video card - for big screen
hello every body
im in the US for the next couple of years, so i need a computer
i bought 28" hanns-g
what is the graphics i would need to play games in a good resolution on this kind of screen
thenk you in advance
What is Your 28'' resolution?
Screen Size
27.5" Viewable
Native Resolution 1920x1200
Response Time
3ms
Rated Contrast Ratio
800:1
Maximum Brightness
500cd/m2
PC Inputs HDMI and D-Sub VGA
Video Inputs Component
TV Tuner
None
HDCP Yes
USB None
Pic in Pic
None
Speakers 2 x 2.5w
Adjustibility Tilt and Swivel
Display Colors
16.7M
Viewing Angle
160deg H and V
Weight 30.2lbs
Warranty 3 Years
im just buying it
general
q9550
asus p5qc
8gb memory
ok, so you better consider HD4850 or HD4870 .
depends on your budget....
these are great of HD content and gaming... you will get a DVI to HDMI adapter which delivers full 1080P with 7.1 channel surround sound :xyxthumbs:
