בעיה מוזרה מאוד ב- HD , עזרה בבקשה , אנגלית
hi
i got an Hard-Disk problem.
ok , here is the problem
i got 6.4 western digital UDMA HD (a little old , yes)
lately , i noticed that all the time when i am installing a game , i got the pop-up
window thats tells me that there is not enough disk space.(and its give me the options where i
can delete TMP files or from the recycle ).
but in a matter of fact i got a lot of free space.
when i got 4.0 gb avilable space and trying to install a 500mb game , the pc tells me that i dont have
free disk space and all over again.
just for you to know : the HD NEVER made any problems and working till now GREAT , and
in the setup bios all ok and hd setting correctly .
so , i decided that its a virus .
scan the PC for viruses with norton anti-virus 2002 and got 60 viruses.
delete all and pc was clean , still the same problem
so i did this :
FDISK , FORMAT and install win98se again.
now all looked ok until i install a program that shows me the available space on disk ,
and its showing me 2.3 GB FREE ONLY !!!
but if i right click and properties on C:\ i see i got 5.9 GB !!!!
i hope you understand the problem i got and you can help me .
P.S : can it be a virus that attacks the HARDWARE ?
or maybe a LOW LEVEL FORMAT can help here ?
Please if you have any idea , i need HELP here !
Thank you in advance
Tochkel.
first of all do fdisk again and delete all the partitions.
than set it to the maximum disk space available.
restart.
format c:
First, I think you should improve your English. Take a private teacher or something, but the easiest and cheapest way to go is write in Hebrew. ESPECIALLY IF YOU DO NOT KNOW ENLGLISH!!!
restart.
format c:
Don't forget to clean the master boot record:
fdisk/mbr
