פורסם 2003 בינואר 1823 שנים Well, I'm using kernel 2.4.18 with GeForce 2 MX.I've seen that all OpenGL apps went slow, so I decided to install the drivers.I Installed the 4191 (from source) and it didn't work.Than I installed the 3123 (from source) and it didn't work either.Here is the err of startx:########Error start#######XFree86 Version 4.2.0 / X Window System(protocol Version 11, revision 0, vendor release 6600)Release Date: 18 January 2002If the server is older than 6-12 months, or if your card isnewer than the above date, look for a newer version beforereporting problems. (See http://www.XFree86.Org/)Build Operating System: Linux 2.4.18 i686 [ELF] Module Loader presentMarkers: (--) probed, (**) from config file, (==) default setting,(++) from command line, (!!) notice, (II) informational,(WW) warning, (EE) error, (NI) not implemented, (??) unknown.(==) Log file: "/var/log/XFree86.0.log", Time: Sat Jan 18 18:15:47 2003(==) Using config file: "/etc/X11/XF86Config"Symbol __glXActiveScreens from module /usr/X11R6/lib/modules/extensions/libdri.a is unresolved!Symbol __glXActiveScreens from module /usr/X11R6/lib/modules/extensions/libdri.a is unresolved!(II) [GLX]: Calling GlxExtensionInitFatal server error:Caught signal 11. Server abortingWhen reporting a problem related to a server crash, please sendthe full server output, not just the last messages.This can be found in the log file "/var/log/XFree86.0.log".Please report problems to xfree86@xfree86.org.XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"after 0 requests (0 known processed) with 0 events remaining.#########Error End########Any Ideas?
פורסם 2003 בינואר 1823 שנים Put the relevant information from /var/log/XFree86.0.log and we will be able to help you somehow. Without a detailed log information, i cannot know what exactly is the problem.In addition, show us your XFree86 config file (i think it's /etc/X11/XF86Config, but it can be different on different systems)
פורסם 2003 בינואר 2823 שנים מחבר Well, I managed to get this drivers work.Actually - They rock! OpenGL works perfect.
