Sharing problem on wireless network
The internet works.
sharring files between 2 comp's is the problem.
When I'm trying 2 share it asks for username and password ?
What r they ?
Start from the beginning
What have you done to make sure there is a shared resource between the two computers?
What operation systems are installed on them?
Just a liitle tip for you: next time you derscribe a problem specify as much as possible information regarding the problem and your actions. :)
Both of them are working on Vista Ultimate.
Both are marked on shared (in properties).
The problem is when I'm in Network and Sharing I see them, when I try to enter the other one it asks me for user name and password - which I have never opened.
The Network and the password
[attachment deleted by admin]
It seems like secured sharing is turned on...
Go to "network and sharing center" inside control panel and make sure password protected shraing is turned off.
More information and details can be found here.
Thank you very much.
now its working...
