Team Fortress 2 - הדיון הראשי
עדכון חדש עם שיפורים לא קטנים:
The Engineer's Teleports can now be upgraded to level three. It will recharge faster the higher level it is.*
Spies will be able to recharge their cloaking ability by piking up ammo off of ground or from health cabinets.*
.Any weapons that fire bullets can now break apart the damoman's stickybombs
Added achievment tracker that will allow people to choose specific achievements that they are trying to get.
.The engineer's dispensers can now be upgraded to level three. It wiil give out metal and heal faster as it s upgraded
ויש עוד.. רק מה שלא ברור לי זה איפה רואים את הLEVEL של הטלפורטס והדיספנסרים? ברמה השנייה (?) הTeleport הופך להיות מאוד מאוד מהיר ולא צריך כמעט טעינה...אז מה משפרים שם כבר?.
(אגב העדכון אצלי ירד בקצב גבוה מאוד יחסית, משהו באזור ה65Kbps לעומת 10).
  • תגובות 703
  • צפיות 76.5k
העדכון הבא הוא לסקאוט....
וגם משתמשי הX360 יקבלו את כל העדכונים בקרוב
ובנוסף החבר'ה של וואלב עובדים על שיפור למנוע של TF2..
  * The next class pack will be the Scout. One of the main goals we're focusing on for him has been to provide tools that make him useful in maps like Dustbowl & Goldrush. If you have any ideas for what you think would work well, post them over on the Team Fortress 2 Forum and we'll take a look.
* We are actively working on a massive XBox 360 update, which will include pretty much everything we've shipped on the PC in the last year. We'll provide you with a rough date when we have one.
* We're also working on bringing over a variety of engine improvements from Left 4 Dead into the TF2 engine, but it won't be a wholesale replacement of the engine. This means we'll get some of L4D's performance improvements, like the better multicore support, but not all of them. For example, we can't bring over some improvements without dropping support for DX8, which we're not prepared to do.
וכל העדכונים להיום:
# The Engineer's teleporters can now be upgraded to level three. It will recharge faster the higher level it is
# The Engineer's dispensers can now be upgraded to level three. It will give out metal and heal faster as it is upgraded
# Spies will be able to recharge their cloaking ability by picking up ammo off of the ground or from health cabinets
# Some changes to the second part of the first stage of Goldrush to give the attackers more of an advantage
# Any weapons that fire bullets (shotguns, sniper's machine gun, heavy's minigun, etc.) can now break apart the Demoman's stickybombs
# The icon on the HUD for a person calling for Medic will now give more information to the medic (if the target is low on health, on fire, etc.)
# Added an achievement tracker that will allow people to choose specific achievements that they are trying to get
# There is now a custom icon for death messages when the player was killed from a critical hit
# Added a new particle effect for when a player enters the water
# Added smoke to the feet of a rocket jumping soldier
# Players will now have some particles swirling around them so other players can see when they are overhealed
נראה שהמשחק עודכן אצלי... בזמן האחרון אני לא שם לב מתי סטים מספיק להוריד לי עדכונים ;D
מוריד עכשיו, איטי ביותר(2.0KBS)
ויש לי שאלה, תמיד הדיספנסרים והטלפורטרים יהיו להם מצב שבם יכולים להשתדרג לרמות?
יש! סוף סוף!
חדשות מצויינות :yelclap::D.
אם כתוב לך 100% Ready, הוא מעודכן.
לא.
את הטלפורטים לא יצא לי לבדוק, אבל הדיספנסרים משתנים גם מבחינת הצורה (עם הרמות עולות באות עוד תוספות).
ברמה השנייה הDispenser מביא 50 metal כל פעם במקום 40.
ברמה השלישית הוא מקבל גם מן "מכונת חיים" למעלה ומעלה מהר את החיים וגם נותן 60 METAL כל פעם.
בשביל לשדרג לרמה הבאה צריך 200מטאל (כמו בSentry gun) וכך גם לTeleporters.
ככה נראה הDispenser ברמה השלישית:
[attachment deleted by admin]
נכנסתי לשחק היום רק כדי לבדוק את העדכונים גם הטלפורט משגר בקצב מהיר והדיספנסר מצויין!
ורק חבל שהקלוק של הספיי עכשיו יורד בקצב מהיר מאוד למרות שאפשר למלא אותו תוך כדי הליכה...
יאללה קיבלתי חשק לשחק :P
רק שה X3100 של הנייד יסחוב בכלל את המשחק..
וכל העדכונים להיום:
שיט אני אצטרך להוריד את כל המשחק מחדש כי שכחתי לגבות את הקבצים שלו לפני הפירמוט :(
אני מקווה שהעדכון שווה את זה ( מחכה לעדכון SCOUT בקוצר רוח ).
כרגע קניתי את המשחק ב 9.99$ :)
יש מבצע סוף שבוע.
עד עכשיו הייתי משחק עם משתמש רוסי שהייתי צריך לשנות כמה דברים בשביל לשחק..
הוריד לי את העדכון על 200Kb\s, סיים תוך שתי דקות .
יש לי כמה שאלות:
1)המפתחים עכשיו מפתחים כול מיני UNLOCKים לדמויות שונות?
2)אם כן, פחות או יותר מתי כול זה יקרה?
3)מה הדרך הכי קלה להשיג את הACHIVMENTS של ה HEAVY? פתחתי רק 12 ונשארו לי עוד 4 עד שאני מקבל את הMINIGUN העצבני.
4)מה אני מקבל כשאני מסיים את כול הACHIVMENTS הכלליים?
1. כן, נשקים...
2. כשאתה משיג מספר מסויים של אצ'יבמנטים עם הדמות המתאימה.
אבל לא לכולם יש unlockים. הם עדיין עובדים על זה.. יש רק לחלק.
יש סרברים של אצ'יבמנטים שאתה יכול לסיים את רובם מהר מאוד.
אגב, המיניגאן שאתה מקבל(נטשה) הוא לא כזה טוב. אני מעדיף להשתמש ברגיל.
אבל אין דבר יותר כיף מלראות סקאוט חסר אונים מפרפר לצדדים תוך כדי נסיון נואש לברוח מHeavy עצבני עם נטשה ;D :cool2:.
בקיצר נטשה שימושית נגד סקאוטים (וגם נגד אויבים מתחכמים שאוהבים לקפץ לצדדים כל פעם שהם תוקפים אותך).
מה ההבדל בין נטשה לMINI הרגיל?(חוץ משנטשה יותר עוצמתית)
על אילו סרברים מדובר? יש המלצות?
ד"א יש ACHIEVEMENT אחד שצריך להרוג 10 אוייבים עם חגורת הKGB או משהו כזה........מה????
ושוב, מה אני מקבל כשאני מסיים את כול הachivements הכלליים?
הנטשה הוא לא יותר עוצמתי, הוא מוריד פחות 25% HP מהרגיל אך הוא מאט אותך והוא 100% פוגע במטרה.
חפש בGAME MONITOR סרברי ACHIEVEMENTS
לא הבנתי מה זה 10 אויבים עם חגורת KBG. מה זה בכלל?
הוא מדבר על כפפות הKGB.
פשוט נכנסים לאיזה שרת אצ'יבמנטס ומפרקים 10 Heavys.
אלה כפפות שאיטיות יותר מהאגרופים אבל אם אתה הורג איתן מישהו הן נותנות לך 10 שניות קריטס היטס (מה שיכול להיות מאוודדד כיף).
