המלצה: תוכנת צילום מסך חינמית WinSnap
מאוד נוחה וקלה.
מומלץ :xyxthumbs:
http://www.filehippo.com/download_winsnap/
WinSnap is a small enhancement utility for taking and editing screenshots. It can easily capture windows of non-rectangular form with the background of your choice, automatically perform simple canvas transformations and coloring effects, add professional smoothing shadows in Photoshop style and more. Also, WinSnap supports variety of image formats and provides advanced auto-save features.
* Easy makes screenshots of windows with rounded corners
* WinSnap saves info about window form and adds real smoothing shadows!
* Unique "Application" mode allows you to capture all visible windows of the foreground application with one click.
* Basic coloring effects and canvas transformations.
* Advanced auto-save and auto-copy options.
* Usual keyboard and mouse control (Print Screen replacement).
* Make all this work with one 100-kb application - smaller than Paint!
* It is FREE for personal, educational and non-commercial use
[attachment deleted by admin]
