אתחול ומסך כחול
בעת העתקת קובת מכונן DVD ל HD המחשב שלי מאתחל עצמו.
הוא מראה לי מסך כחול לשנייה.
אני מצרף קובץ Dump.
אודה על פענוחו.
[attachment deleted by admin]
תוכל לעשות את זה בעצמך .. זה לא יקח הרבה זמן
יש לך סטיקי ללכת אליו , תקרא קצת , תתקין את מה שצריך ותראה מה עושה לך בעיות
הנה הפלט :
* Bugcheck Analysis *
KERNEL_DATA_INPAGE_ERROR (7a)
The requested page of kernel data could not be read in. Typically caused by
a bad block in the paging file or disk controller error. Also see
KERNEL_STACK_INPAGE_ERROR.
If the error status is 0xC000000E, 0xC000009C, 0xC000009D or 0xC0000185,
it means the disk subsystem has experienced a failure.
If the error status is 0xC000009A, then it means the request failed because
a filesystem failed to make forward progress.
Arguments:
Arg1: c03ddcf0, lock type that was held (value 1,2,3, or PTE address)
Arg2: c000000e, error status (normally i/o status code)
Arg3: f773c2a0, current process (virtual address for lock type 3, or PTE)
Arg4: 3eca3860, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
Debugging Details:
ERROR_CODE: (NTSTATUS) 0xc000000e - A device which does not exist was specified.
DISK_HARDWARE_ERROR: There was error with disk hardware
BUGCHECK_STR: 0x7a_c000000e
DEFAULT_BUCKET_ID: DRIVER_FAULT
PROCESS_NAME: System
LAST_CONTROL_TRANSFER: from 80526f01 to 80537832
STACK_TEXT:
f7c86858 80526f01 0000007a c03ddcf0 c000000e nt!MiAttemptPageFileReduction+0x71
f7c86880 804facb1 81235f48 c03ddcf0 f773c2a0 nt!RtlVerifyVersionInfo+0x155
f7c868f8 804e9fcb 3eca3860 f773c2a0 c03ddcf0 nt!MiWaitForInPageComplete+0x327
f7c8694c 804e0f07 00000000 f773c2a0 00000000 nt!RtlSetBits+0x70
f7c8694c f773c2a0 00000000 f773c2a0 00000000 nt!KiTrap07+0x2d4
f7c869d4 f7743356 86371ae8 86371e0c 00000000 SCSIPORT!SpEnumerateAdapterAsynchronous
f7c86a18 f7734469 86371a30 855f4a40 86383f38 SCSIPORT!ScsiPortFdoPnp+0x516
f7c86a2c 804e19ee 86371a30 855f4a40 f7c86aac SCSIPORT!ScsiPortGlobalDispatch+0x1d
f7c86a2c 863e79b8 86371a30 855f4a40 f7c86aac nt!KiTrap0D+0x1c3
WARNING: Frame IP not in any known module. Following frames may be wrong.
f7c86d20 00000000 863e79b8 00000001 00000000 0x863e79b8
STACK_COMMAND: kb
FOLLOWUP_IP:
SCSIPORT!ScsiPortFdoPnp+516
f7743356 ?? ???
SYMBOL_STACK_INDEX: 6
SYMBOL_NAME: SCSIPORT!ScsiPortFdoPnp+516
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: SCSIPORT
IMAGE_NAME: SCSIPORT.SYS
DEBUG_FLR_IMAGE_TIMESTAMP: 41107b4b
FAILURE_BUCKET_ID: 0x7a_c000000e_SCSIPORT!ScsiPortFdoPnp+516
Followup: MachineOwner
נראה כי קיימת בעיה הקשורה להתקן-איחסון כלשהו (ואולי למנהל-ההתקן שלו).
כנראה דיסק קשיח.
הדיסק הקשיח שיש ברשותך הוא מה שרשום במפרט?
תעשה סריקה להארד דיסק שלך באמצעות תוכנה מיצרנית שלו ..
ותעשה גם סריקה מהכלי של הוינדוס עם האופציה לתיקון שגיאות
התוכנות של היצרניות בד"כ לא שוות הרבה...
עדיף לנסות לבדוק את הכונן באמצעות MHDD - הניתנת להורדה מכאן.
תודה רבה.
האם ייתכן שזה קשור לזה שאני משתמש בתוכנת ה- Daemom Tools ??
"ERROR_CODE: (NTSTATUS) 0xc000000e - A device which does not exist was specified."
זו עשויה להיות אפשרות, שכן התוכנה מדמה התקני-איחסון.
תתחיל בלעדכן לגרסת ה DAMEON TOOLS האחרונה. זה בטוח.
נראה לי יותר עדיף להתחיל בבדיקת-זיכרון (למשל באמצעות +memtest86), ורק אח"כ להתפנות להסרת ה-Daemon Tools כליל (ואולי גם לבדיקת ולניקוי מעה"פ), ולבדיקת הכונן-הקשיח (גם באמצעות MHDD ושות').
שלום רב,
בהתאם לתשובות שלכם למעשה אני צריך לבדוק את כל המחשב: זכרון, HD,לוח אם וכו'.
צרפתי קובץ Dump וקולגה שלי צירף את הפלט שלו בשרשור זה.
האם תוכלו לכוון אותי יותר מה מקור התקלה?
במקרה של חשד לבעיית חומרה, לא רצוי למקד הבדיקה באיזור מסויים לפני שבודקים את הכל באופן כללי.
