Crysis Warhead - הדיון הראשי
ואם אני רוצה את כול האוביקטים על המסך וזין על המערכת? ;)
איזה הגדרות אני צריך לשנות בשביל זה?
:lol: זה אני לא יודע אם יש בהגדרות אבל כן... זה טעינת אובייקטים רחוקים יהיה משהו עם distance
  • תגובות 1.7k
  • צפיות 189.4k
מה חדש/הוסיפו/שיפרו?
תודה על הלינק SHADOW.
^זה רשום בלינק הראשון חביבי
Patch 1.2 ReadMe File - November, 2008
Fixes:
- Fixed: Several client and server crashes
- Fixed: Several memory leaks
- Fixed: '\' in level names in levelrotation.xml will now work
- Fixed: Incorrect weapon recoil after zooming
- Fixed: Claymore mines sometimes did not detect enemy players
- Fixed: Potential exploits using client cvars
- Fixed: Players not able to skip intro movies
- Fixed: Reloading and shooting with the AY-69 will not cause a second reload animation anymore
Improvements:
- Balance: Reduced prices of AY and SMG
- Balance: Increased price of Shotgun
- Balance: Reduced price of the PS-Radar Kit
- Balance: Adjusted weapon recoil by any SMG and Assault Rifle type weapons.
- Balance: Reduced Kill radius of any Explosive Weapons
- Balance: Adjusted splash radius of any Explosive Weapons
- Balance: Reduced rate of fire of the Grenade Launcher
- Balance: Adjusted C4 vehicle damage
- Balance: Increased LAW rocket Speed
- Balance: Increased AAA Rocket speed
- Balance: Increased AAA Rocket turn speed
- Balance: Adjusted AAA Gun damage
- Balance: Reduced splash damage of VTOL rockets against infantry
- Balance: Increased damage of Helicopter rockets
- Balance: Increased SOCOM damage
- Balance: Increased AY69 damage
- Balance: Adjusted Stand to Prone modifier for weapons
- Balance: Adjusted Stand to crouch modifier for weapons
Please check mycrysis.com for more details: www.mycrysis.com/gameguidesite.php?site=29228
Updates:
- Updated: Added shortcut keys for Nanosuit modes
Patch 1.1 ReadMe File - October, 2008
Fixes:
- Fixed: Stand/Prone firing exploit by exaggerating spread of all weapons when transitioning
from standing position to prone position
- Fixed: Inconsistency between the HUD score and the score shown in the scoreboard
- Fixed: Disconnection caused by cheat protection for levels saved by the map downloader
Improvements:
- Improved: Player icon, cross hair and round start messages visibility against bright backgrounds
Updates:
- Removal of online activation (ReleaseControl)
- Support of Linux server
- 64bit version
- Vista Parental Control file [/left
מישהו ניסה? מרגיש שיפור?
בשלב האחרון יש יצור ענק... איך הורגים אותו?
רסס אותו בלי סוף..ולך למטוס המרוסק באמצע יש שם איזה נשק מפחיד כזה (נראה כמו ויברטור ענק שיורה חשמל).
פשוט תתקרב למפלצת קצת ותירה בו כמה כדורים עם הנשק הזה עד שהוא יפול
תודה :xyxthumbs:
אחינו למה יש לך ניסיון עם ויברטורים יורי חשמל :lol: :itschy:
:lol: איזו התחלה הזוייה
ואם SHADOW שאל את זה אז התשובה דיי ברורה
אמרו שהפאץ מתקן את זה שאי אפשר להעביר את הסרטון פתיחה בCRYSIS WARS.
ווכן, לי זה לא עובד, אני כל פעם נאלץ לראות את הסרטון(האמנם טוב, אבל לא בפעם העשירית ויותר) מחדש ... :s07::bash:
Tom's Hardware ערכו השוואה בין המשחק FARCRY 2 לבין CRYSIS בסרטון וידאו
http://www.tomshardware.com/farcry2-crysis,video-318.html
לא מפתיע מי לקח.
החברה יודעים שמה להעריך את המלך CRYSIS WH :yelclap:
^בהחלט :xyxthumbs:
תנסה את זה, אותה בעיה לכמה מהאנשים ששאלו בפורום הראשי mycrysis
http://www.mycrysis.com/thread.php?threadid=39294
לחלקם זה לא עובד ואפשר לעקוף את זה ע''י שינוי שם הספריה video לשם אחר
:yelclap:
עכשיו הרבה יותר טוב, מחקתי את הקבצים שהם אמרו. :xyxthumbs:
