הצורב הפסיק ליצרוב לי
1C82-0000-19E5-MAAX-4006-3080-9819
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 16/08/2006 22:44:04
NT-SPTI used
Nero Version: 7.2.3.2
Internal Version: 7, 2, 3, 2
Recorder: <YAMAHA CRW-F1E> Version: 1.0b - HA 1 TA 0 - 7.2.3.2
Adapter driver: <SCSI> HA 1
Drive buffer : 8192kB
Bus Type : default (0) -> SCSI, detected: ?
CD-ROM: <VJ1570Y PFZ681O >Version: 1.0 - HA 1 TA 1 - 7.2.3.2
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y120P0 nvatabus Port 0 ID 0 DMA: Off
DiskPeripheral : WDC WD2500JB-00GVC0 nvatabus Port 0 ID 2 DMA: Off
CdRomPeripheral : YAMAHA CRW-F1E nvatabus Port 0 ID 3 DMA: Off
CdRomPeripheral : VJ1570Y PFZ681O 1.0 ax83dvag Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
VJ1570Y PFZ681O E: CDRom1
YAMAHA CRW-F1E F: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095528kB)
Free physical memory: 1351MB (1383852kB)
Memory in use : 33 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
23.12.2006
CD-ROM (ISO)
18:36:06 #1 Text 0 File Isodoc.cpp, Line 6427
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:36:06 #2 Text 0 File Burncd.cpp, Line 3086
YAMAHA CRW-F1E
Buffer underrun protection activated
18:36:06 #3 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 81920KB of Memory
18:36:06 #4 Text 0 File Reader.cpp, Line 124
Reader running
18:36:06 #5 Text 0 File Writer.cpp, Line 113
Writer F: YAMAHA CRW-F1E running
18:36:06 #6 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
18:36:06 #7 Text 0 File Burncd.cpp, Line 3400
Turn on Track-At-Once, using CD-R/RW media
18:36:06 #8 Text 0 File DlgWaitCD.cpp, Line 289
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 358757 ( 79:45.32)
18:36:06 #9 Text 0 File DlgWaitCD.cpp, Line 301
Write in overburning mode: NO (enabled: CD)
18:36:06 #10 Text 0 File DlgWaitCD.cpp, Line 2715
Recorder: YAMAHA CRW-F1E;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
18:36:06 #11 Text 0 File DlgWaitCD.cpp, Line 473
>>> Protocol of DlgWaitCD activities: <<<
18:36:06 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 358758 (358758) = #358758/79:43.33
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358756 blocks [F: YAMAHA CRW-F1E]
18:36:06 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [F: YAMAHA CRW-F1E] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 735043584, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
358758 | lead-out | 1 | 0x41 | 0x00
18:36:06 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1127
Removed 2 run-out blocks from end of track 1. Length: 358758 -> 358756.
18:36:06 #15 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
18:36:06 #16 Text 0 File SCSIPassThrough.cpp, Line 84
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:36:06 #17 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
18:36:06 #18 Text 0 File Burncd.cpp, Line 4231
Cache writing successful.
18:36:06 #19 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
18:36:06 #20 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 16x (2,400 KB/s)
18:36:06 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:36:06 #22 Text 0 File MMC.cpp, Line 22035
Set BUFE: Buffer underrun protection -> ON , Optimum Writespeed Control : ON
18:41:17 #23 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
18:41:25 #24 Text 0 File MMC.cpp, Line 16684
<YAMAHA CRW-F1E > start Close Track #1
18:41:25 #25 Text 0 File MMC.cpp, Line 16846
<YAMAHA CRW-F1E > start Close Session
18:41:25 #26 SPTI -1046 File SCSIPassThrough.cpp, Line 291
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x09
CDB Data: 0x5B 00 02 00 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 09
18:41:25 #27 CDR -1046 File ThreadedTransferInterface.cpp, Line 1308
Illegal disc
F: YAMAHA CRW-F1E
18:41:25 #28 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1308
Could not perform Fixation
18:41:25 #29 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 16x (2,400 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19/05/2006 23:16:24
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 16/05/2006 22:23:54 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 04/08/2004 14:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
בן כמה הוא?אם הבנתי נכון זה ימהה שלא מיוצרת ממזמן.אבל אלא היו סוסי עבודה.
היתה מפרט יותר על התקלה.
הוא צורב עד סוף הדיסק ואז אומר שהוא לא הצליח
אומר מדיה לא חוקית (בטוח זה לא הדיסק!!)
זה קורה אם כל תוכנת צריבה וכל דיסק?
