התלבטות בקנייה של כרטיסים
אני לא יודע איזה כרטיס לבחור יש כאן כמה כרטיסים שאח שלי יכול לקנות לי מחו"ל אז תראו איזה הוא הראה לי
# PNY GeForce 7900GS 256MB PCI Express Video Card (Mfr# VCG7900SXPB/ VCG7900SXPB-CUS) » only $149.99 + Free In-Store Pickup
More BestBuy.com Deals : More Computer Component Deals : More BestBuy.com Coupons
*** Hot Deal *** No Rebates ***
Designed for extreme High Definition (HD) gaming, the PNY Nvidia GeForce 7900 GS 256MB GDDR3 PCI Express Graphics Card delivers an ultra-realistic gaming experience, and unparalleled image quality at the highest resolutions. The Nvidia GeForce 7900 GS graphics card also delivers smooth, high-definition video playback and crisp picture quality due to advanced Nvidia PureVideo technology. If you are searching for an extreme HD gaming and video experience for your PC, then you need to look no further than this GeForce 7900 GS graphics card from PNY Technologies!
BestBuy.com is carrying this 256MB PCI Video Card for only $149.99!
During checkout, you may want to select in-store pickup to save on shipping charges!
Note: BestBuy.com collects sales tax in all the states where it has local presence!
כלומר זה 7900gs ב-150$
או
# BFG Technologies GeForce 7950 GT 512MB PCIe Video Card (Mfr# BFGR7950512GTOCE) » only $255.63 Shipped
More Computer Component Deals : More Newegg.com Coupons
Mind-Blowing Performance The NVIDIA® SLI-Ready BFG Tech GeForce® 7950 GT OC graphics card cranks up the graphics horsepower with a whopping 512MB and a 565 MHz core. Power through games with exceptionally smooth frame rates at widescreen resolutions up to 2560x1600, and enjoy ultra fluid, high-definition video playback using advanced NVIDIA® PureVideo HD technology. More is better!
# Newegg.com is carrying this 512MB Video Card for $304.99
# During checkout, apply $10 off Special coupon code "AFCBFG7950" on it (Expires 11/09/2006)
# There is a $10 Exclusive Bundle Mail-In Rebate on it until 11/15/2006
# Shipping cost on this item is $5.64
# Your Final Price: $269.99 - $10 - $10 + $5.64 = $255.63 Shipped
שזה ה -7950gt 512mb ב-255.6$
או ה
# ATI Radeon X1950 Pro 256MB PCI Express x16 Video Card ( Dual DVI) (Mfr# 100-437807) » only $199.99 + Free In-Store PickUp
*** Hot Deal *** No Rebate ***
Explore stunning new worlds of cinematic gameplay with the combination of power and performance with the Radeon® X1950 Pro 256 MB GDDR3 PCI-E® Graphics Card from ATI Technologies. Featuring 256 MB GDDR3 memory the Radeon® X1950 Pro delivers crystal clear graphical details. The Anti-Aliasing and Anisotropic Filtering feature combines power and efficiency to handle demanding visual applications. In addition, Radeon® X1950 Pro is CrossFire ready, allowing multi-GPU fantasies to come true. The incorporated Avivo technology creates vibrant colors, ultra sharp images, true-to-life image reproduction, and smooth HD video playback. This graphics card provides support for Microsoft® DirectX® 9.0 Shader Model 3.0 programmable vertex and pixel shaders in hardware!
BestBuy.com is carrying this 256MB Video Card for only $199.99!
כלומר ה-x1950 pro ב-200$..אז אני יודע שתאמרו לי שזה ממש תלוי בתקציב אבל אולי יש קניה שיותר שווה מהשניה או אולי יש לכם הצעות אחרות (כמו ה-x1950xt או ה-x1900xt שלא כתבתי כאן וכדומה..)
הממ ראיתי גם את זה שיותר זול
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2456679&CatId=1382
הקטע הוא שמבחינת מחירים המחירים בחו"ל קצת שונים (כלומר חוץ מזה שהם יותר זולים מבארץ) היחס קצת שונה אז אולי היחס ביצועים/מחיר יכול להשתנות כאן ביחס לכרטיסים מסוימים אז תאמרו לי מה לדעתכם הכי משתלם..
הכי משתלם לדעתי
עצורררררררררררררררררררררר :o
לפי מפרט מחשב יש לך פנטיום 4 3GHZ ולא הצלחתי להבין איזה לוח-אם יש לך ?
יש לוחות-אם שלא תומכים בחיבור של PCIE וכל הכרטיסים שצינת הם רק בחיבור PCIE
בהנחה שכן יש לך PCIE אני במקומך הייתי קונה כרטיס יותר זול (כמו 7600GT או 7900GS ) שיחזיק לי שנה ואז משדרג לדור הבא DX10
יש הבדל של 50$ בין ה 7900GS לבין ה X1950Pro.
אני הייתי הולך על ה 7900GS (עם אובר קלוק אתה יכול לעקוף את ה X1950Pro בלי בעיה.)
אז דבר ראשון יש לי כניסת agp אבל אני מחליף את הלוח אם אז אין בעיה (ויש לי סוקט 775 lga אז זה גם בסדר מצד המעבד..)
ומצחיק שאין כאן דעה אחידה אבל בכל מקרה אני לא רוצה לשדרג את הכרטיס עוד שנה אני מאמין שהמשחקים החדשים עדיין ימשיכו לתמוך ב-dx9c ושזה יוריד לי ממש קצת fps ולכן זה לא שווה שדרוג בשנתיים הקרובות ואני חושב שאם אני אקח את ה-x1950xt אני אוכל להנות מהגדרות גבוהות במשך השנים הללו..מה אתם אומרים?
