בעיה עם uigetfile ב-Matlab R2007a
שלום,
יש לי בעיה עם הפונקציה uigetfile ב- Matlab R2007b
אני כותב:
a=uigetfile('*.txt','title','c:\nvidia\')
ומקבל:
??? Java exception occurred:
java.lang.ArrayIndexOutOfBoundsException: Array index out of range: 5
at java.util.Vector.get(Unknown Source)
at javax.swing.plaf.basic.BasicDirectoryModel.getElementAt(Unknown Source)
at javax.swing.plaf.basic.BasicListUI.updateLayoutState(Unknown Source)
at javax.swing.plaf.basic.BasicListUI.maybeUpdateLayoutState(Unknown Source)
at javax.swing.plaf.basic.BasicListUI.getCellBounds(Unknown Source)
at javax.swing.JList.getCellBounds(Unknown Source)
at javax.swing.JList.ensureIndexIsVisible(Unknown Source)
at sun.swing.FilePane.ensureIndexIsVisible(Unknown Source)
at sun.swing.FilePane.doDirectoryChanged(Unknown Source)
at sun.swing.FilePane.propertyChange(Unknown Source)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at java.awt.Component.firePropertyChange(Unknown Source)
at javax.swing.JFileChooser.setCurrentDirectory(Unknown Source)
at com.mathworks.mwswing.MJFileChooser.setCurrentDirectory(MJFileChooser.java:167)
at javax.swing.JFileChooser.setSelectedFile(Unknown Source)
at com.mathworks.mwswing.MJFileChooserPerPlatform.setSelectedFile(MJFileChooserPerPlatform.java:377)
Error in ==> AbstractFileDialog.AbstractFileDialog>AbstractFileDialog.setPeerCurrentFile at 172
obj.Peer.setSelectedFile(java.io.File([aPathName, filesep], aFileName));
Error in ==> UiFileOpenDialog.UiFileOpenDialog>UiFileOpenDialog.show at 40
setPeerCurrentFile(obj);
Error in ==> uitools\private\uigetputfile_helper at 46
ufd.show();
Error in ==> uigetfile at 125
[filename, pathname, filterindex] = uigetputfile_helper(0, varargin{:});
האם אני עושה משהו לא נכון או שמדובר בבאג ב-Matlab? אני משתמש בגרסאת 64bit בוינדוס ויסטה פרמיום 64.
