the power to bury amd once and for all :x
