התאמת כרטיס זיכרון
Field Value
Memory Module Properties
Error Detection Method None
Memory Speed PC3200 (200 MHz)
Memory Type DDR SDRAM
Module Name Hyundai HYMD564 646CP8JD43
Module Size 512 MB (1 rank, 4 banks)
Module Type Unbuffered
Module Voltage SSTL 2.5
Module Width 64 bit
Refresh Rate Reduced (7.8 us), Self-Refresh
Serial Number 04FF8039h
Memory Timings
@ 133 MHz 2.0-2-2-6 (CL-RCD-RP-RAS)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS)
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS)
Memory Module Features
Auto-Precharge Not Supported
Buffered Address/Control Inputs Not Supported
Buffered DQMB Inputs Not Supported
Differential Clock Input Supported
Early RAS# Precharge Not Supported
On-Card PLL (Clock) Not Supported
Precharge All Not Supported
Redundant Row Address Not Supported
Registered Address/Control Inputs Not Supported
Registered DQMB Inputs Not Supported
Write1/Read Burst Not Supported
Memory Module Manufacturer
Company Name Hynix Semiconductor Inc.
Product Information http://www.hynix.com/eng/02_products/01_dram/index.jsp
הכרטיס הזה יצאים לי יש לי גם PCI-E וגם DDR
http://www.imperia-pc.com/ProductDetails.aspx?pid=933
