קניתי כונן חדש של מקסטור. הנה התוצאות
הכונן ממש שקט לא שומעים.
עשיתי לא בחינה והיה 95 90 ועכשיו 90 90.
בכלל מה דעתכם האם זה מספק לכונן חדש.
או שזה מחודש
Almost every EIDE or SATA hard disk includes S.M.A.R.T. data. That information is collected by the drive itself and contains data that the manufacturer considered relevant to check reliability. The data is made up of several attributes that have a current value, a worst one, a threshold, some raw data, and some flags. Basically, when any attribute's current value is below its threshold, the hard disk is considered unreliable and likely to fail. By using several techniques, this report tries to give a wider range of info, basing its analysis on advanced comparisons with normal values based on real hard disks and on expert-like checks. The final results are not to be taken as an absolute truth, but they are a very good approach to what a professional would say about your hard disk status.
Your hard disk is a Maxtor 6L160P0 with firmware BAJ41G20.
The average temperature for this hard disk is 37C (MIN=28C MAX=48C) and yours is 28C.
Your hard disk's S.M.A.R.T. attributes are now being analyzed and a full report about the reliability, health and status of your hard disk is generated:
Your hard disk is not below any attribute threshold. This is good.
Your hard disk was never below any attribute threshold. This is good.
Your hard disk is now being compared to real data used to define normal values for your specific hard disk model. This way, the analysis can automatically use proper operating ranges. The images give you an idea of how each attribute is within such range. Current and raw values are shown for easier reference for experienced users. There are 1286 hard disk models in the current archive.
Attribute Current Raw Overall
10 Spin Up Time 252 3631 Very good
10 Start/Stop Count 253 18 Very good
10 Reallocated Sector Count 253 0 Very good
10 Read Channel Margin 253 0 Very good
10 Seek Error Rate 253 0 Very good
1 Seek Time Performance 243 63390 Normal
10 Power On Hours Count 253 10333 Very good
1 Spin Retry Count 252 0 Normal
10 Calibration Retry Count 253 0 Very good
10 Power Cycle Count 253 23 Very good
10 Power Off Retract Count 253 0 Very good
10 Load Cycle Count 253 0 Very good
10 Hardware ECC Recovered 253 17195 Very good
10 Reallocated Event Count 253 0 Very good
10 Current Pending Sector 253 0 Very good
10 Offline Uncorrectable Sector Count 253 0 Very good
10 Ultra DMA CRC Error Rate 199 0 Very good
10 Write Error Rate 253 0 Very good
10 Soft Read Error Rate 253 0 Very good
10 TA Increase Count 253 0 Very good
10 Run Out Cancel 253 0 Very good
10 Shock Count Write Opern 253 0 Very good
10 Shock Rate Write Opern 253 0 Very good
1 Spin High Current 252 0 Normal
1 Spin Buzz 252 0 Normal
2 Offline Seek Performance 241 147 Normal
10 Unknown attribute 210 253 0 Very good
10 Unknown attribute 211 253 0 Very good
10 Unknown attribute 212 253 0 Very good
NOTE: not all warnings are reflected on fitness and performance overall values as relevancy is based upon the settings from the hard disk manufacturer who is the best entity deputed to define such relationships.
The overall fitness for this drive is 90%.
The overall performance for this drive is 90%.
The link to get back and see a new report about this hard disk in the future is this. Consider that new hard disks and new checks are added over time.
DISCLAIMER: this report does its best to highlight issues and warnings related to your hard disk. It cannot be held responsible for any mistake. This page and its results cannot be used in any other way but the one defined by its author
תתחדש!נראה סבבה.
באיזה תוכנה ניבדק הדיסק?
MAXTOR הם סבבה, QUANTUM לשעבר.
