רוצה מנדריק 9.1
מאיפה אני יכול להוריד מנדירק 9.1? ???
תודה ::)
  • 2 שבועות מאוחר יותר...
1.5 ג'יגה???????????? איך צורבים ת זה ? חשבתי שאפר לצרוב את זנ על דיסק אחד
שלושה דיסקים...
אתה לא רואה שלושה לינקים??
אה וואלה
אתה צריך לצרוב לפי ההוראות האילו אם לא יהיו בעיות בהתקנה: ("לי כבר היו בעיות")
Howto burn an ISO image ?
All the CD-Writing software can use ISO image to burn directly a CD-Rom.
Important note: take care to download the ISO in binary mode (FTP). By default Netscape download the file in ASCII mode which corrupt the image. You can check the integrity of the ISO file with the md5 key (md5sum mandrake.iso under Linux), go to http://www.etree.org/md5com.html to get the md5sum.exe version if you are using Windows)
Please avoid downloading the ISO with a 56K modem line. If the download
fails you can use "Resume" which allows you to continue the download. It
works with ftp (reget), ncftp, CuteFTP, Getright, ...
With Easy CD Creator:
Open Easy CD Creator
Go to "File"
then to "Create CD from disc image"
make sure to change the bottom drop down menu ("Files of type:") to say
"ISO image files"
It will do the rest after you browse to the *.iso file
(Thanks for zacheyer)
With WinOnCD:
you can select a
"track-image" project when you click the New button. So long as you are
in track mode, not file-system mode (how that looks depends on whether
you have 3.0 or 3.5) then dragging a track image file onto the CD window
should accept it as a raw track. WinOnCD uses .RAW as its own
extension
(Thanks Rick Jones)
With Nero Burning Rom:
Open Nero.
Close the wizard if it is started automatically.
Go to "File"
then to "Burn Image...".
In the next dialog, click on "Image Files (*.nrg)" and select "All files
Choose the .iso file and accept.
In the following dialog make sure:
- Type of Image is: Data Mode 1
- Block size: 2048
- Image header: 0
- Image trailer: 0
- All the checkboxes are unactive.
Click "OK".
In the next dialog check that the "write" and "finalize" option are active.
Click on "Write".
(Thanks Antonio Asensi)
With CD-Record:
CD-Writing HowTo:
http://howto.linuxberg.com/ptHOWTO/CD-Writing-HOWTO
For example:
cdrecord -v speed=4 dev=4,0 mandrake.iso
You get the number on the SCSI bus number with "cdrecord --scanbus"
הוראות צריב ה בדויקות לשלושת התוכנות הכי מוכרות שלב אחר שלב בהצלחה
