תוכנית אשר בודקת שני מערכים
כתבתי תוכנית אשר אמורה להשוות שני מערכים חד מימדיים ,אך משום מה החיפוש הבינארי לא מחזיר לי את ההתוצאות הדרושות
public class IntVector
//instance variable
private int [ ] _arr;
* Constructor for objects of class IntVector
public IntVector (int size)
_arr = new int [size];
//methods
public void addInt (int num , int index)
if(index<_arr.length)
_arr[index] = num;
else
System.out.println("the index is bigger than the array");
private void swap(int [] data , int first , int second)
int temp;
temp = data[first];
data[first] = data[second];
data[second] = temp;
* 3 arguments partition
private int partition (int [] a , int lo , int hi)
swap (a , lo , medianLocation(a , lo+1 , hi , (lo+hi)/2 ) );
int m = partition (a, lo+1 , hi ,a[lo]);
swap (a, lo , m);
return m ;
* 4 argument partition
private int partition( int [] a , int lo , int hi , double pivot)
if (hi == lo )
if (a[lo]< pivot)
return lo ;
else
return lo-1;
else if (a[lo]<= pivot)
return partition(a, lo+1 , hi , pivot);
else
swap (a ,lo , hi);
return partition (a , lo , hi-1, pivot );
* median location method
private int medianLocation(int [] a , int i , int j , int k )
if( a[i]<= a[j] )
if ( a[j]<= a[k])
return j;
else if(a[i] <= a[k])
return k ;
return i;
else // a[j] < a[i]
if ( a[i] <= a[k])
return i;
else if (a[j]<= a[k])
return k;
else return j;
* Quick Sort
private void quicksort(int [] a , int lo , int hi)
int m;
if (hi>lo+1) // there are at least 3 elements , sort recursively
m=partition(a,lo,hi);
quicksort(a , lo , m-1);
quicksort(a , m+1 , hi);
else //1,2 or 3 elements , sort directly
if( hi ==lo+1 &&a[lo] >a[hi] )
swap(a , lo , hi);
* binary search for num in an ordered array
private int binary(int [] data , int num) //binary search for num in an ordered array
int middle , lower=0 , upper=(data.length-1) ;
do
middle=((lower + upper)/2);
if (num < data[middle])
upper = middle-1;
else lower = middle+1;
while ( ( data[middle] != num) && (lower<= upper)); // postcondition : if data[middle] isn't num
if(data[middle] == num)
return middle;
else return -1;
* whhhhhhhhhhhhhhhhatttttttttttt
public boolean what(int [ ] other )
if(_arr.length != other.length)
return false;
quicksort(_arr , 0 , _arr.length-1);
quicksort(other , 0 , other.length-1);
boolean f=false;
for(int i=0 ; i<_arr.length ; i++)
if((binary(_arr , other[i])== (-1)) && (binary(other, _arr[i])==(-1)))
return f;
else f= true;
return f;
public class Tester1
public static void main (String[] args)
IntVector aaa = new IntVector(10);
aaa.addInt(5,0);
aaa.addInt(55,1);
aaa.addInt(89,2);
aaa.addInt(15,3);
aaa.addInt(3,4);
aaa.addInt(8,5);
aaa.addInt(785,6);
aaa.addInt(78,7);
aaa.addInt(99,8);
aaa.addInt(512,9);
IntVector intArr1 = new IntVector(3);
intArr1.addInt(5,0);
for(int i=0 ; i<3; i++)
intArr1.addInt(i+1 ,i);
int[] bbb= {15,89,55,5,3,8,785,78,96565,512};//new int [10];
System.out.println(aaa.what(bbb));
// int[] ccc = {1,3,2};
// System.out.println(intArr1.what(ccc));
