פורסם 2002 בפברואר 1124 שנים Proof that Bill Gates is the Devil himself!--------------------------------------------------------------------------------Warning! Bill Gates (the president of the Microsoft) may be the next antichrist:Revelation 13:18 says:"Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: His number is 666."The real name of the Bill Gates is William Henry Gates III. Nowadays he is known as Bill Gates (III), where "III" means the order of third (3rd). By converting the letters of his name to the ASCII-values (which are used in computers) you will get the following:B I L L G A T E S 366 + 73 + 76 + 76 + 71 + 65 + 84 + 69 + 83 + 3 = 666Daniel 7:23 says: "Thus he said: 'The fourth beast shall be a fourth kingdom on Earth, which shall be different from all other kingdoms, and shall devour the whole Earth, trample it and break it in pieces." Current history knows three antichrists:- Adolf Hitler- Joseph Stalin- The Pope(You can count number 666 from each of the names above.)Is the fourth beast Microsoft corporation which represents the power of money? Revelation 13:16 and 13:18 says:"He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads," "and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name."Windows compatible?"--------------------------------------------------------------------------------It looks like well-known OS's fall into the same category: M S - D O S 6 . 2 1 77+83+45+68+79+83+32+54+46+50+49 = 666 W I N D O W S 9 5 87+73+78+68+79+87+83+57+53+1 = 666Coincidence? I think not!לקוח מ:http://www.connix.com/~rzs/humor/666.html
פורסם 2002 בפברואר 1124 שנים מחבר חחחחחבדקתי וזה נכון!(בניתי תוכנה קטנה בVB שמחשבת את האסקי)(זמן פנוי)
פורסם 2002 בפברואר 1224 שנים מחבר אבל הכי מהיר לכתוב איתה משהו קטנצ'יקואני משתמש בVS.NET (לא שיש לי אותו כמובן *cough* *cough*)ומיקרוסופט שינו הרבה דברים בסיסיים בVB...בו נגיד, שאם עד היום היה היגיון של העולם האמיתי והיגיון של תכנות, אז הגבול ביניהם טושטש לחלוטין...
פורסם 2002 בפברואר 1224 שנים מחבר אז גילית את העולם המופלא של העשבים הלא חוקיים, אה?אני נקי כמו טוסיק של תינק, אבל אני מתחיל לחשוד שארכיטקט התוכנה הראשי שלהם כן
פורסם 2002 בפברואר 1224 שנים אז גילית את העולם המופלא של העשבים הלא חוקיים, אה?אני נקי כמו טוסיק של תינק, אבל אני מתחיל לחשוד שארכיטקט התוכנה הראשי שלהם כןאיזה טוסיק? (של אחי לא כל כך נקי רוב הזמן!) ;D
פורסם 2002 בפברואר 1224 שנים בולשיט! כודם מוסיפים 3 , אחרי זה לוכחים גירסת דוס שלא קיימת, ובפעם שלישית מוסיפים 1.אני יכול להוכיח שגם אני השטן:נכתוב את השם הפרטי שלי עם שגיעת כתיב נפוצה:- מ ו ר ד כ י -בגימטריה זה יוצא 40 6 200 4 20 10 = 280 . נוסיף את המחשב הראשון שלי. מה יוצא :666
פורסם 2002 בפברואר 1224 שנים בולשיט! כודם מוסיפים 3 , אחרי זה לוכחים גירסת דוס שלא קיימת, ובפעם שלישית מוסיפים 1.אני יכול להוכיח שגם אני השטן:נכתוב את השם הפרטי שלי עם שגיעת כתיב נפוצה:- מ ו ר ד כ י -בגימטריה זה יוצא 40 6 200 4 20 10 = 280 . נוסיף את המחשב הראשון שלי. מה יוצא :666נו אז מה חשבת? שזה אמיתי? זה סתם בשביל הצחוק.....אבל אהבתי את מה שעשית
פורסם 2002 בפברואר 1424 שנים נו אז מה חשבת? שזה אמיתי? זה סתם בשביל הצחוק.....אבל אהבתי את מה שעשיתחוץ מזה הכוונה לא " מפלצת ששמה \מספרה הקטלוגי הוא 666 ", אלא "ששמאות שישים ושש מפלצות"וחוץ מזה - אין ספר כזה בתנ"ך
