בעיה במשחק Penumbra Black Plague
המשחק יוצא לווינדוס
מה יכולה להיות הבעיה ?
Game Running
Reset check for input!
Loading collada for 'maps/level01_cells.dae' took: 406 ms
ERROR: Couldn't create material 'particle_rockpiece.mat'
ERROR: Couldn't find particle system file 'particle_imp_generic_hard.ps'
ERROR: Couldn't create material 'particle_metalpiece.mat'
ERROR: Couldn't create SoundEntity 'unbreak_impact_metal_soft_furniture_med.snt'
WARNING: Couldn't preload sound 'unbreak_impact_metal_soft_furniture_med'
WARNING: Geometry for joint child '' is missing! Might be connected to bone.
WARNING: Geometry joint parten '' is missing! Might be connected to bone.
ERROR: Couldn't find particle system file 'particle_imp_metal_special.ps'
WARNING: Parent 'group3' couldn't be found! Failed to attach 'artefact01_pointLight1' to 'artefact01'.Attaching directly to mesh.
ERROR: SoundEnv 'soundenvs/EnvPreset012_Hallway.snv' does not exist!
ERROR: SoundEnv 'soundenvs/EnvPreset001j_Vent.snv' does not exist!
ERROR: SoundEnv 'soundenvs/EnvPreset104_DustyRoom.snv' does not exist!
ERROR: Couldn't find game entity 'descRBshelffloor'
WARNING: Couldn't find game entity 'descRBshelffloor'
Loading map 'level01_cells.dae' took: 10063 ms
WARNING: Entity 'descventdark' callback doesn't exist in 'Player'
המשחק יוצא לווינדוס
עותק לא חוקי.
שי,קרא את חוקי הפורום להבא.
ננעל.
