פורסם 2003 במרץ 1423 שנים מחבר לקחתי את זה מsandra:SiSoftware SandraComputer SystemManufacturer : ECSModel : M920Version : 1.0Serial Number : 00000000Unique ID : 00000000-00000000-00000000-00000000System ChassisManufacturer : ECSCase Type : DesktopCan be locked : NoVersion : 1.0Serial Number : 00000000Asset Tag : 0123ABCSystem MainboardManufacturer : ECSMP Support : NoModel : M920Version : 1.0Serial Number : 00000000BIOS ID : 62-1016-001437-00101111-040201-VIAMemory ControllerError Detection Method : 32-bit ECCError Correction Capability : 1-bitSupported/Current Memory Interleave : 1-way / 1-wayNumber of Memory Slots : 4Maximum Installable Memory : 4096MBMaximum Module Size : 1024MBSupported STD/FPM/(B)EDO Speeds : 70ns, 60nsSupported Memory Types : STD, FPM, EDO, Parity, ECC, SIMMSupported Memory Voltages : 3.3VPhysical/BIOS Memory BanksDIMM1 (RASL-1 RASL-0) : 256MB DIMM SDRAM single-bankDIMM2 : EmptyDIMM3 : EmptyDIMM4 : EmptySystem ChipsetModel : VIA Technologies Inc VT8753 Apollo P4X266 System ControllerBus(es) : ISA AGP USB SMBus/i2c Front Side Bus Speed : 4x 100MHz (400MHz data rate)Max FSB Speed / Max Memory Speed : 4x 100MHz / 1x 133MHzIn Order Queue Depth : 8 req(s)Chipset Hub InterfaceType : V-LinkWidth : 8-bitFull Duplex : YesMultiplier : 1xSpeed : 4x 66MHz (264MHz data rate)Down / Up In Order Queue Depth : 9 / 9 req(s)Logical/Chipset Memory BanksBank 0 Setting : 256MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CLSpeed : 1x 100MHz (100MHz data rate)Multiplier : 1/1xPower Down Mode : NoFixed Hole Present : NoMemory Module(s)Memory Module 1 : 256MB 8x(32Mx8) SDRAM PC133U-333-542 (CL3 upto 133MHz) (CL2 upto 100MHz)Environment Monitor 1Model : ITE IT8705/12 ISAMainboard Specific Support : NoTemperature Sensor(s)Board Temperature : 37.0°C / 100.4°FCPU Temperature : 33.0°C / 91.4°FPower / Aux Temperature : 46.0°C / 109.4°F tdCooling Device(s)Auto Fan Speed Control : NoCPU Fan Speed : 3750rpmVoltage Sensor(s)CPU Core Voltage : 1.76VAux Voltage : 2.51V+3.3V Voltage : 3.34V+5V Voltage : 5.19V+12V Voltage : 11.79V-12V Voltage : -11.04V-5V Voltage : 3.29VStandby Voltage : 5.16VBattery Voltage : 3.41VAGP BusVersion : 2.00Speed : 66MHzCurrent Data Transfer Rate : 4x 66MHz (264MHz data rate)Side Band Enabled : NoSide Band Support : YesFast-Writes Enabled : NoAperture Size : 64MBLPC Hub Controller 1Model : VIA Technologies Inc VT8233 PCI to ISA BridgeACPI PM Enabled : YesRandom Number Generator Enabled : NoMultiplier : 1/4xSpeed : 8MHzDMA Multiplier : 1/2xDMA Speed : 4MHzUSB Controller 1Model : VIA Technologies Inc VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)Version : 1.10UHCI Interface : YesChannels : 2Speed : 48MHzLegacy Emulation Enabled : NoUSB Controller 2Model : VIA Technologies Inc VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)Version : 1.10UHCI Interface : YesChannels : 2Speed : 48MHzLegacy Emulation Enabled : NoUSB Controller 3Model : VIA Technologies Inc VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)Version : 1.10UHCI Interface : YesChannels : 2Speed : 48MHzLegacy Emulation Enabled : NoSystem SMBus Controller 1Model : VIA VT823x SMBusSpeed : 16kHzExpansion Slot(s)PCI1 (1h) : PCI 32-bit 3.3V Shared PME FullLength Available (VIA Technologies Inc VT8633 Apollo Pro 266 CPU to AGP Controller)PCI2 (2h) : PCI 32-bit 3.3V Shared PME FullLength InUsePCI3 (3h) : PCI 32-bit 3.3V Shared PME FullLength AvailablePCI4 (4h) : PCI 32-bit 3.3V Shared PME FullLength AvailablePCI5 (5h) : PCI 32-bit 3.3V Shared PME FullLengthPort Connector(s)USB - Def : SSA SCSI - Mini Centronics / DB25 pin male
פורסם 2003 במרץ 1423 שנים איזה מעבד יש לך ? אני לא יתכיל להגיד לך מושגים כמו SOCKET 478 אולי אתה לא יודע אז אני יגיד הגדול שזה הישנים או החדשים הם הקטנים?
פורסם 2003 במרץ 1423 שנים מחבר אתה יכול להסתכל במפרט שלי. וכתהתי איזה socket. תגידו אתם עושים לי דווקא? באמת אני מעריך את העזרה אבל אתם שואלים את אותם שאלות. אתה כאילו מגיעים איתי עד לסוף ושב עוזבים אותי! נו בחיית מישהו שישאר איתי מההתחלה עד הסוף!.
פורסם 2003 במרץ 1423 שנים שמע אף אחד פה לא עושה לך דווקא ולא כתבתה איזה סוקט המעבד שלך במפרט לפחות אני לא רואה.הלוח שלך זה חברת ECS eilte group אבל אני צריך לדעת איזה סוקט בשביל למצוא לך ביוס.
פורסם 2003 במרץ 1423 שנים תשמע אחי לך לאיזה טכנאי מחשבים שאתה קניתה מהם את המחשב והם יסדרו לך אותו כי להם יש יותר ידע אחי מקסימום הכרטיס לא עובד יש לך אחריות .תבדוק טוב כי לא נראה לי שהספק לא טוב או אולי הספק חלש ולא מגיע אליו מתחים טובים לכרטיס ואז זה עושה בעיות
פורסם 2003 במרץ 1523 שנים תשמע אחי לך לאיזה טכנאי מחשבים שאתה קניתה מהם את המחשב והם יסדרו לך אותו כי להם יש יותר ידע אחי מקסימום הכרטיס לא עובד יש לך אחריות .תבדוק טוב כי לא נראה לי שהספק לא טוב או אולי הספק חלש ולא מגיע אליו מתחים טובים לכרטיס ואז זה עושה בעיות עכשיו בזה אתה טועה ובגדול מה שבטוח ידע יותר אין אולי יהיה לו את היתרון שהוא רואה את הלוח מול העיניים.
פורסם 2003 במרץ 1523 שנים תראה איזה מהלוחות האלו הם שלך:1).http://www.ecsusa.com/products/p4vxas.html2). http://www.ecsusa.com/products/p4vxasd.htmlאני מהמר שיש לך את השני כי אמרתה נרא לי שיש לך גם סלוטים של זיכרנות SDRAM וגם DDRAM.אם כן אז הביוס זה זה:http://www.ecsusa.com/downloads/bios/p4vxasd2020627.exeאל תיקח אותי במילה כמובן תבדה שזה הלוח ב100 אחוז.מקווה שזה עוזר.
פורסם 2003 במרץ 1523 שנים מחבר האמתי שזה ממש הלוח שלי. הכל כמו שצריך אבל עדיין שלי אדום יפה. בצבע של ה-radeon(אחת מהסיבות שבחרתי ב-ati ;D)
פורסם 2003 במרץ 1523 שנים לא יודע מה להגיד לך זה הלוח היחידי שיש לו SDRAM ו DDR וCHIPSET של VIA באתר .ואם זה לא מתאים לך לך לחנות שהם יבדקו לך ויעשו לך שידרוג ביוס כי אם הם יהרבו אז יהיה אל אחריותם.
פורסם 2003 במרץ 1523 שנים מחבר זה בול הלוח שלי! בכל כמו שצריך רק שלי הוא אדום ולא סגול. ואיך מתקנים כזה דבר?.
