Gears Of War - הדיון הראשי
האמת לא נראה לי שאפשר להתכופף מבלי להיות תחת מחסה, אני גם לא רואה סיבה לעשות זאת, אם רוצים להמנע מאש באיזור שחשוף פשוט צריך לעשות את הריצה המהירה (שהיא באמת פאקינג מהירה) עד שמגיעים למחסה וזה הכל.
  • תגובות 553
  • צפיות 80.4k
מישהו יודע מה גורם לדרופים ללא שום סיבה 60 אפ פי אס קבוע אבל תקיעות במעבר חדרים
amd 5200 dual oc 3 ghz
8800 X2 gts 640
4 גיגה זיכרון פנימי
הנה הסבר למה יש לך דרופים .
Stutter Fix......Fixed.
All that poohoo about tweak this or replace that only does one thing and that is to reduce the texture quality. That in itself is a clue to what the problem is....fill rate.
It doesn't matter if your card can render the Planet at 1000 frames if it hasn't got the video ram it'll stutter and cache as the ram tries to keep in time with the gpu.
The only reason people are having issues with the game is either they are not reading the relevant information or they are trying to select a graphics setting that is beyond their machines capabilities.
The stuttering is purely down to the texture setting. I noticed this as selecting a lower screen resolution plus Highest detail textures fixed the stuttering. Hence I was no longer hitting my graphics card's fill rate. The other settings my card can render no problem but if I want higher resolutions then I have to reduce the texture resolutions as well or the stuttering returns.
As it stands for me at 1280x1024, medium texture is preferred on a 512 meg card.
I'd say high texture is for 768 meg cards
highest texture is for 1024 meg cards or the SLI'd GTX monster card crowd.
It isn't drivers either as I'm still using 7.4 and I'm hitting 50 frames
v-sync enabled
all settings high
Textures medium
16xAF
-2 lod setting
all on a Athlon 64 3800
2gig ram
x1950 pro 512
One thing that may throw people is every time you change the texture setting you have to reload the game even though it doesn't say to do so.
Wouldn't mind but even at medium textures the game looks phenomenal as they are rendered at 1024x1024.
I've not seen graphics this good on my PC.
http://img144.imageshack.us/img144/3136/67684558nk8.jpg
מישהו יודע מה זה?
כשאני לוחץ על HOME אז נפתח לי החלון של ליצור משתמש ללייב,אבל כשאני יוצא ממנו זה מה שיש לי בתור תפריט.
תודה לעוזרים!
אין לי מילים, המשחק פשוט אדיר!
בהתחלה חשבתי שהשליטה קצת מסובכת, אבל אחרי שהתחלתי לשחק הכול השתנה.
אני לא זוכר שנהנתי כול כך הרבה מסינגל פלייר של משחק מאז RE4.
יש אפשרות לשמור את המשחק באמצע?
אהבתי את המסור שיש על הרובה, כשחותחים מפלצת אתה באמת מרגשי שאתה חותך מפלצת (חסר לי הרעידות בשלט אבל לא נורא)
RE4 (למחשב) היה אחד המשחקים הנוראיים ביותר שאי פעם ראיתי
משחק מעולה באמת מעולה אבל יש כמה בעיות טכניות כרגע שכול עוד הן קיימות לא נראה שבאמת יהיה אפשר להנות מהמשחק הזה:
1. CTD's - אני יודע על ה"פיתרון" של ALT+TAB אבל זה לא פיתרון אמיתי לבעייה.
2. בעיית הגמגומים - אם צריך 512 מגה במסך למה לא לכתוב את זה בדרישות ???
צריך 512 זיכרון בכרטיס מסך? אז תוריד בזולציה אם יש לך רק 256 .
הורדתי את הTEXTURE מHIGH לMEDIUM וזה פתר את הבעייה אבל אני לא מבין למה זה לא יכול לרוץ על HIGH כמו UT3 אם זה אותו מנוע ??
לפי מה שרשום כאן בדף קודם, 512 זיכרון מתאים לטקסטורות ברמה בינונית, בשביל מקסימום מומלץ 768? או אפילו 1024? מעניין .... בכל מקרה גם בטקסטורות בינוניות אומרים שהמשחק נראה מדהים! :xyxthumbs:
קראתי את הדיון שבו מצאו את הפיתרון הזה :
http://utforums.epicgames.com/showthread.php?t=583716&page=3
ומישהו אחר כתב שם שזה נראה יותר כמו בעייה של קוד :
Some parts were helpful. Except the part about texture settings and video RAM. That's a load (in certain setups). I have an EVGA 8800GTS 320DDR2 RAM Overclocked GPU and I can run BioShock and UT3 on the highest of settings while recieving a constant 60FPS. Even Gears with everything on the highest settings and res at 1440x900 I get 60FPS constant, except for when the game loads assets on the fly then it drops to 20FPS for an instant.
And to throw another wrench into your GPU theory, the game has the same performance hiccups at the same asset load points even with everything on low, set to DX9 and res at 800x600. So what would be the cause of that? I sure as hell have got no clue, other then it's something with the load code itself.
*any anger in this post really isn't directed at you T3TSUO, it's just aggrevation with the game, seriously*
Intel Dual-Core 6600
3Gigs DDR2 Kingston RAM
EVGA GeForce 320DDR2 Overclocked
300Gb 7200 SATA HDD
והאמת שראיתי עוד פיתרונות מוצעים שאני הולך לנסות בבית:
http://utforums.epicgames.com/showthread.php?t=583504&page=2
http://forums.epicgames.com/showthread.php?t=583629&page=3
כול אחד והטעם שלו.
לפי דעתי RE4 ל PS2 הוא עדיין ה SCI-FI SHOOTER הטוב ביותר שיצא בשנים האחרונות.
זה רק אני, או שהמשחק די חד-גוני?
לא רואה שם שום דבר פורץ דרך.
ולא מבין כל ההייפ הזה מסביבו.
זה רק אתה, לפי דעתי המשחק מצוין.
השליטה ממש מכניסה כיף למשחק.
משהו יכול להביא לי על הcheck point הראשון בבקשה?
כל פעם שאני נכנס למשחק ורואה את הסרטון המשחק קורס לי...
בבקשה משהו יכול לעלות את ה-check point הראשון במשחק, תודה רבה
