מסך כחול , פירוט WINDBG בפנים .
Microsoft ® Windows Debugger Version 6.9.0003.113 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini100108-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: C:\WINDOWS\Symbols
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805634c0
Debug session time: Wed Oct 1 20:20:27.356 2008 (GMT+3)
System Uptime: 2 days 9:24:29.513
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image win32k.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for win32k.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {c0800b86, 0, c0800b86, 2}
Could not read faulting driver name
Probably caused by : win32k.sys ( win32k!xxxSleepThread+17d )
Followup: MachineOwner
0: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: c0800b86, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: c0800b86, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000002, (reserved)
Debugging Details:
READ_ADDRESS: c0800b86
FAULTING_IP:
+ffffffffc0800b86
c0800b86 ?? ???
MM_INTERNAL_CODE: 2
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: ICQLite.exe
LAST_CONTROL_TRANSFER: from bf802f3d to c0800b86
FAILED_INSTRUCTION_ADDRESS:
+ffffffffc0800b86
c0800b86 ?? ???
STACK_TEXT:
WARNING: Frame IP not in any known module. Following frames may be wrong.
b6218c80 bf802f3d 00000200 e11b9eb0 00000000 0xc0800b86
b6218ca8 bf801b2a 000025ff 00000000 00000001 win32k!xxxSleepThread+0x17d
b6218cec bf819e6c b6218d18 000025ff 00000000 win32k!xxxRealInternalGetMessage+0x418
b6218d4c 804dd98f 006faa84 00000000 00000000 win32k!NtUserGetMessage+0x27
b6218d60 0012fec4 7c90e4f4 badb0d00 0012fea8 nt!ZwSetSystemInformation+0x13
b6218d64 7c90e4f4 badb0d00 0012fea8 00000000 0x12fec4
b6218d68 badb0d00 0012fea8 00000000 00000000 0x7c90e4f4
b6218d6c 0012fea8 00000000 00000000 00000000 0xbadb0d00
b6218d70 00000000 00000000 00000000 00000000 0x12fea8
STACK_COMMAND: kb
FOLLOWUP_IP:
bf802f3d ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: win32k!xxxSleepThread+17d
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 48025f2a
FAILURE_BUCKET_ID: 0x50_CODE_AV_BAD_IP_win32k!xxxSleepThread+17d
קוראות לי הרבה נפילות של המחשב עקב win32k אך ורק בזמן שאני משחק במשחק כלשהו , ששמו COUNTER-STRIKE SOURCE , המחשבים יכול לפעול ימים ואף חודשים מבלי ליפול במסך כחול , עד שאני משחק בקאונטר-סטרייק סורס בערך שעה ואז יש לי מסך כחול שמביאה את הפירוט של למעלה .
עזרה :]
עיין בסטיקי של פורום תמיכה טכנית לגבי ניתוח של קבצי DUMP וההבנה של התוכן שלהם.
בכל מקרה לא היה צורך סתם ככה להדביק פה הכל.
מועבר לפורום המתאים.
עיינתי , ואני מעדיף לקבל תשובה כאן .
איזו חבילת שירות(SP) מותקנת אצלך כרגע?
כל העידכונים ל-Windows מותקנים?
יש Hotfix שאמור לתקן(ברוב המקרים) BSOD שקשורים ל-win32k.
SP3 ,
אני אבדוק אם קיימים עדכונים .[br]פורסם בתאריך: 1.10.2008 בשעה 23:34:53
מצטער על הדאבל , אך בדקתי באתר של מיקרוסופט אם קייימים עדכונים , ולא קיימים עדכונים לSP3 .
