Problems configuring IIS under WinXP
I'm building a site for the computer bagrut and it includes ASP, I installed IIS and ASP code does work but I can't find how and where to configure it IIS to work properly.
My main problem is that everytime you refresh an ASP page it closes all the sessions, I have a visitor counter in the site which is supposed to open a session for each user so it won't list the same user over and over again whenever he refreshes the page. The page works perfectly fine using PWS in my school but using IIS at home it adds a new visitor to the counter each time you refresh the page.
How do I get IIS to work properly?
