האם זה אומר שהרדיסק דפוק.
אני פונה בגלל שהיו לי BAD SECTOR
כמו כן בעיות התעקויות של מחשב.
Your hard disk's S.M.A.R.T. attributes are now being analyzed and a full report about the reliability, health and status of your hard disk is generated:
Your hard disk is not below any attribute threshold. This is good.
Your hard disk was never below any attribute threshold. This is good.
Your hard disk is now being compared to real data used to define normal values for your specific hard disk model. This way, the analysis can automatically use proper operating ranges. The images give you an idea of how each attribute is within such range. Current and raw values are shown for easier reference for experienced users. There are 1166 hard disk models in the current archive.
Attribute Current Raw Overall
Spin Up Time 188 15083 Normal
Start/Stop Count 253 706 Very good
Reallocated Sector Count 253 0 Very good
Read Channel Margin 253 0 Very good
Seek Error Rate 253 0 Very good
Seek Time Performance 250 43749 Good
Power On Hours Count 218 7794 Good
Spin Retry Count 253 0 Very good
Calibration Retry Count 253 0 Very good
Power Cycle Count 251 996 Good
Power Off Retract Count 253 0 Very good
Load Cycle Count 253 0 Very good
Hardware ECC Recovered 253 3259 Very good
Reallocated Event Count 253 0 Very good
Current Pending Sector 253 0 Very good
Offline Uncorrectable Sector Count 253 0 Very good
Ultra DMA CRC Error Rate 1 11919 Watch
Warning: Ultra DMA CRC Error Rate is below the average limits (193-199).
Write Error Rate 253 0 Very good
Soft Read Error Rate 253 2 Very good
TA Increase Count 253 0 Very good
Run Out Cancel 253 0 Very good
Shock Count Write Opern 253 0 Very good
Shock Rate Write Opern 253 0 Very good
Spin High Current 253 0 Very good
Spin Buzz 253 0 Very good
Offline Seek Performance 194 0 Normal
Unknown attribute 99 253 0 Very good
Unknown attribute 100 253 0 Very good
Unknown attribute 101 253 0 Very good
NOTE: not all warnings are reflected on fitness and performance overall values as relevancy is based upon the settings from the hard disk manufacturer who is the best entity deputed to define such relationships.
NOTE : your hard disk Ultra DMA CRC Error Rate attribute current value (1) is below the normal range (193 - 199) reported for your specific hard disk model. This usually means that some communication errors occurred between the hard disk and the external controller. Most likely those errors are due to the cable. Double check it, reroute it and, if needed, replace it.
The overall fitness for this drive is 95%.
The overall performance for this drive is 94%.
The link to get back and see a new report about this hard disk in the future is this. Consider that new hard disks and new checks are added over time.
DISCLAIMER: this report does its best to highlight issues and warnings related to your hard disk. It cannot be held responsible for any mistake. This page and its results cannot be used in any other way but the one defined by its author.
זה ממש לא משנה מה כל תוכנות הניטור האלו אומרות כי הן לא 100% מדוייקות, אבל אם היה לך bad sectors תגבה באופן שוטף לכל צרה שלא תבוא.
באיזה תוכנה לגבות
יש לי הרד דיסק 250 ג'יגה. מערכת ההפעלה ב-30 גיגה ב- NTFS
יש לי הרד דיסק 40 גיגה.כרגל ללא ב-NTFS
האם צריך לחלק ואיל לגבות. תודה
דברים שממש חשובים עדיף לגבות ל DVD, דברים שמעט פחות חשובים תשים בדיסק הקשיח השני (זה שלא היה לו bad sectors).
איזו תוכנה הכי טובה לגיבוי מכונן קשיח למשנהו, חוץ מנורטון
תלוי, אם אתה רוצה לגבות את כל הHD, אפשר להשתמש בGHOST, אם רק חלקים ממנו, צריבה לDVD תיהיה טובה מספיק (בעזרה נרו אפילו)
אם אתה רוצה לגבות את מערכת ההפעלה, גם אני הייתי ממליץ להשתמש בגוסט (למרות שאני מחבב יותר את acronis).
אם זה סתם קבצים (שירים, סרטים וכו...) פשוט להעתיק אותם לדיסק הקשיח המשני.
אבל עדיין הדבר הכי טוב לעשות זה לגבות על מדיות DVD, כונן קשיח שמראה שיש לו bad sectors אי אפשר לסמוך עליו, הוא יכול להחזיק מעמד יופי שנים או לחלופין הוא יכול למות שבוע הבא.
רציתי לעשות בארקוניס וגם בתוכנה השנייה אך בארקוניס לא נתן כי רצה לגבות את כל הכונן ולא מחיצה .
אני מקווה שבגוסט נורטון זה אפשרי.
אקרוניס כן נותן לגבות מחיצה, פשוט תבחר ב The entire disk contents or individual partition, תבחר את C וזהו.
Acronis®TrueImageHome® version 10.0 (build4,871)
לא מצאתי
אולי תדריך אותי צעד צעד עד שאגיע.
מצטער שאני מנדנד. פשוט לא מצאתי
וואלה, אני משתמש ב server, אולי אין את האופצייה הזו ה home.
