עזרה! התקנתי דריברים וכשאני בא להפעיל משחק זה רושם|כנסו
זה רושם את מה שרשום למטה
בבקשה עזרה! :s05: :s05:
כרטיס מסך 9250
[attachment deleted by admin]
בעיה מוכרת... הצלחתי למצוא באתר אחר מידע שכדאי שתנסה:
QUOTE
Reinstall your graphics drivers. I have never toyed with AGP, but there should be an option somewhere in the advanced (Ctrl Panel>Display>settings>Advanced) display settings that allows you to vary the width of AGP. Set it to max, or default (which should be max but I guess some people have issues running that. If you know your computer can only run AGP 2x or 4x and not 8x, then set it to the highest your motherboard can support.
QUOTE
There is a setting in your BIOS. Also in your graphic card settings, right click desktop==>properties==>settings==>advanced it will be in one of the tabs, you get different tabs dependant on different video cards, but there will be a setting in there to alter AGP settings.
QUOTE
You can change it in your BIOS....BUT if you do not know how to do it, don't mess with it you can end up doing more harm than good. Now I had that problem when C3 came out, I had bought a new video card and my computer had an on board video card in it. What you have to do is go to
Right Click My Computer->Properties
Go to the hardware tab and click device manager.
Once that window opens usually there is a "System Devices" drop down menu, click the + next to it, somewhere in there you will find one for your on board card. You actually have to update that as well for your computer to recognize that it is now AGP enabled.
QUOTE
I take it you ahve an on board graphics and are using an agp graphics card now? What you need to do to solve this is install the drivers for the onboard graphics card. BOOM problem solved ;) That used to piss me off when i started linegage
and finally:
QUOTE
actually this has nothing to do with setting ur AGP to first device, if u set ur AGP aparture size to below 64m it deactivates AGP And runs ur AGP as PCI so set ur agp aparture size to 256m if u have 512ram in ur system and 128 if u have 256
זה לא פתר כלום בבקשה עזרה!
אתה לא רציני?! אתה הולך להגיד לי שניסית באמת את כל מה שרשמתי פה ב-10 דקות?
אתה חייב לנסות את כל הסעיפים לפני שכן הם פתרונות של גולשים שחוו את הבעיה שאתה מתאר... אם אתה לא מבין חלק מסוים רק תאמר ונסייע לך.
