Assembler problem
ORG 100h      ; this directive required for a simple 1 segment .com program.
MOV AX, 0B800h ; set AX to hexadecimal value of B800h.
MOV DS, AX ; copy value of AX to DS.
XOR CX,CX
MOV Cl, 255 ; copy to the counter the higest ASCII value
woot: ; the
MOV DL, CL ; set DL to ASCII code of CX.
MOV DH, CL ; set DH to binary value.
MOV BX, CX ; set BX to CX.
MOV [BX], DX ; copy contents of CX to memory at B800:255
LOOP woot ; repeats the drawing of ASCII CX in spot CX in color CX
RET ; returns to operating system.
why does it print only half of the codes?
EDIT:
nvm solved
