למישהו יש הסבר קצרצר על אופציית C1E ו-EIST ?
מה ההבדל בינהם ? מתי אני רוצה או לא רוצה להפעיל אותן ? מי עדיפה ? מה ההבדל בינהם ?
חיפשתי מידע בגוגל, מצאתי הרבה על EIST אבל כמעט כלום על C1E... אשמח למידע או הסבר קצרצר...
מצאתי הסבר ישן על מעבד סלרון שהכיל הסבר על ה C1E:
Extended Halt State (C1E)
The Intel® Celeron® Processor 1.66 GHz/1.83 GHz Extended Halt State (C1E) enables
significant power savings. Extended HALT state is a low power state entered when the
processor core has executed the HALT or MWAIT instructions and Extended HALT state
has been enabled via the BIOS. When the processor core executes the HALT
instruction, the core is halted. The Extended HALT state is a lower power state than the
HALT state or Stop Grant state.
Note: The Extended HALT (C1E) state must be enabled for the processor to remain within its
specifications.
The Extended HALT state requires support for dynamic VID transitions in the platform.
The processor automatically transitions to a lower core frequency and voltage operating
point before entering the Extended HALT state. Note that the processor FSB frequency
Intel® Celeron® Processor 1.66 GHz/1.83 GHz—Low Power Features
is not altered; only the internal core frequency is changed. When entering the low
power state, the processor first switches to the lower bus to core frequency ratio and
then transition to the lower voltage (VID).
While in the Extended HALT(C1E) state, the processor processes bus snoops. The
processor exits the Extended HALT state when a break event occurs. When the
processor exits the Extended HALT state, it first transitions the VID to the original value
and then changes the bus to core frequency ratio back to the original value.
אם אני ימצא משהו על EIST אני יעדכן..
מצאתי הסבר קצת ארוך של אינטל..
http://www.intel.com/cd/channel/reseller/asmo-na/eng/203838.htm
