דריברBETA חדש של Nvidia (ל-XP) שוחרר - 162.18
תמהרו להוריד :) בקרוב מאוד יהיה גם לויסטה.
http://www.nvidia.com/object/winxp_2k_162.18.html
This is all the geforce 8 series fixes in the driver release notes
Changes in Version 162.18
Fixed IssuesWindows XP 32-bit
Fixed Single-GPU Issues
Geforce 8 Series GPU's
The NVIDIA Control Panel crashes when closing the nTune
ʺNVPerformance Benchmarkʺ.[299621]
GeForce 8800 GTX: NVIDIA Control Panel ʺResize HDTV Desktopʺ
(overscan compensation) sliders do not maintain their settings.
[289632]
This issue is fixed with an NVIDIA‐provided workaround to enable overscan
compensation and allow the Resize HDTV Desktop sliders to work properly.
See NVIDIA Knowledgebase Article #2064 for instructions.
GeForce 8800 GTX: 1680x1050 resolution is not available when using
the Dell 3007WFP monitor. [284181]
GeForce 8800 GTX/GTS: Flat‐panel scaling doesnʹt work with widescreen
monitors. [309707]
GeForce 8800 GTX: After changing the HDTV component format, the
display either turns blank or reverts to the previous format.[279287]
GeForce 8800 GTX: This task cannot be opened now ... message
appears when clicking the NVIDIA Control Panel ʺRun multiple
display wizardʺ navigation link after clicking the ʺAdjust video color
settingsʺ navigation link.[298477]
GeForce 8800 GTX: Elder Scrolls: Oblivionanimation is visible
through the trees when HDR and NVIDIA Control Panel antialiasing
are enabled. [296265]
GeForce 8800 GTX: S.T.A.L.K.E.R.the crosshair is missing when
antialiasing is enabled. [308826]
GeForce 8800 GTX: Far Cryblue‐screen crash occurs after playing the
game for awhile.[301780]
GeForce 8800 GTX, GeForce 7900 GTX/7300 GS: Ghost Recon
Advanced Warfighter 2 the game fails if you try to change settings
right after the loading a mission. [308576]
GeForce 8800 GTX: Lost Planet: Extreme Condition the game crashes
after the player destroys some objects in mission 01. [302251]
GeForce 8600: The NVIDIA Control Panel ʺSetup multiple displaysʺ
page reverts back to the ʺAdjust image settings with previewʺ page
after running 3DMark05.[297180]
GeForce 8600: Rainbow Six Vegasthe game does not start when
antialiasing is set to 8x, 8xQ, or 16x.[298195]
GeForce 8600 GTS, GeForce 8500 GT: Hot‐key switching between the
internet games Mir 2 and My causes the screen to go blank, requiring a
hard reboot. [325400]
GeForce 8500/8400/8300: Could not create the Direct3D device
message appears when previewing a 3D screen saver in Dualview
mode.[299992]
GeForce 8600: On closing the NVIDIA Control Panel, the display
configuration automatically switches from Clone mode to Singledisplay
mode.[303542]
GeForce 8500/8400/8300: The NVIDIA Control Panel Resize HDTV
Desktop navigation link does not work consistently.[301312]
GeForce 8500/8400/8300: With the resolution set to 1080i, the desktop
cannot be changed from Dualview mode to Clone mode.[300058]
GeForce 8 Series GPUs SLI mode
[sLI], GeForce 8800 GTX: SLIAA doesnʹt turn off after switching back
to application controlled under the NVIDIA Control Panel‐
>Manage 3D Settings page‐>Antialiasing‐Mode setting.[293282]
[sLI], GeForce 8800 GTX: Blue‐screen crash occurs when enaling SLI
mode with a second monitor connected to the slave GPU.[298438]
[sLI], GeForce 8800 GTX: After enabling SLI mode, the SLI animation
on the NVIDIA Control Panel Set SLI Configuration page
disappears.[295415]
[sLI] GeForce 8800 GTX: Titan Questwith V‐Sync disabled, there are
horizontal black lines during the intro video. [260416]
[sLI], GeForce 8800 GTX: Splinter Cell:Double AgentSLI mode does
not work when the game is run through the front end launcher.
[298601]
[sLI], GeForce 8800 GTX: Dungeon Siege 2there is a block of
corruption around the mouse cursor.[297306]
[sLI], GeForce 8800 GTX: Elder Scrolls: Oblivionvisual indicators do
not display the correct information when SLI AA is enabled.[296267]
[sLI], GeForce 8800/8600: Act of Warthe cursor flickers when playing
the game in multi‐GPU AFR modes.[221369]
[sLI], GeForce 8500/8400/8300: The NVIDIA Control Panel crashes
after resuming from 3D screen saver preview in Dualview
mode.[302725]
Fixed IssuesWindows XP 64-bit
GeForce 8500/8400/8300: There is corruption on the NVIDIA Control
Panel ʹChange flat panel scalingʹ page after changing the display]
from DFP to CRT.[296837]
GeForce 8500/8400/8300: 400: The NVIDIA Control Panel Apply and
Cancel buttons are present on the ʺResize HDTV Desktopʺ page when
no settings have been changed.[298515]
mode.[299992]
this is all the known issues with geforce 8 series in driver release notes
NVIDIA IssuesSingle GPU
All GPUs
HDCP cannot be enabled with the Dell 30 flat panel on resolutions
higher than 1280x800, which prevents playback of HD DVDs or Bluray
discs. [328561]
The NVIDIA Control Panel Run Display Optimization Wizard back
button does not work.[302285]
DVI display is blurry with normal display timing settings.[282940]
The blurriness does not occur if Treat as HDTV is selected and then CVT
advanced timings are used.
Battlefield 2: Corruption and flickering occur in the grass when video
settings are set to High.[272027]
Star Wars: Republic Commando: Application crashes when starting a
new game.[254010]
Dark Messiah of Might and Magiclight flickers on the weapons and
characters, and the system freezes after a period of gameplay.[ 260689
260335 260315 262958]
FEARreflection in the puddle flickers.[259670]
There is no display in Clone mode when TV is switched from
Component to Composite.[259390]
NVIDIA Control Panel Category Pages: Foreign language text
exceeds the boundary of category windows.[234800]
NVIDIA Control Panel Category Pages: Japanese translation issues
exist in the menu options.[257063]
GeForce 8 Series, GeForce 6600: HQV DVD shows corruption when
played using Windows Media Player.[302235]
GeForce 8800 GTX: Video frame freezes while audio continues when
playing H.264 HD titles using PowerDVD.[325436]
GeForce 8800 GTX: The system hangs after playing a Blu‐ray disc for
awhile using PowerDVD. [318755]
GeForce 8800 GTX: Blue‐screen crash occurs when changing
resolutions while Direct3D, OpenGL, and video applications are open
at the same time.[262074]
GeForce 8800 GTX: When connecting HDTV mode and setting the
resolution to 1080p, there is no TV output.[270122]
GeForce 8800 GTX: nTune (5.05.38.00) GPU fan control settings are
not available (grayed out). [308669]
GeForce 8800 GTX: nTune (5.05.38.00) GPU fan control settings revert
to previous settings when applied.[308683]
GeForce 8800 GTX: Star Wars: Battlefront 2there is corruption during
the training mission when played at high resolutions. [310721]
GeForce 8800 GTX: Sid Meierʹs Railroads!during gameplay, the
driver crashes or the application freezes.[297044]
GeForce 8800 GTX/GeForce 7900 GTX: Neverwinter Nights 2the
minimap loses its background when the resolution is
changed.[273788]
GeForce 8800 GTX: Dungeon Siege 2the mouse cursor is laggy and
jittery when CSAA is enabled.[297301]
GeForce 8600: Jaggies appear during de‐interlace video playback
using Windows Media Player. [301769]
GeForce 8600 GT/GS: When attempting to set the HD mode to 576i,
the resolution switches to 480i instead. [275079]
GeForce 8600: Dropped frames occur with high bit‐rate HD DVD or
Blu‐ray disc H.264 titles. [324963]
GeForce 8600 GT: Call of Duty 2the game crashes under the
following settings: in‐game settings of 1920x1200 resolution and 2x
antialiasing, NVIDIA Control Panel enhanced antialiasing mode set to
16xQ. [312949]
GeForce 8600: Rise of Nations:Rise of Legendsthe game crashes to
the desktop when the resolution is set to 1920x1200 and antialiasing is
set to Medium from the game control panel.[298503]
GeForce 8600: Thief Deadly Shadowsthere is texture corruption
when using the game control panel default settings.[299579]
GeForce 8500/8400/8300, GeForce 7300 GT: After switching from
Dualview mode to VGA single‐display mode, the output appears on
the DVI in signle‐diaplsy mode. [327042]
GeForce 8 Series GPUs SLI Mode
[sLI], GeForce 8800 GTX: The SLI visual indicators for some SLIAA
modes do not match the NVIDIA Control Panel settings. [327393]
[sLI], GeForce 8800 GTX: The SLI visual indicators for SLI16xS
antiliasing displays 16xQ antialiasing instead. [327398]
[sLI], GeForce 8800 GTX: Stalkerwith SLI mode enabled, the game
performance does not improve by much.[306807]
[sLI], GeForce 8800 GTX: Half‐Life 2 Episode 1with SLI mode
enabled, purple textures appear with 16xQ CSAA enabled at
2560x1600 resolution.[302602]
[sLI], GeForce 8800 GTX: Far Crythere is a flickering/shifting sky in
the Research level when SLI mode is enabled.[265091]
[sLI], GeForce 8800 GTX: Neverwinter Nights 2 flickering occurs
between screen transitions when SLI is enabled.[296352]
[sLI], GeForce 8600: The SLI Load Balancing indicator does not
appear when invoked. [311894]
[sLI], GeForce 8600: Blank display with corruption occurs when
resuming from system standby. [295619]
[sLI], GeForce 8600 GT: Far Crythere are flickering patches when
moving around within the game. [324450]
[sLI], GeForce 8600: 3DMark06the benchmark crashes to the desktop
when run at 1600x1200 resolution and with 8x antialiasing enabled.
[324430]
[sLI], GeForce 8600: Splinter Cell Double Agentthe game crashes to
desktop at 1600x1200 resolution and with 32xQ SLIAA
enabled.[306223]
[sLI], GeForce 8600: Half Life 2white patches appear in the sky when
8xAA is enabled from the NVIDIA Control Panel (Enhanced mode) in
conjunction with 2xMSAA enabled from the game control
panel.[306259]
[sLI], GeForce 8500/8400/8300: Blue‐screen crash occurs when
resuming from standby mode while an OpenGL demo is running.
[317880]
תודה על הידיעה!!
מישהו ניסה אותו?
יש שיפור מסויים במשחקים?
בבקשה :xyxthumbs:
אצלי הוא מותקן עכשיו, הכל תקין ועובד.
לא מזמן הם שיחררו 162.16, הורדתי, התקנתי, ואז הם החליטו להסירו זמנית מהאתר עקב בעייה שהיתה לו. לפי מה שזכור לי (ומה ששמעתי) היה שיפור מסויים במשחקים. אחד המשחקים שלי נתן BSOD עם 162.16 אבל ה-162.18 החדש סידר את הבעייה. יש לי הרגשה טובה בקשר אליו :)
אני לא רואה שום שיפור בדרייבר, ההפך.
במשחקים נגיד קונטר סורס ואלה, אני קובע 100FPS, ואני מרגיש את הכוונת זזה כמו על 60FPS לא טסה כזה, וגם רואים כזה כמו בלי AA.
קיצר אני מתקין את הדרייבר הרישמי.
אני לא ממהר להוריד... בייחוד בגלל שכרגע אין לי שום צורך בו (: ה8800 שלי עושה עבודה פנטסטית בינתיים...
עוד דרייבר שתוכנן רק למשתמשי גיפורס 8, למרות שכלולים שם כל כרטיסי המסך מסדרת הFX, האופטימזציה נעשתה לכיוון הגיפורס 8 בלבד, עם ה7600GT לא הרגשתי שום הבדל אפילו אולי פחות, חזרתי ל100.12.
מה ז"א "קובע 100FPS" ? ואיך אפשר להרגיש כוונת זזה על 60? אתה בכלל רואה כמה FPS אתה מקבל? אולי אתה באמת על 60 כי Vsync פועל ? אם יש לך בעיית mouse lag פשוט תוריד את ערך ה-Pre-render ל-1 או 0. זה דיי משמעותי כש-vsync פועל.
בכלליות, עם כרטיס כזה מומלץ שתשחק עם Vsync ב-Source. התמונה זזה יותר חלק\נעים לעיין. אם יש לך LCD גם ככה לא תקבל יותר מ-60FPS ואם יש לך CRT אז למה אתה צריך יותר מ-85/75 ? עדיף 85 עם vsync מאשר 100 בלי!
ואתה לא רואה AA? מוזר אצלי הכל תקין... אולי תעבור על הגדרות הדריבר שלך מחדש, אני ממליץ על nHancer.
אני מרגיש את הכוונת כבדה, וליפעמים זזה לי לאט כמו 800DPI שאני על 1600DPI.
וגם אפור חלש רואים לבן וזה מכער את המשחק.
אני יצלם תמונה ותיראה לך.
בקרבון אני רואה ירידה של 2-5FPS, דרייבר בטה וכניראה ישאר ככה הרבה זמן.
ואני רוצה 100FPS, כי הריקול של החירור יותר טוב פשוט, לא כי אני מיוחד ורואה ככה.
אתה שחקן CS? אני משאר שלא.
אתה חייב תגובה מהירה של המחשב\שלך ועם זה הכוונת, כלומר אני מרגיש כמו דיליי עם העכבר לכוונת במשחק שאני על 60FPS.
אני דווקא משחק CSS. אני משחק עם Copperhead על 2000dpi. סמוך עלי שכבר חפרתי מספיק בתחום.
אני לא מבין אותך, אתה משחק עם או בלי Vsync ? מה ה-refresh rate ? מה ערך ה-pre-render בדריבר ?
אני משחק על 85FPS קבוע עם vsync. הורדתי pre-render ל-"1" גלובלי, אין דיליי בכלל. הכל פרפקט ובדוק 100%.
זה הכל הגדרות - אני תמיד מתגבר על "תופעות לוואי" כאילו. אבל אם אתה לא מנסה להתמודד לא תשיג תוצאות.
ד"א, אתה חושב שיש הבדל בין 100FPS ל-85FPS נגיד, מבחינת אופן החירור ?? תסביר.
לא הבנת אותי, בדרייבר 158.22 הרשמי, המשחקים בכללית כולם עובדים כמו שצריך, שאני מתקין את הגירסה 162.18 יש לי ירידת FPS, עיווט צבעים, ובעיית איטיות בעכבר כמו דילי עם הכוונת, ה-V-sync מכובה, ואני תמיד איתו מכובה.
אנשים טוענים שככל שיש לך יותר FPS ב1.6 זה משפיע בצורה כלשהיא על הייריה (שטויות)
ה FSP לא משפיע על החירור. זה בראש שלו :screwy: הדבר היחיד שה FPS משפיע עליו זה כמה התמונה תתחלף חלק, אם ה FPS קבוע מעל 60 אתה לא תרגיש הבדל בכלל לא משנה איזה מספר יהיה כתוב לך. ברוב המקרים המסכים בכל מקרה לא יציגו יותר מ 60FPS :kopfpatsch:
תשחק על 40 FPS ב CS 1.6 ותחורר תראה שיש הפרשי זמן קטנים בין כדור לכדור שאתה יורה.
ב 60 FPS באמת יש דיליי כזה, זה קרה לי ששכחתי לכבות את ה Vsync.
תנסה לשחק עם Vsync ובלי Vsync ותראה שיש הבדל גדול.
כמו שאמרתי, בכדי לתקן את הדיליי לעכבר יש להוריד את ערך ה prerender limit (*גלובלי* - חשוב)
http://www.nhancer.com/?dat=d_optimizations#Prerender
ואז אפשר לשחק בכיף גם עם Vsync.
ואם יש לו LCD, אכן הוא בכלל לא מציג יותר מ-60FPS, עם ובלי vsync :lol: עם LCD כבר עדיף לשים Vsync, חבל על ה-"קריעת תמונה".
אני עם CRT, אני רואה בדיוק את ההבדלים ב-FPS. חמקן אתה מקסימום יכול לראות את המס' המוצג ב-FRAPS, לא יותר מזה.
בכל מקרה, אני מרוצה מהדריבר החדש.
60FPS אין שום דבר אני משחק ב CS כמה שנים בדקתי את זה.
40FPS ברור שיהיה כי צריך 60 בשביל תמונה חלקה, מי בכלל דיבר על FSP שנמוך מ 60 :P
כמו שאמרתי ברוב המקרים המסך לא מציג יותר מ 60FPS :xyxthumbs:
