בעיה עם התוכנה AVI2DVD בבקשה עזרה אני משתגעת.
אחרי כמה דקות שהתכנה רצה פתאום נפתח לי הTMPGEnc ולא יודעת מה היה רשום אבל היה לחצן אחד אז לחצתי עליו ואחרי כמה דקות התוכנה של AVI2DVD ראיתי שזה לא זז.. זה נתקע בדיוק כאן:
WNASPI32.DLL 0.0.0.0
- 02/12/2006 15:37:30
- AVI to SVCD Conversion
- AVI2DVD ver. 1.2.3 build 1
Initializing
- D:\The Texas Chainsaw Massacre DVDRip.XviD-DMT[MYAKUZA.NET].avi
Initializing finished.
Saving Subtitles ini file
- 02/12/2006 15:37:39
- Free on drive D: 2665.86 mb
- AUDIO Extraction
Undoing Nandubs 1152 BlockAlign value to 1
Redoing Nandubs 1152 BlockAlign value
Audio extraction finished.
- 02/12/2006 15:38:34
- AUDIO conversion
- 02/12/2006 15:38:39
- AUDIO conversion
Converting MP2 to WAV. Filename: D:\DVD\Extracted_audio_1.mpa
Executing MADPlay (mp2 to wav). Commandline:
"D:\DVD2SVCD\MADPlay\madplay.exe" --quiet --output=wave:"D:\DVD\Encoded_audio_1.mp2.wav" "D:\DVD\Extracted_audio_1.mpa"
Conversion (mp2 to wav) of D:\DVD\Extracted_audio_1.mpa finished.
Encoding Audio. Filename: D:\DVD\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"D:\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "D:\DVD\Encoded_audio_1.mp2.wav" -output "D:\DVD\Encoded_audio_1.mp2" -logfile "D:\DVD\Encoded_audio_1.log" ) -ota( -g max ) -shibatch( --rate 48000 ) -2lame( -e -b 224 -m s )
Audio conversion of D:\DVD\Extracted_audio_1.mpa finished.
Audio conversion finished.
- 02/12/2006 15:52:21
- Video Encoding using TMPGEnc
- Encoding D:\DVD\AviSynth_Script_file.avs
StreamSectors: 4546875788
AudioSectors: 167407016
VideoPAPO: 67840308
ScanOffsetBytes: 127249
SeqAligningBytes: 8087394
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 2324
EmptySectors: 238.00
PictureSectors: 0.00
PureMPEGStream: 4303411493.20
Seconds: 5899.06
CalcMPEGStream: 4303411493.20
Frames: 141388
CDSize: 4350.00
Number of CDs: 1
Cut point 4345.00
Max. Bitrate: 9000
Avg. Bitrate: 5836.06
Min. Bitrate: 200
Executing TMPGEnc. Commandline:
"C:\Documents and Settings\Administrator\Desktop\úé÷éä çãùä (2)\TMPGEnc.exe" "D:\DVD\TMPGEnc_Project_file.tpr" /Encode /Close
Video Encoding finished.
- 02/12/2006 15:58:08
- Multiplexing Audio and Video
Executing MPlex. Commandline:
"D:\DVD2SVCD\DVDAuthor\mplex.exe" -f 8 -o "D:\DVD\MPlex_Muxed_File00.mpg" "D:\DVD\Encoded_Video_TMPGEnc_NTSC.mpv" "D:\DVD\Encoded_audio_1.mp2"
- 02/12/2006 15:58:11
- Determining length of audio
Analyzing finished.
Saving Subtitle Timecodes.
SVCD subtitles.
- 02/12/2006 16:04:13
- Multiplexing Subtitles
Executing SpuMux. Commandline:
"D:\DVD2SVCD\DVDAuthor\spumux.exe" -m dvd -s 0 "D:\DVD\Subs\iw1-1.xml" < "D:\DVD\MPlex_Muxed_File00.mpg" | "D:\DVD2SVCD\DVDAuthor\spumux.exe" -m dvd -s 1 "D:\DVD\Subs\en2-1.xml" > "D:\DVD\MPlex_Muxed_File00-subbed.mpg"
SpuMux failed for unknown reasons!
For details open: "D:\DVD\Subs\SpuMux_log.txt"
ואז הלכתי לראות את הפרטים ורשום לי :The system cannot find the file specified
ועכשיו מה אני אעשה? מישהו יודע?
אם אתה רוצה להעביר קובץ AVI לDVD תשיג את CONVERTXTODVD של VSO, אני משתמש בה המון זמן והיא מדהימה!
יש לך מדריך איך לתוכנה?
זו תוכנה כל כך פשוטה שלא צריך מדריך.
פשוט משנים את שם הקובץ של הכתוביות לשם הקובץ של הסרט.
לוחצים על ה + כדי להוסיף את הסרטים.
וזהו רק לבחור CONVERT.
