Rivatuner 16.2 עם תמיכה מלאה בG80
פירוט על הגירסא החדשה:
Added experimental NV50/G80 GPU support. Thanks to Andrew Worobiew for testing RivaTuner with NVIDIA GeForce 8800GTX and NVIDIA GeForce 8800GTS display adapters.
Added new CSAA modes for G80 bases display adapters.
Improved low-level hardware diagnostic report module:
Added G80 streaming processors detection support. Currently RivaTuner is the only low-level diagnostic tool able to detect and display the amount of active streaming processors on G80 based display adapters.
Added G80 memory controller support. Currently RivaTuner is the only low-level diagnostic tool able to detect and display type of memory installed on G80 based board and amount of active ROP/MC units forming total memory bus width.
Added G80 clock frequency generators support. Currently RivaTuner is the only low-level diagnostic tool able to monitor core ROP and Shader domain clocks and memory clocks.
Added G80 specific performance tables v1.5 support for G80 VGA BIOS images. Now RivaTuner can display G80 specific core ROP domain and shader domain clocks defined in VGA BIOS in "NVIDIA VGA BIOS information" diagnostic report category.
Added G80 specific voltage tables v2.0 support for G80 VGA BIOS images. Now RivaTuner can display G80 specific voltage tables defined in VGA BIOS in "NVIDIA VGA BIOS information" diagnostic report category.
Added extended G80 I2C bus support. Now RivaTuner is able to access all 4 I2C buses available on G80 based bards. Please take a note that currently RivaTuner doesn't access G80 I2C controller directly and uses ForceWare's I2C access layer instead. Direct low-level access to G80 I2C buses will be implemented in future versions. Due to these limitations RivaTuner's I2C access code for G80 will not work under Vista, so low-level features depending on I2C (e.g. fan control, ambient temperature and fan speed monitoring) won't be available under this OS for G80.
Added low-level fan control tab for G80 based boards with external I2C ADT7473 sensor and fan controller.
Updated NVStrap driver v1.12:
Added G80 support including streaming processors control support . Now the testers can disable G80 streaming units (block of 16 streaming processors) one by one to study G80 shader performance scaling and simulate not yet announced G80 based models' performance.
להורדה מפה:
http://downloads.guru3d.com/download.php?det=163
לכל אלה שכבר הספיקו לקנות 8800GTS/GTX אפשר אולי תוצאות אוברלקוק? ;)
