Starcraft 2 - כל הפרטים כאן
רוצה לשחק? ותעלה replays אני מעלה את שלי עכשיו בHD לYoutube, יש לציין שלא שיחקתי בSC1 ברשת ככה שאני רחוק מלהיות טוב במיוחד...
  • תגובות 926
  • צפיות 124.7k
דובי-כן, ה"פ עם פרטים בדרך אליך.. :cool2:
Kidney_stonE - אתה מוכן בבקשה לענות על השאלה שהעלתי?
גם חבר של חבר שלך משחק בSCII או רק אתה? [עם אותו המשתמש - כדי לדעת אם זה אפשרי לשחק ממחשבים שונים עם אותו משתמש בו זמנית / או לסירוגין]
תודה.
כבר עניתי על זה בעמוד הקודם...
טעות שלי.
סליחה.
פאטצ' חדש.
StarCraft II Beta - Patch 1 (version 0.3.0.14093)
BALANCE CHANGES
TERRAN
Viking
The armor value for this unit in Fighter Mode has decreased from 1 to 0.
The damage done by this unit in Fighter Mode has changed from 6 (+8 armored) to 10 (+4 armored).
Reaper
The damage done from D-8 Charges has decreased from 40 to 30.
The delay between attacks for D-8 Charges has decreased from 2.5 to 1.8.
Orbital Command
The build time for this upgrade has decreased from 50 to 35.
PROTOSS
Observer
Gravitic Boosters: The cost of this research has decreased from 150 minerals and 150 vespene gas to 100 minerals and 100 vespene gas.
High Templar
Phase Shift: This ability has been removed from the game.
New ability: Feedback - Drains all energy from the target unit and causes damage equal to the amount of energy drained.
Colossus
The building pathing radius for this unit has decreased from .75 to .5625.
Mothership
Vortex: The energy cost of this ability has increased from 75 to 100.
Vortex: The target radius of this ability has decreased from 3.0 to 2.5.
Temporal Rift: This ability has been removed from the game.
Wormhole Transit: This ability has been removed from the game.
New ability: Mass Recall - Teleports all of the player's units in the target area to the Mothership.
Nexus
Chrono Boost can no longer target allies.
Gateway
The build time of this building has increased from 50 to 65.
ZERG
Infestor
Fungal Growth: The damage done by this ability has decreased from 48 to 36.
Fungal Growth: This ability now prevents affected units from burrowing.
Neural Parasite: Functionality changed - The Infestor now channels this spell, which lasts 10 seconds or until the Infestor is destroyed. You can now target all units with this ability.
Terran Infestation: The ability’s energy cost has reduced from 50 to 25 and Infested Terrans now spawn 1 at a time.
BUG FIXES
Addressed an issue causing people to receive an “Internal Battle.net Error” message with their game client.
Muting your microphone will no longer cause your microphone to be turned off in the operating system once the program has exited.
Please note that the voice chat functionality has only partially been implemented. There are many known issues with voice chat that we expect to address in a future patch.
The “Medium” graphical settings were reconfigured to work better on appropriate machines. The video settings “auto-detect” functionality has been reset as a result.
Added a frame rate limiter to the game menus to prevent some graphics cards from running at higher frame rates than necessary.
לאאאא..... הם אנסו את ה- :'( mothership
זה נראה שהם באלנס ממש קיצוני. ייקרו דברים והחלישו אותם.
אנסו? הדבר הזה היה הכי OP בעולם בערך, Thor זאת חרא של יחידה, 4-5 יחידות פושטיות מפרקות אותה והנזק שהיא עושה אפסי(ציפיתי ממנה לsplash damage רציני והיא לא עושה פשוט כלום).
הדבר הכי טוב עם הTerrans שאפשר לעשות זה Viking Rush כרגע, היחידה הזאתי מעולה, טוב שלא נגעו בה יותר מיידי :)
כל דבר אחר אלא אם עושים Marine/Mara's rush עם עוד אחד ב2V2 פשוט חסר תועלת.
Sige Tank עושה נזק סביר בלבד, ומת מכמה מכות קלות, הBC פשוט אפס, הדבר היחידי שיש להם כרגע זה הViking.
וגם nuke spam עם ghosts שעכשיו זה פשוט קל להחריד...
כמו שאמרתי כבר בהתחחלה המשחק כרגע לא מאוזן להחריד ל-MP.[br]פורסם בתאריך: 26.02.2010 בשעה 17:05:22
http://www.youtube.com/watch?v=p0cR0aD22lg
הReplay הנובי הראשון שלי.
אני מסכים שזו יחידה חזקה מידי, אבל אם היו מחזקים יחידות אחרות ומקצצים קצת במאת'רשיפ נראה לי שזה היה יוצא יותר טוב...
היה לי משחק לפני הפאטצ' שבניתי בו באיזשהו שלב המון mutas שהסתובבו בקבוצה ליד אחד הבסיסים שלי
הפרוטוס שהיה נגדי בדיוק שלח כח עם mothership לכיוון, וכשהוא ראה את ה mutas הוא הפעיל wormhole או משהו על כל הקבוצה
לרגע הרגשתי ממש מעוצבן שפאקינג קליק אחד חיסל לי את כל ה mutas - מה שמראה למה ה mothership היא רעיון שנוי במחלוקת.
אבל לשמחתי למרות שכל ה mutas היו באמצע המערבולת - הם יצאו ללא פגע וחיסלו את ה mothership
זה היה די מצחיק, או שזה באג או שזה לא אמור לפגוע ביחידות אלא רק בבניינים או משהו.
אולי אני אעלה את הקטע הזה מתישהו באמת.
זה לא מחסל אותם זה רק מוציא אותם מהמשחק למשך זמן מסויים :)
מה הaspect ratio הטבעי של המשחק, 16:10 או 16:9?
אין כזה דבר "aspect ratio טבעי" למשחק בימינו, אתה בוחר ברזולוציה של המסך שלך ומשחק.
קרא את הסקירה הקצרה הזו
כמה בדיקות ש-GS עשו על המנוע הגרפי של SC2:
http://www.gamespot.com/features/6251839/index.html?om_act=convert&om_clk=picks&tag=picks;title;4
לפי הבדיקות שהם ביצעו - ככל שהיחס "רחב יותר" כך אתה רואה יותר מהמפה אבל זה די זניח.
