פורסם 2007 בינואר 119 שנים אפשר אולי להכניס לסטיקי ולעדכן עם הזמן...?נלקח מהאתר הבא:http://www.hardforum.com/showthread.php?t=1115861&page=10&pp=20Cases that do not fit the 8800GTXThermaltake TsunamiAsus TA-210 (It's never going to fit in this case)CoolerMaster MystiqueLianLi PC-65 (It will fit one card but not two in SLI)LianLi PC-3077 (It will fit one card but not two in SLI)Raidmax Sagitta (Is never going to fit the 8800GTX)Thermaltake Armor Jr.Thermaltake AquilaThermaltake Matrix VXThermaltake SopranoThermaltake TsunamiCases that do fit the 8800GTXAntec P180 (Only By Removing one od the The Hard Drives) Antec 900Antec PlusView 2Apevia X-PiderApevia X-Cruiser (It is really close but it will fit, but you might not be able to mount hard drives on the bottom cage.)Chenming CMUI-601 (you will have to remove the lower hard drive cage)CoolerMaster Centurion 5 (requires no drives being present in 3.5 bays)CoolerMaster Praetorian 730 (it's really close)CoolerMaster Stacker 830CoolerMaster CM690CoolerMaster WaveMasterEnermax CS-5271BFSGigabyte GZ-FA1CAGigabyte Aurora 3DLian Li A10Lian Li V2000-2100 seriesNZXT Apollo (If the 8800GTX is really 10.5 inches long it will fit.)NZXT Lexa "Retro toaster"Silverstone TJ07Silverstone TJ09Thermaltake Soprano Dx (Only By Removing The Hard Drive Cage)Thermaltake ArmorThermaltake Shark (Only if the 8800GTX should fit if it is 10.5 inches and not 11)Thermaltake Mambo (Will fit the 8800GTX, but you will not be able to mount all of the hard drive cage.)XG CA-SW2-K (you will have to replace the included PSU)XION Solaris (will fit the 8800GTX but you will not be able to mount hard drives in the lower drive cage
פורסם 2007 בינואר 3019 שנים ראיתם ביקורת חדשה באחד האתרים הנ"ל? ראיתם ביקורת שפיספסנו? תשלחו לינק בהודעה פרטית ל-Xtract או ל-LiorP23 אם הביקורת טובה אז נוסיף לינק אליה כאן JG = JonnyGuru Hexus = Hexus.net HS = HardwareSecrets PCP = PC Perspective SPCR = SilentPCReview XBit = X-Bit Labs Antec: EarthWatts 500W @ JG NeoHE 430W @ SPCR 500W @ PCP 550W @ HS 550W @ XBit Phantom: 350W @ SPCR 500W @ SPCR 500W @ XBit 500W @ PCP SmartPower II: SP-450 450W @ SPCR TruePower II: 430W @ SPCR 550W @ JG TruePower Trio: 550W @ SPCR 650W @ JG BFG Tech: 650W @ JG 650W @ PCP CoolerMaster: iGreen RS-430-ASAA 430W @ HS RS-600-ASAA 600W @ Hexus RS-600-ASAA 600W @ PCP Real Power: RS-450-ACLY 450W @ SPCR RS-550-ACLY 550W @ SPCR RS-550-ACLY 550W @ ExtremeOverclocking Corsair: HX serias: HX520 520W @ JG HX520 520W @ SPCR HX620 620W @ JG HX620 620W @ Hexus HX620 620W @ HS HX620 620W @ PCP HX620 620W @ SPCR HX620 620W @ XBit HX620 620W @ [H]ard|OCP VX serias: VX450 450W @ SPCR VX450 450W @ [H]ard|OCP VX450 450W @ JG Enermax: Galaxy: EGA1000EWL 1KW @ JG EGA1000EWL 1KW @ HS EGA1000EWL 1KW @ PCP EGA1000EWL 1KW @ SPCR DXX CF 1KW @ [H]ard|OCP Liberty: ELT500AWT 500W @ HS ELT500AWT 500W @ SPCR ELT620AWT 620W @ SPCR NoiseTaker II: 535W SLI @ Hexus 600W @ SPCR Infiniti: 720W @ JG 720W @ [H]ard|OCP FSP - Forton Source Power BlueStorm: 500W @ Hexus Booster X3: 300W @ Hexus Epsilon: 600GLN @ Hexus 700GLN @ Hexus Green GLN: 400W @ SPCR 400W @ Hexus 650W @ Hexus Hec: ACE: 480W @ HS Win: 480W @ HS Lian Li: HPC: 600W @ SPCR OCZ: EvoStream: 600W @ JG GameXStream: 600W @ XBit 700W @ JG 700W @ Hexus 700W @ HS 700W @ PCP 700W @ XBit PCP&C - PC Power & Cooling: (אמנם אין ייבוא לארץ, אבל מותר לחלום לא?) Ultimate: Turbo Cool 1KW @ JG Silencer Silencer 750W @ PCP SeaSonic: M12: 700W @ JG 700W @ SPCR S12: 330W @ SPCR 430W @ SPCR 500W @ SPCR 600W @ SPCR 600W @ PCP S12 Energy Plus: 550W @ SPCR 650W @ SPCR 650W @ Hexus 550W @ Modders-inc SilverStone: Element: ST50EF-Plus 500W @ JG ST50EF-Plus 500W @ SPCR NightJar: ST30NF 300W @ Hexus Olympia: OP1000 1KW @ JG OP650 650W @ JG Strider: ST56F 560W @ SPCR ST75F 750W @ JG ST85F 850W @ overclock3d ST85F 850W @ JG Zeus: ST56ZF 560W @ JG ST65ZF 650W @ Hexus ST75ZF 750W @ JG ST75ZF 750W @ PCP ST75ZF 750W @ XBit ST85ZF 850W @ JG ST85ZF 850W @ PCP ST85ZF 850W @ XBit Tagan: Black: TG480-U1 480W @ Hexus Dual Engine: TG700-U25 700W @ Hexus EasyCon: TG530-U15 530W @ JG EasyCon XL: TG700-U35 700W @ SPCR TurboJet: TG1100-U95 1.1KW @ HS Thermaltake: PurePower: 460W @ Hexus 480APD 480W @ Hexus 500TWV 500W @ Hexus ToughPower: 750W @ JG 750W @ HS 750W @ PCP 850W @ PCP 1200W @ [H]ard|OCP 1200W @ JG TR2: 430W W0070RU @ HS Zalman: ZM300-APS @ Hexus ZM400-APS @ Hexus ZM460-APS 460W @ SPCR ZM600-HP 600W @ JG ZM600-HP 600W @ HS ZM600-HP 600W @ PCP ZM600-HP 600W @ SPCR Zippy/Emacs: (עוד חברה שהיינו שמחים לראות ייצוג שלה בארץ) Gaming Power: HP2-6500PE 500W @ XBit GSM-6600P 600W @ JG PSM-6600PE 600W @ XBit PSL-6720P 720W @ XBit PSL-6850P 850W @ XBit
פורסם 2007 במאי 1018 שנים תפקידו של המארז הוא לאגד את כל החומרה ביחד בתוך קופסה אחת ולשמור שלא תיפגע מנזקים פיזיים. מארז נמדד על פי מספר קריטריונים: יופי: יופיו של המארז, לטעמו של הקונה. קירור: על המחשב להיות מקורר בדרך מסוימת על מנת שיוכל לפעול כהלכה. קריטריון זה חשוב במיוחד לאלו המשתמשים בקירור אוויר, התלוי בטמפרטורה שבתוך המארז ובסירקולציית האוויר שבו. הקירור מושפע ישירות ממבנה המארז, איכותו והמאווררים הכלולים בו. למארז טוב ישנם פתחי מאווררים הממוקמים במקומות אסטרטגיים והוא בנוי מחומר בעל מוליכות חום גבוהה. [glow=red,2,300]אקוסטיקה:[/glow] על מארז לסייע בצמצום הרעש הנובע מן המחשב, שבו חלקים נעים רבים, ובמיוחד הכוננים השונים והמאווררים. הנדסת אנוש ואיכות בנייה: על המארז להיות מתוכנן לשימוש נכון וקל של המשתמש ולהיבנות בצורה טובה ומחושבת. מוטב גם שהחומרים שמהם בנוי המארז יהיו קלים. פיצ'רים, תוספות ו־Extras: ישנם מארזים המגיעים עם תוספות כמו לוח בקרת טמפרטורה, נעילה של המארז, חלון צד שקוף, תיק נשיאה ותוספות נוספות. *קרדיט לויקיפדיה בפוסט הזה אני ארחיב על סעיף האקוסטיקה ברמת הבסיס, בלי להביא נוסחאות משעממות, שאני מודה, משעממות גם אותי. בעצם הרחבתי כל כך את הנושא עד לקריעה לגזרים של כל שאלה אפשרית שעלולה לעלות אח"כ אני מאלה שאוהבים לישון בחדר כאשר המחשב דולק ליד, ואם תציצו במפרט תגלו שזה "לא בדיוק" מחשב מזכירה עם קירור פסיבי. * הכתוב כאן הוא דעתי הפרטית הכל כאן מרוכז בשבילכם ונועד למנוע מכם לכבות את המחשב בלילה או לחילופין לזכור פלגת פיליפינים שינפנפו עליו עם עלי דקל שלא תתעוררו מהרעש של המאוררים מקווה שתהנו מעוניינים למדוד רמת רעש ברצינות? המודד היחיד שמצאתי בישראל: http://www.sos-shop.co.il/show_product.asp?id=221 אלה המודדים הרשמיים של המשרד לאיכות הסביבה (נלקח מדו"ח רשמי משנת 2003 של המשרד לאיכות הסביבה למדידת רעש של כביש מס' 2 ליד בתי מגורים): http://www.bksv.com/1130.asp רוצים לדעת מה אומרים מספרי ה DBA (דציבלים) בנתונים של המאוררים וכמה DBA זה באמת שקט? אז ככה . . . זוהי טבלת רעש. תשננו אותה כדי להיזכר בה אח"כ תוך שאתם מעיינים באתרים השונים ומנסים לנחש כמה שקט זה לעזאזל 30 DBA ?! חילקתי את המארזים בשוק ל-5 סוגים. (דירגתי אותם בסדר יורד מהשקטים ביותר לגרועים ביותר מבחינת יכולת ההשקטה שלהם): 1)מארזים מושקטים (מגיעים עם מבנה הנדסי עשוי מחומרים מיוחדים, חומרים סטנדרטיים המודבקים יחדיו ליצירת "מבנה של משתיק"): P182/182 הP180 עשה מהפכה הנדסית כאשר היה המארז הראשון שהציג את המבנה המושלם: רגליות סיליקון, דלת קדמית לכל האורך ודלת צדדית אשר שתיהן עשויות משלושה שכבות : אלומיניום/פלסטיק/אלומיניום. P182 הוא בדיוק אותו המארז למעט השינויים המבורכים הבאים: -מאחורי פאנל הלוח אם ישנם עכשיו חורים, ובעצם מעבירים את כבלי הספק מאחורי הלוח אם ככה שלא אורים אותם בכלל. רעיון גאוני. -ישנם 2 חורים לצינורות מים של ערכות קירור מים -ישנם שני מפסקים על צידו האחורי עליון של המארז ששולטים על מהירות שני מאוררי ה Tri-Cool העליונים. - צבע אקדח מתכתי שחור P180: P180B, הגרסה השחורה של הP180, צבע שונה מ P182 : :P182 P182 SE או Special Edition אשר משתמש באותו המבנה אלה בהרכב קצת שונה. שתי הדלתות עשויות מהשילוש ברזל, פלסטיק, ואלומיניום. אה, כן,פרט קטנטן: השכבה השלישית של הברזל מלוטשת לדרגה מושלמת של מראה אמיתית ובעצם אפשר לחסוך זמן בבוקר כשבודקים מיילים לפני העבודה ואגב כך להתגלח ;D אני בודק כרגע איך להביא אותו לארץ הקודש . . . יא חאצ'ווו !!! (אני רוצה ברוסית) :'( http://www.antec.com/us/productDetails.php?ProdID=81803# P190 - הוכרז בתערוכת CES 2007 http://images.google.com/imgres?imgurl=http://hardware.gotfrag.com/files/upload/galleryimage_18800_t.jpg&imgrefurl=http://hardware.gotfrag.com/portal/gallery/653/&h=270&w=180&sz=11&hl=en&start=40&tbnid=K2tuSCVVh6Tk0M:&tbnh=113&tbnw=75&prev=/images%3Fq%3DP190%26start%3D21%26gbv%3D2%26ndsp%3D21%26svnum%3D10%26hl%3Den%26sa%3DN זה קצת להקדים תרופה למכה, כי הוא לא יצא בכלל לשוק אבל רציתי שתהיו מעודכנים שינויים עיקריים: 1 - נוסף מאורר 20 ס"מ "Big Boy" בדלת הצדדית מסוג Tri Cool. 2 - נוסף מאורר 12 ס"מ עליון. 3 - במקום קצף, יש עכשיו שכבת Plexiglass בדלת של המארז והדלת הקדמית. 4 - ניהול כבלים מאחורי הלוח אם, בדומה ל P182/SE. 5 - צורת הדלת הראשית עברה שינוי מזערי בעיצוב. 6 - המארז אמור להגיע עם שני ספקים.Dual Neo-Linked Power Supplies בהספק 550W ו 650W. אחד עבור כרטיסי מסך חזקים ואחד עבור שאר המערכת. הספקם הכולל 1200W ! * מחיר המארז משוער ב כ-400$ ומעלה ומיועד אך ורק לתותחים הכבדים בעלי מערכות מטורפות הכוללות QUAD SLI. ** אמרתי כבר שהחתול שלי חי בפחד מתמיד שיום אחד אני אמכור אותו כדי לממן את הP190? חח ;D 2) מארזים רגילים אשר עשויים מאלומיניום או ברזל שהיצרנית מוכרת אותם מראש עם איזהשהו סוג של ציפוי פנימי אקוסטי. הציפוי הזה זה בדיוק מה שאפרט בהמשך ונקרא "קיטים להשתקת המארז".וגם פה קיימים מארזים טובים יותר ופחות: טובים: כאלה שממש מכוסים באופן מלא בקיטים האלה, בדיוק מה שהייתם מקבלים לו הייתם עושים את זה לבד בבית. רעים: אלה שהיצרנים ניסו "לצאת ידי חובה" ולשים "משהו" כדי לפרסם את זה כ"מארז שקט". לשים לב טוב טוב לביקורות מה בדיוק מכוסה במארז בחומר השתקה ! כרגע, רק ה NZXT HUSH (כנסו ללינק יש שם תמונות מעולות), נראה כמו האונס שעבר אצלי בבית ה P180 שלי, אבל רק כמו ;D כאן נתקלתי בשלושה דגמים: NZXT Hush שהגיע לארצנו (ואגב, זו דוגמה מעולה למה שאתם צריכים לעשות (או התחלה לפחות) אם אתם מתכוונים לקנות "קיט השקטה" ויש לכם מארז מסוג 4 שתראו בהמשך http://www.overclockersclub.com/reviews/nzxt_hush/3.htm ANTEC P150 http://www.antec.com/us/productDetails.php?ProdID=81500# Lian Li PC-B20 http://www.neoseeker.com/resourcelink.html?rid=132203 3)מארזים בעלי דלת קדמית לכל אורך החזית שלא רק שסוגרת הרמטית (מלבד חורי אוורור) את המאווררים והכוננים האופטיים והקשיחים, אלה היא גם מוסיפה עוד מקום להדביק בו קיטים להשקטה ובעצם אפשר להשתיק איתם כמעט לחלוטין את צידו הקדמי של המארז. Antec P180/180B/182/182 SE Lian Li PC-B20 Lian Li PC-S80 Lian Li PC-101 4)מארזים רגילים אשר אינם עשויים אלומיניום או ברזל שנמכרים ללא שום ציפוי פנימי ובעצם אינם נחשבים לשקטים, ניתנים להשתקה מסויימת ע"י ערכות מקצועיות שאפרט בהמשך. ההשוואה כלפיהם נעשית ע"י בחינת המאוררים שמותקנים בהם. לדוגמה: מארזX שמותקנים בו שני מאווררי 8 ס"מ יהיה רועש יותר ממארז דומה עם שני מאוררי 12 ס"מ. הסיבה לכך נעוצה בעובדה שככל שהמאוררים גדולים יותר, כך הם שקטים יותר כי שטח הפנים של הלהבים שלהם גדול יותר ממאווררי ה 8 ס"מ ועל כן עליהם לבצע פחות סיבובים על מנת לדחוף את אותה כמות האוויר שדוחפים מאווררי ה 8 ס"מ.פירוט על מאוררים בנספחים את המארזים הרגילים (והכי נפוצים) הללו ניתן להשתיק איכשהו רק בדרך אחת וזה עם קיטים של גומי מבודד ועדיף בשתי שכבות ! ואני מדבר מניסיון איתם ועוד על הP180 ישנם 2 קיטים להשתקת המארז שנמכרים בישראל, כאשר בתפוצה רחבה יש רק את הקיט המעולה של THERMALTAKE שבו השתמשתי אישית. Akasa Paxmate PLUS noise reduction AK-PAX-2 http://www.pandas.co.il/product_info.php?cPath=946_1185&products_id=9831 Thermaltake A2384 Noise dampening Kit http://www.thermaltake.com/product/Accessory/CaseMods/a2384/a2384.asp# למכירה בארץ (השתמשתי בקיט הזה ב P180 שלי ויצא מפחיד, לא שומעים שהמחשב פועל, וזה עוד עם החומרה ה"צנועה" שלי וכל המאוררים. הקיט יש 2 ריבועי דלת MIDI ATX ו שני מלבנים לרצפה ודלת קדמית. http://zap.co.il/models.asp?sog=&keyword=a2384 http://logicpc.co.il/heb/itdetail.aspx?icom=10146 5)מארזים שחלק מהמבנה שלהם עשוי מרשתות שונות ומשונות . . . להתרחק מרוב הדגמים כמו מאש ! מדוע? לא רק שאין שום דבר בין רעש המאוררים לביניכם, אלא שכמויות האבק שהמארזים האלה מושכים הן מסוכנות בעליל, סותמות רכיבים וגורמות ליותר חום מהשפתיים של אנג'לינה ג'ולי עם שפתון צ'ילי חריף Antec Nine Hundred - 900 המארז בעל הקירור הכי טוב בביקורת. מאורר כמו טורנדו ומכניס אבק בכמויות דומות . . . של טורנדו. המאוררים חסרי כל פילטר אבק ועל כן אנשים החיים ליד כבישים סואנים ומקומות מאובקים היזהרו: יסתמו לכם הצלעות קירור בכל הרכיבים. המאוררים אומרים אינם רועשים. לקנות רק אם יש פיליפינית צמודה עם תרסיס אוויר דחוס נגד אבק. http://www.antec.com/us/productDetails.php?ProdID=15900 Lian Li PC 777 השבלול המפורסם הזה מכיל את הרשת הגדולה בעולם כנראה . . . לקנות רק אם אתם חובבי . . . שבלולים כל השאר, תלכו לקטגוריות 1,2,3. אמנם מארז זה אינו מכיל רשת, אך עדיין בחיים לא לקנות מארז עם מאורר קטן מובנה בדלת שלו רעש נוראי, המון תלונות של בעליו בפורומים שלנו וסה"כ, חור במקום רשת שאינו סותם רעש, אלא ההיפך - מייצר אותו . . . במקום זה, תקנו את המארז שאסביר עליו בפסקה הבאה . . . Thermaltake Tsunami לא לגעת ! אז מה כן לקנות? אם כבר חשקה נפשכם במארז עם מאורר בגודל של חצי מהמארז בדלת למען תוכלו לעשות לעצמכם פן ליד הקופסה (ניתן להפוך את כיוון האוויר כך שיוציא אוויר חם החוצה) ולא להיראות ככה כשאתם יוצאים לעבודה: אני ממליץ על המארז הזה שמכיל מאורר ענק של 25 ס"מ, שלפי הביקורות לא שומעים אותו בכלל. Enermax Chakara http://www.virtual-hideout.net/reviews/enermax_chakra/index.shtml והגרסה החדשה שלו ה ENERMAX UBER CHAKRA ביקורת וידאו מעולה: http://www.3dgameman.com/content/view/7246/48/ עד כמה רעש משפיע עליכם לאט לאט ומה החסרונות של לשבת כל הזמן ליד מחשב מרעיש? לרעש השפעה פסיכולוגית המתבטאת ב: • עייפות • מתח • פגיעה בכושר הריכוז וכושר הלימודים/עבודה נ.ב - מי שרוצה עוד מידע לגבי רעש מהאתר היחיד ומצאתי בעברית: http://www.alehlod.co.il/Eco/Noise.htm [glow=red,2,300]נספחים:[/glow] נספח א': מארזים בעלי קירור פסיבי (סדרת ה TNN - Totaly No Noise האגדית של חברת Zalman): מארזים אלו הינם בעלי קירור פסיבי לכל חלק במחשב שפולט חום וכוללים צינורות Heatpipes בין המארז ל: מעבד,כרטיס מסך ,לוח אם, הכוננים הקשיחים ובנוסף ספק ללא מאורר. החיסרון? מחיר צנוע של 4 עד 7 אלף (!) ש"ח . . . מוגדר כציוד למשוגעי הדבר, ואני יודע שמארזים כאלה נמכרו למחשבים בתוך אולפני הקלטות ברחבי הארץ לדוגמה, אה כן, ולבחור אחד ששמעתי שזכה בלוטו והיה לו עודף מיותר מהזכייה . . . Zalman TNN 300 http://zalman.co.kr/eng/product/view.asp?idx=178&code=020 מגבלות: מעבד בעל פליטת חום עד 150W, מתאים לרוב המעבדים בשוק היום. כרטיס מסך בעל פליטת חום עד 75W, לא מתאים לרוב הכרטיסים החזקים בשוק היום. מומלץ עד 6600GT, אבל תזכרו, שזה לא נועד למחשב משחקים מלכתחילה. TNN 500AF http://zalman.co.kr/eng/product/view.asp?idx=152&code=020 מגבלות: מעבד בעל פליטת חום עד 150W, מתאים לרוב המעבדים בשוק היום. כרטיס מסך בעל פליטת חום עד 75W, לא מתאים לרוב הכרטיסים החזקים בשוק היום. מומלץ עד 6600GT, אבל תזכרו, שזה לא נועד למחשב משחקים מלכתחילה. לוח אם עם גשר צפוני בעל פליטת חום של עד 20W. הדגם הראשון, בכור הסדרה TNN 500A http://zalman.co.kr/eng/product/view.asp?idx=64&code=020 מגבלות: מעבדים: אינטל - עד פנטיום 4 3.2 ג'יגה בתושבת 478. AMD: עד 2.2 ג'יגה דגם 3400 בתושבת 754 כרטיס מסך: נבחן עם RADEON 9800 PRO, יש לבדוק עם היצרן תמיכה בכרטיסים חדשים יותר. נספח ב': מאוררים שקטים למארז השוואת מאוררים מבית ה-אתר לחובבי שקט: http://www.silentpcreview.com/article63-page2.html חידוש בשוק מגיע אלינו מחברת Enermax אשר הוציאה את ה מארז שלה ENERMAX UBER CHAKRA עם מאורר צד עם נתונים לא פחות ממדהימיםף 650סל"ד 90 CFM ו רק 17 DBA ! ! ! היא מייצרת את המאוררים הגדולים השקטים ביותר כיום בטכנולוגיית Enlobal Bearing שאפשר אפילו לפרק מהמגנטים ולנקות. נתונים? איך אומר מר.2-1-שלוווששש ! פשוט מ-ה-מ-מ-י-ם ! ! ! 44CFM רק ב 17DBA ! : כמה חבל שבארץ אין לו זכר . . . איך זה עובד? ככה: ***לתוספת של מידע/תמונות/נספחים אנא פנו ל-Xtract או ל-LiorP23***
