פורסם 2007 באפריל 419 שנים לכל אלו שהיו להם בעיות להפעיל את בריל על קנופיקס עם כרטיסי מסך חדשים של נוידיה,הנה הדרך לגרום לזה לעבוד.נלקח מפה: http://www.knoppix.net/forum/viewtopic.php?p=111972אגב, ממש בקרוב תצא גרסת 5.2.1!To all of you, first you need to make sure that your graphics card hasNvidia acceleration.For this it is neccessary to use apt-get or synaptic and installnvidia-glxnvidia-kernel-commonnvidia-kernel-2.6.18-4 (kernel sources)OR the kernel sources for kernel 2.6.19 . Knoppix 5.1.1uses kernel 2.6.19 by default and if like me your CD or DVD was a cover disk then you may not have the kernel sources. This is why I used apt-get to install kernel 2.6.18-4.After installing the packages check that Nvidia acceleration is enabled. You should see a Green and white Nvidia splash screen, log out of kde and restart the xserver, ctrl-alt-backspaceIf no splash screen appears then the your /etc/X11/xorg.conf file may need modifying.This is especially true in your case joeylutledge. In the section "Device"Section "Device"### Available Driver options are:-# sw_cursor is needed for some ati and radeon cards--snip--Identifier "Card0"# auto-generated by KNOPPIX mkxorgconfigDriver "nv"VendorName "All"Change the line that starts Driver from nv to nvidia as below:Driver "nvidia"You should now see an Nvidia spash screen when starting kdm. If this works then from a terminal type glxinfo. This will generate lots of outputincluding whether your card has the glx extensions. Sample below:anc@orac:~$ glxinfoname of display: :0.0display: :0 screen: 0direct rendering: Yesserver glx vendor string: NVIDIA Corporationserver glx version string: 1.4server glx extensions:GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,GLX_ARB_multisample, GLX_NV_float_bufferclient glx vendor string: NVIDIA Corporationclient glx version string: 1.4client glx extensions:GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_floatGLX version: 1.3GLX extensions:GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,GLX_ARB_multisample, GLX_NV_float_buffer, GLX_ARB_get_proc_address--snip--Now for the last part, open a terminal and typeberyl-mangagerYou should see a splashscreen followed by a diamond in the kde tray. If so, try switching to desktop 2 or 3 the screen will rotate. Hold down ctrl and alt andgrab the top left corner of the screen, you should be able to roate and spin your desktop cube.If something fails:Try and restart the x-server by pressing ctrl-alt-backspaceIf you have a garbled display, look closely you may find part of an error message that is readable.Check dmesg and /var/log/Xorg.0.log for clues.In my case my Sparkle Nvidia Geforce 5700 Ultra card did not support GLX textures at the default colour depth which was 16 bit. I changed thisto 24 bit in my xorg.conf file and it worked.Good luck.
